IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
  • 1.  IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Nov 18, 2013 11:10 AM
    We have 16 IAP-105-US Installed at a co-op 60 and over apartment complex.
    8-On east side of building Connected to a Comcast Business Class Modem..
    8-On west side building.. Connected to a Comcast Business Class Modem..
    Since updating to firmware : 6.2.1.0-3.4.0.3_40346
    We had MANY DHCP TIMEOUTS – Also people are having a hard time connecting ..
    – Really NEVER saw this with other Firmware Ver’s – Not Sure What Ver’s Were OK !
    AP’s Are setup to hand out DCHP … And I see from the ALERTS – DCHP Timeout
    When I login to the IAP web page I see 2-3 people that have a 0.0.0.0 IP
    Really Could Use Some Help! Suggestions ? Please ?
    version 6.2.1.0-3.4.0
    virtual-controller-country US
    virtual-controller-key c1abcf9d01b1e68bf1f8c96187eab3bcf1d26ddc9b33c365e2
    name Instant-CD:EF:AE
    terminal-access
    ntp-server time.nist.gov
    clock timezone Central-Time -06 00
    clock summer-time CDT recurring second sunday march 02:00 first sunday november 02:00
    rf-band all
    allow-new-aps
    allowed-ap 24:de:c6:cd:ef:ae
    allowed-ap 24:de:c6:cd:ef:e8
    allowed-ap 24:de:c6:cd:ef:b5
    allowed-ap 24:de:c6:cd:f0:04
    allowed-ap 24:de:c6:cd:f0:ba
    allowed-ap 24:de:c6:cd:f0:0a
    allowed-ap 24:de:c6:cd:f0:86
    arm
     wide-bands 5ghz
     min-tx-power 127
     max-tx-power 127
     band-steering-mode disable
     air-time-fairness-mode default-access
     client-aware
     scanning
     spectrum-load-balancing
    rf dot11g-radio-profile
     spectrum-monitor
     interference-immunity 4
    rf dot11a-radio-profile
     spectrum-monitor
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin 240403e085c4fb83b72d66d1d1e5b7c536e9717c34d5d36a
    wlan access-rule default_wired_port_profile
     index 0
     rule any any match any any any permit
    wlan access-rule Green-House-Village
     index 1
    wlan access-rule wired-instant
     index 2
     rule 10.1.10.10 255.255.255.255 match tcp 80 80 permit
     rule 10.1.10.10 255.255.255.255 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan ssid-profile Green-House-Village
     enable
     index 0
     type guest
     essid Green-House-Village
     wpa-passphrase 3f05e201865e34794899ce5695172bd1f580305235a85fb4
     opmode wpa-psk-tkip,wpa2-psk-aes
     max-authentication-failures 0
     vlan guest
     rf-band all
     captive-portal disable
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter none
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
     wireless-containment none
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
    #3600
  • 2.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Nov 18, 2013 12:55 PM
    Please open a case for this.
  • 3.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 04:22 PM
    I have opened a ticket :  Case # 1481656 : DHCP TIMEOUT issue: [ ref:_00D3008G4._50040VpEjw:ref ]
    However .. No One seems to beable to fix this .. nor help.
    1. Updated and Down Graded to different firmware ver's
    2. Set =  broadcast filter all - And ARP
    3. Set All IAP's to a static IP's Instead of DHCP
    Does anyone know how to set the IAP DHCP Lease times  ???
    Does Anyone Have a Suggestions ??????
    version 6.3.1.0-4.0.0
    terminal-access
    led-off
    rf-band all
    allow-new-aps
    arm
     wide-bands 5ghz
     min-tx-power 127
     max-tx-power 127
     band-steering-mode prefer-5ghz
     client-aware
     scanning
    ip dhcp pool
     lease-time 60
    mgmt-user admin 9af989b52feb59a734571041deea557eb3734fff626efa0f
     index 0
    wlan access-rule default_dev_rule
     index 1
     index 2
     index 3
     rule 10.1.10.11 255.255.255.255 match tcp 80 80 permit
     rule 10.1.10.11 255.255.255.255 match tcp 4343 4343 permit
     enable
     index 0
     type guest
     wpa-passphrase be85d10c2930763a6a3f9882479a4460b20ae79b28ab9f19
     vlan guest
     rf-band all
     dtim-period 1
     inactivity-timeout 1800
     broadcast-filter arp
     blacklist
     server localhost
     port 80
     url "/"
    blacklist-time 3600
    ids classification
    ids
     allowed-vlan all
     native-vlan 1
     shutdown
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
     allowed-vlan all
     native-vlan 1
     no shutdown
     speed auto
     duplex auto
     no poe
     type employee
     no dot1x
    uplink
     preemption
     enforce none
     failover-internet-check-timeout 10
    airgroup
     disable
     disable
     description AirPlay
     disable
  • 4.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 05:34 PM
    Can you share the output of "show tech-support" from the VC? Are the 16 APs organized into two separate clusters, each with 8 APs?
  • 5.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 05:58 PM
    THANK YOU FOR THE REPLY !
    My Customer is getting very un-happy with me and the system :(
    We have ( 2 ) Total IAP-105-us Systems ..  Both Setup Exactly the Same ... Not ( 8 )  My Bad Typing Sorry.
    Organized into two separate clusters, each with 7 APs?
    7 - IAP-105's On east side of building .. Connected to a Comcast Business Class Modem and 8-Port 10/100Mbps PoE Switch - TPE-S80
    7 - IAP-105's On west side building .. Connected to a Comcast Business Class Modem and 8-Port 10/100Mbps PoE Switch - TPE-S80
    What is: APAS provision failed, code: fail-prov-no-rule   ??????
    Please look at : Console.txt  < Attched as Link - 60 pages
    https://www.dropbox.com/s/hcjsbj3ct2tiqgf/Console.txt
    show log system
    12/9/13 Console
    51/60
    Dec 9 15:08:04 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:08:08 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:08:40 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 15:11:41 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 04:54:53:ed:78:e2 connect fail because DHCP request timed out
    Dec 9 15:13:07 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:13:11 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:18:10 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:18:13 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:22:41 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 15:22:41 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 00:26:5e:07:08:c1 connect fail because DHCP request timed out
    Dec 9 15:23:12 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:23:16 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:26:42 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client d4:9a:20:5c:17:0b connect fail because DHCP request timed out
    Dec 9 15:28:16 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:28:19 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:30:42 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 15:33:19 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:33:23 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:33:30 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.16: Client 00:22:6b:a3:10:5c connect fail because DHCP request timed out
    Dec 9 15:36:42 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 15:37:42 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client 28:6a:ba:35:af:65 connect fail because DHCP request timed out
    Dec 9 15:38:21 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:38:25 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:38:42 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client 00:22:69:61:bd:10 connect fail because DHCP request timed out
    Dec 9 15:42:43 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 15:43:24 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:43:27 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:44:13 cli[1110]: <341102> |AP 1-East@10.1.10.11 cli| Incorrect format for message type 126:220:46:10:10.1.10.15:15200.
    Dec 9 15:45:30 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.16: Client 18:e7:f4:b0:47:3a connect fail because DHCP request timed out
    Dec 9 15:48:26 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:48:30 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:49:34 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.11: Client 7c:c3:a1:b5:7a:37 connect fail because DHCP request timed out
    Dec 9 15:49:43 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client b8:e8:56:69:94:68 connect fail because DHCP request timed out
    Dec 9 15:51:43 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client 88:cb:87:e6:f1:87 connect fail because DHCP request timed out
    Dec 9 15:53:28 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:53:32 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:57:44 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 04:54:53:ed:78:e2 connect fail because DHCP request timed out
    Dec 9 15:57:44 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 15:58:31 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 15:58:35 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 15:58:38 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.15: Client 00:12:17:9b:4a:f8 connect fail because DHCP request timed out
    Dec 9 16:03:33 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 16:03:37 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 16:04:36 cli[1110]: <341102> |AP 1-East@10.1.10.11 cli| Incorrect format for message type 126:220:46:10:10.1.10.15:15200.
    Dec 9 16:07:44 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client 00:1b:9e:bd:1d:50 connect fail because DHCP request timed out
    Dec 9 16:08:35 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 16:08:39 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 16:11:39 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.15: Client a4:d1:d2:0b:95:8a connect fail because DHCP request timed out
    Dec 9 16:11:45 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 94:44:52:9e:71:70 connect fail because DHCP request timed out
    Dec 9 16:13:38 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 16:13:38 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.17: Client 70:de:e2:a1:26:7e connect fail because DHCP request timed out
    Dec 9 16:13:41 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 16:15:45 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.14: Client 00:26:5e:07:08:c1 connect fail because DHCP request timed out
    Dec 9 16:16:32 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.16: Client 00:22:6b:a3:10:5c connect fail because DHCP request timed out
    Dec 9 16:16:45 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client d4:9a:20:5c:17:0b connect fail because DHCP request timed out
    Dec 9 16:18:40 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 16:18:44 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 16:23:43 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 16:23:46 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 16:26:39 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.15: Client 18:e7:f4:b0:47:3a connect fail because DHCP request timed out
    Dec 9 16:28:45 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| Isc_send_request
    Dec 9 16:28:49 cli[1110]: <341005> |AP 1-East@10.1.10.11 cli| APAS provision failed, code: fail-prov-no-rule
    Dec 9 16:29:46 cli[1110]: <341004> |AP 1-East@10.1.10.11 cli| AP 10.1.10.12: Client 68:a8:6d:4e:bb:de connect fail because DHCP request timed out
  • 6.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 06:20 PM
    Could the wired network be using the subnet 172.31.98.0? Could we try manually configure the DHCP pool to a different subnet (say 192.168.10.0), to see if anything changes?
  • 7.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 06:29 PM
    No ... the Comcast modem uses : 10.1.10.19/250 - 255.255.255.0 - 10.1.10.1  - See Pic
    I have set ALL IAP's To a Static IP To get from Comast Modem To See If that Helped Used: 10.1.10.11/17
    ( It Was Set As DHCP )   DID NOT SEEM TO HELP!   :(
    How to set the IAP DHCP Lease times  ??????
  • 8.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 06:33 PM
    I understand your frustration and appreciate your patience in bearing with us. I know it may still take a few more tries before we get this working but I am confident that it will be resolved in the end.
    For now, could you recall which subnet was the client getting its IP from before the recent upgrade that caused all these problems? Is it 192.168.10.0?
    Yan
  • 9.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 06:54 PM
    Hmmm ... I have no Idea any more ..
    ( Bangs Head On Desk )
    I think ORG Firmware Gave Out : 192.168.1.-
    The Newest Firmware Gives Out : 172.31.98.-
    But I see a Few People Complaining about DHCP On The IAP-105's Here On This Fourm ..
    I have a feeling that the newest Firmware has a DHCP bug!
    Because I never had problems before with DHCP ... After Updating Firmware .. Is When problems started with DHCP.
    ( Now No Matter What Ver Firmware I Try It Still Has Problems )
    I Also think maybe whats happing is .. the IAP-105 is running out of IP's to hand out
    Because the DHCP Lease Time is not working or not set  ???
    Anyway ...
    Do we know what is : APAS provision failed, code: fail-prov-no-rule   ???
    How do we set the IAP DHCP Lease times  ???
  • 10.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 07:04 PM
    The lease time can be set in the UI via 'System > Show Advanced Options > DHCP'. You can also try changing the subnet here back to 192.168.10.0, mask 255.255.255.0, to see if it helps.
    The 'APAS provision failed' message is due to the fact that this network is provisioned manually instead of via our cloud-based activation system to provision your IAPs, so there is no cause for concern.
  • 11.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 07:15 PM
    THANK YOU FOR YOU REPLY ...
    I have set the DHCP Time Out To 1-Hour at about 10am today.
    I found this today about 10AM But was not sure that was the correct place.
    ( This does not seemed to help )   :(
    Would be be so kind and help me fill in whats needed ?
    Domain Name =  ?
    DNS Servers = ?
    Network = ?
    Mask =?
  • 12.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 07:25 PM
    I would leave domain name and DNS servers blank, but fill in "192.168.10.0" for the network and "255.255.255.0" for the mask, to see if there is any improvement.
  • 13.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 07:49 PM
    Ok I set the DHCP In Settings ...
    I also set the DNS to OPEN DNS ..
    I was Kinda worried about not setting a DNS Server LOL
    Seems Weird .. that the people connecting are now getting very HIGH IP's  like : .199 or .170  ect
    ( See Pic )
  • 14.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 08:19 PM
    Hmmmm .. Still getting DHCP Time Outs Ater Setting up DHCP In Settings :(
    ( See Pic )
  • 15.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 08:25 PM
    Did the number of timeouts reduce at all or everything looks about the same?
    BTW if we do not configure a DNS server in the DHCP pool, the IAP will give out its own DNS server to the clients.
  • 16.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 09, 2013 10:57 PM
    Its the same amount  :(
  • 17.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 03:16 AM
    From the screen-shot, we can see every client in alert table can get IP address finally because they displayed with clients in client table.This alert in this scenario is harmless. And it is trying to tell us there was DHCP request timed out ever when client cannot get DHCP request in 30s in that time.
    How about we focus on the clients that still in 0.0.0.0 status? Can we know which kinds of client they are? And how about the its wireless enviornment that time? And get show tech-support in that AP that the 0.0.0.0 client tring to connect.
  • 18.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 03:23 AM
    If we did not set DHCP lease time in system, the default value for DHCP Server is 12 hours.
  • 19.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 08:10 AM
    Yes .. you are correct ... clients do get an IP after a while ..
    ( However this was never an issue before firmware update .. Never saw DHCP error untill now )
    This is because of me rebooting the AP's
    However after 1-3 days they start getting 0.0.0.0 IPs
    The Orignal 7 IAP-105's on the WEST Side of Bulding
    Have been installed for 8-9 months with NO PROBLEMS - NO DHCP ERRORS - NO REBOOTS - WORKED VERY WELL
    ( Till Firmware Update - 1 month ago )
    Worked So Good In Fact .. The Customer Bought 7 more for east side
    Here is a link to ALL IAP's TECH Dump .. 14 - Txt Docs
    https://www.dropbox.com/s/w002cc98d5b4252/SYSTEM-DUMP-FILES.zip
    here is what it looks like when that happens ...
    ( Older Pic from 11-26-13  - 4:57 PM )
  • 20.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 09:58 AM
    From the currently log, there is only one client connected to 6-West cannot connect to IAP because of wrong passphase, its mac-address is 34:23:ba:3d:c2:3f,
    Dec 6 08:38:55 wpa2-key1 <- 34:23:ba:3d:c2:3f 6c:f3:7f:c4:c7:12 - 117
    Dec 6 08:38:55 wpa2-key2 -> 34:23:ba:3d:c2:3f 6c:f3:7f:c4:c7:12 - 117 mic failure
    Can we get the same logs when lots of clients cannot connect to IAP? We'd like to analyse what happen that time.
  • 21.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 03:51 PM
    I Will Update when I see this happen ...
    I have Updated to this firmware today ...
    Build Time:
    2013-11-26 12:32:36 PST
    Version:
    6.3.1.1-4.0.0.1_41049
    Still Getting DHCP Errors .. However sofar no 0.0.0.0 Ip's
    Here is the log from Client 94:44:52:9e:71:70 - Who Showed up as a DHCP Timeout Error
    show datapath user
    Datapath User Table Entries
    Flags: P - Permanent, W - WEP, T- TKIP, A - AESCCM
           R - ProxyARP to User, N - VPN, L - local, I - Intercept
    FM(Forward Mode): S - Split, B - Bridge, N - N/A
           IP              MAC           ACLs    Contract   Location  Age    Sessions   Flags     Vlan  FM
    10.1.10.14       24:DE:C6:CD:F0:04   105/0      0/0     0         1        1/65535  P           1   N
    0.0.0.0          B8:E8:56:69:94:68   131/0      0/0     0         0        0/65535  P        3333   B
    192.168.10.251   94:44:52:9E:71:70   131/0      0/0     0         0       62/65535           3333   B
    192.168.10.1     24:DE:C6:CD:F0:04   105/0      0/0     0         656      0/65535  P        3333   B
    192.168.10.65    04:54:53:ED:78:E2   131/0      0/0     0         23       2/65535           3333   B
    192.168.10.71    B8:E8:56:69:94:68   131/0      0/0     0         12       2/65535           3333   B
    0.0.0.0          04:54:53:ED:78:E2   131/0      0/0     0         0        0/65535  P        3333   B
    0.0.0.0          94:44:52:9E:71:70   131/0      0/0     0         0        0/65535  P        3333   B
    0.0.0.0          24:DE:C6:CD:F0:04   105/0      0/0     0         0        1/65535  P           1   N
    end of show datapath user
    <active_objs><num_objs><active_slabs><num_slabs>Dec 10 14:18:43  stm[1117]: stm_send_sta_offline: Sending sta offline msg to CLI0, mac='94:44:52:9e:71:70'
    Dec 10 14:18:43  cli[1109]: <541004>  |AP 4-East@10.1.10.14 cli|  recv_sta_offline: receive station msg, mac-94:44:52:9e:71:70 bssid-00:00:00:00:63:6c ssid-.
    Dec 10 14:18:43  stm[1117]: update_ip_mac_role_acl_vlan: 12587: user entry deleted for '192.168.10.251' '94:44:52:9e:71:70'
    Dec 10 14:18:43  sapd[1113]: sapd_proc_stm_reset_key: Got STM Reset key bss=24:de:c6:5f:00:42 mac=94:44:52:9e:71:70, idx=0
    Dec 10 14:18:53  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:19:46  stm[1117]: add dhcp ageout alert >>>>
    Dec 10 14:19:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:20:50  stm[1117]: stm_alert_send: 2313: send 1 new alerts to send to master
    Dec 10 14:20:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:21:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:23:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:24:40  stm[1117]: VLAN_HIGHER_PRECEDENCE_THAN_STORED: 1020: vlan_rule_index=ff, sap_sta->vlanhow=ff, precedence_result=1
    Dec 10 14:24:40  stm[1117]: __HIGHER_PRECEDENCE_COMPARE: 997: matched_rule_index=37fff, sap_sta->acl_rule_index=0, precedence_result=1
    Dec 10 14:24:40  stm[1117]: stm_send_sta_update: Sending sta update msg to CLI0, mac='94:44:52:9e:71:70'
    Dec 10 14:24:40  cli[1109]: <541004>  |AP 4-East@10.1.10.14 cli|  recv_sta_online: receive station msg, mac-94:44:52:9e:71:70 bssid-24:de:c6:5f:00:42 ssid-Green-House-Village.
    Dec 10 14:24:40  cli[1109]: <541004>  |AP 4-East@10.1.10.14 cli|  recv_stm_sta_update: receive station msg, mac-94:44:52:9e:71:70 bssid-24:de:c6:5f:00:42 ssid-Green-House-Village.
    Dec 10 14:24:40  stm[1117]: recv_radius_acct_multi_session_id: 14254: got mac='94:44:52:9e:71:70', name='', start_time='1386703314 (Tue Dec 10 13:21:54 2013 )'
    Dec 10 14:24:40  stm[1117]: stm_start_acct_for_post_1xauth_user: 14295: ip not ready for sta '94:44:52:9e:71:70'
    Dec 10 14:24:40  stm[1117]: wpa2_encrypt_key() called
    Dec 10 14:24:40  sapd[1113]: sapd_proc_stm_reset_key: Got STM Reset key bss=24:de:c6:5f:00:42 mac=94:44:52:9e:71:70, idx=0
    Dec 10 14:24:40  sapd[1113]: sapd_proc_stm_keys:klen=16, bssid=24:de:c6:5f:00:42, mac=94:44:52:9e:71:70, standby=0
    Dec 10 14:24:40  sapd[1113]: sap_recv_keys: default type=30816
    Dec 10 14:24:40  sapd[1113]: do_madwifi_set_key:isgroup=0 isigtk=0 dev=aruba102 bssid=24:de:c6:5f:00:42 klen=16 idx=65535
    Dec 10 14:24:40  sapd[1113]: sapd_proc_stm_txkey: Got STM Tx key msg
    Dec 10 14:24:43  stm[1117]: rap_bridge_user_handler: 11687: rbs update: flags:1/1 aclnum:131 ip:192.168.10.251 mac:94:44:52:9e:71:70 bssid:24:de:c6:5f:00:42 vlan:3333 wired:0
    Dec 10 14:24:43  stm[1117]: rap_bridge_user_handler: 11706: user entry created for '192.168.10.251' '94:44:52:9e:71:70'
    Dec 10 14:24:43  stm[1117]: stm_start_acct_for_post_1xauth_user: 14314: not authenticated for sta '94:44:52:9e:71:70'
    Dec 10 14:24:43  stm[1117]: rap_bridge_user_handler: 11687: rbs update: flags:1/2 aclnum:131 ip:192.168.10.251 mac:94:44:52:9e:71:70 bssid:24:de:c6:5f:00:42 vlan:3333 wired:0
    Dec 10 14:24:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:25:16  stm[1117]: Client 94:44:52:9e:71:70 connect successfully
    Dec 10 14:25:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:26:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:28:54  sapd[1113]: sapd_papi_rcv_cb: Packet received from unknown port 15208
    Dec 10 14:30:15  stm[1117]: VLAN_HIGHER_PRECEDENCE_THAN_STORED: 1020: vlan_rule_index=ff, sap_sta->vlanhow=ff, precedence_result=1
    Dec 10 14:30:15  stm[1117]: __HIGHER_PRECEDENCE_COMPARE: 997: matched_rule_index=37fff, sap_sta->acl_rule_index=0, precedence_result=1
    Dec 10 14:30:15  stm[1117]: stm_send_sta_update: Sending sta update msg to CLI0, mac='b8:e8:56:69:94:68'
  • 22.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 04:03 PM
  • 23.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 10, 2013 10:00 PM
    Thanks the update.
    As we said before, the alert is harmless because clients could get IP address.
  • 24.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 14, 2013 11:15 AM
    UPDATE:
    I was able to talk on the phone with: Joe Powell | Territory Manager Minnesota, North Dakota & South Dakota
    And Elliott Patterson Systems Engineer | Aruba Networks Minnesota
    Elliott Patterson - Systems Engineer | Aruba Networks Minnesota
    Came to the job site! At 5pm - 5:30pm at night to help me!
    ( Way Beyond The Call Of Duty And Very Very Nice Of Him To Help! )
    He found that the configuration files on BOTH East and West Side was somehow corrupted.
    Both East and West Side Systems were NOT Working - Client DHCP and IAP to Modem DHCP Was Not Functioning Correctly.
    ( Possibly got corrupted from firmware updates ??? )
    After trying to fix the IAP AND CLIENT DHCP problems for about an hour or more .. He / We were unable to correct the problems!
    We both decided to DELETE ALL CONFIGURATION FILES AND FACTORY RESET ALL IAP-105'S
    We Then Updated Both West and East Side IAP's With New Firmware ...
    Build Time: 2013-11-26 12:32:36 PST - Version: 6.3.1.1-4.0.0.1_41049
    And Then Re-Setup Both: West And East Systems With New Configurations.
    We Setup the configuration file to use the MODEM Assigned DHCP
    We Are Not Using the IAP-105 Virtual Controller Assigned DHCP
    We Are Now Getting: Very Little DHCP ERRORS AND ( 0-2 ) DHCP ALERTS IN THE WEB GUI
    Were As We Were Getting: MANY DHCP ALERTS AND 0.0.0.0 IP FAILS ( 2-6 ) IN THE WEB GUI
    And clients are not getting 0.0.0.0 Ips any more!
    The Above Actions Seems To Have Fixed The Problems We Were Having!
    ( Well So far Anyway  LOL  - Time Will Tell If This Was A Permanent Fix )
    I REALLY WANT TO THANK: Elliott Patterson And Joe Powell And Everyone At Aruba Networks
    For going way beyond the call of duty. And Helping Us Resolve This Problem!
  • 25.  RE: IAP-105US - DHCP PROBLEMS - CONNECTIONS - Please Help !
    Posted Dec 20, 2013 09:21 AM
    FWIW, we are seeing the DHCP timeout alerts in the logs of an IAP-105 group comprised of 5 APs.  The VC has two SSIDs, and the timeouts occur on both.  Both SSIDs get DHCP from the network.
    We are running 6.2.1.0-3.4.0.3_40346.
