IAP-105s, IAP-175Ps and new IAP-215s
  • 1.  IAP-105s, IAP-175Ps and new IAP-215s
    Posted Nov 19, 2015 06:33 PM
    We have a site with many IAP-105s and a few IAP-175Ps.  Outside of making certain these are running the latest firmware, any issue with adding new IAP-215s to this mix?  Thank you.
  • 2.  RE: IAP-105s, IAP-175Ps and new IAP-215s
    Posted Dec 15, 2015 07:15 AM
    No issues, only need to be sure to have the same firmware on the IAP's. IAP105-175 have a different firmware than the IAP215.
  • 3.  RE: IAP-105s, IAP-175Ps and new IAP-215s
    Posted Dec 16, 2015 06:52 PM
    Thanks for chiming in—didn’t think anyway would (the OP is a month old!).  For what it’s worth, all I did was update the firmware on the existing APs to the latest version—once I connected the 215s to the LAN, everything simply “Just Worked” and they became part of the cluster.
    Cheers.
