IAP-115 Drop Ethernet Connection for a few seconds.
  • 1.  IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Nov 23, 2018 10:42 AM
    Hi, we have a Instant setup with 91 Access points, 10 of these are in one building and randomly drop and pick up the Ethernet connection the APs that drop are all the IAP-115 model. We have a few IAP-215 and IAP-315 as well which work fine.
    Aruba 6.5.4.9_67129
    These have been split them between two switches with different uplinks to try and solve this issue. No luck. The APs work fine in different buildings. Here's the System Log...
    Nov 23 15:08:49  cli[2355]: <341271> <ERRS> |AP Junior_Art@10.10.85.54 cli|  ethernet uplink bond0 link down.
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  stopping DHCP on bond0
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  ip address get failed
    Nov 23 15:08:49  cli[2355]: <341185> <WARN> |AP Junior_Art@10.10.85.54 cli|  Retrieving ip address from uplink, ip 10.10.85.54, mask 255.255.0.0.
    Nov 23 15:08:49  cli[2355]: <341274> <WARN> |AP Junior_Art@10.10.85.54 cli|  Update election ip from br0, election ip 10.10.85.54/255.255.0.0.
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  build_my_ip_address: old ip and new ip same; skipping
    Nov 23 15:08:49  cli[2355]: <341167> <WARN> |AP Junior_Art@10.10.85.54 cli|  Uplink bond0 type Ethernet, state UP->DOWN.
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  uplink failure on slave
    Nov 23 15:08:49  cli[2355]: <341263> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable uplink .
    Nov 23 15:08:49  cli[2355]: <341167> <WARN> |AP Junior_Art@10.10.85.54 cli|  Uplink  type Dummy, state DOWN->PROBE.
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable dummy uplink
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSMain
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSInternal
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSGuest
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSBYOD
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSCat
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSComm
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable SSID[NottsHSDevices
    Nov 23 15:08:49  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  mute mesh portal as uplink fail.
    Nov 23 15:08:50  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  uplink failure on slave
    Nov 23 15:08:52  cli[2355]: <341272> <ERRS> |AP Junior_Art@10.10.85.54 cli|  ethernet uplink bond0 link up.
    Nov 23 15:08:52  cli[2355]: <341167> <WARN> |AP Junior_Art@10.10.85.54 cli|  Uplink bond0 type Ethernet, state DOWN->UP.
    Nov 23 15:08:52  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  ip address get failed
    Nov 23 15:08:52  cli[2355]: <341166> <WARN> |AP Junior_Art@10.10.85.54 cli|  Get interface br0 ip: 0.0.0.0/0.0.0.0.
    Nov 23 15:08:52  cli[2355]: <341005> <ERRS> |AP Junior_Art@10.10.85.54 cli|  wired reset detected, setup ip now
    Nov 23 15:08:52  cli[2355]: <341181> <WARN> |AP Junior_Art@10.10.85.54 cli|  Uplink bond0, setup ip for uplink - Ethernet.
    Nov 23 15:08:52  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  bring up dhcp client for ethernet uplink
    Nov 23 15:08:52  stm[2405]: <304055> <ERRS> |AP Junior_Art@10.10.85.54 stm| |ap| Unexpected stm (Station management) runtime error at rap_asap_to_stm_handler, 15024, rap_asap_to_stm_handler: recv - Network is down
    Nov 23 15:09:19  KERNEL(Junior_Art@10.10.85.54): (15:09:19) !!! Slave ---> Pot-Master
    Nov 23 15:09:20  KERNEL(Junior_Art@10.10.85.54): (15:09:20) I am POT_MASTER.recv-ed a pot master normal-beacon.
    Nov 23 15:09:20  KERNEL(Junior_Art@10.10.85.54): (15:09:20) master provision, 0 vs. 0
    Nov 23 15:09:20  KERNEL(Junior_Art@10.10.85.54): (15:09:20) !!! Election result, -5
    Nov 23 15:09:20  KERNEL(Junior_Art@10.10.85.54): (15:09:20) !!! Pot-Master ---> Slave
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  /etc/setup_ip_swarm Ethernet 1
    Nov 23 15:09:21  cli[2355]: <341166> <WARN> |AP Junior_Art@10.10.85.54 cli|  Get interface br0 ip: 10.10.85.54/255.255.0.0.
    Nov 23 15:09:21  cli[2355]: <341185> <WARN> |AP Junior_Art@10.10.85.54 cli|  Retrieving ip address from br0, ip 10.10.85.54, mask 255.255.0.0.
    Nov 23 15:09:21  cli[2355]: <341274> <WARN> |AP Junior_Art@10.10.85.54 cli|  Update election ip from br0, election ip 10.10.85.54/255.255.0.0.
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  build_my_ip_address: old ip and new ip same; skipping
    Nov 23 15:09:21  cli[2355]: <341006> <CRIT> |AP Junior_Art@10.10.85.54 cli|  Sending uplink_up msg to sapd
    Nov 23 15:09:21  cli[2355]: <341006> <CRIT> |AP Junior_Art@10.10.85.54 cli|  trap uplink info.
    23 15:09:21  cli[2355]: <341264> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable uplink .
    Nov 23 15:09:21  cli[2355]: <341167> <WARN> |AP Junior_Art@10.10.85.54 cli|  Uplink  type Dummy, state PROBE->DOWN.
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  disable dummy uplink
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSMain
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSInternal
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSGuest
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSBYOD
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSCat
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSComm
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  enable SSID[NottsHSDevices
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  un-mute mesh portal as uplink recover.
    Nov 23 15:09:21  cli[2355]: <341135> <WARN> |AP Junior_Art@10.10.85.54 cli|  Master Changed - new 10.10.85.69 old 10.10.85.21 current swarm state 3.
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  Swarm State Change from Startup to Found
    Nov 23 15:09:21  cli[2355]: <341213> <ERRS> |AP Junior_Art@10.10.85.54 cli|  cli_papi_dp_msg_handler: ASAP to CLI socket recv failed 12 127.
    Nov 23 15:09:21  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  recv non-3g setup_uplink finished from sapd
    Nov 23 15:09:22  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  Swarm State Change from Startup to Found
    Nov 23 15:09:24  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  CLI to PAPI port 8504 communication code 1
    Nov 23 15:09:27  cli[2355]: <341135> <WARN> |AP Junior_Art@10.10.85.54 cli|  Master Changed - new 10.10.85.21 old 10.10.85.69 current swarm state 1.
    Nov 23 15:09:27  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  Swarm State Change from Startup to Found
    Nov 23 15:09:31  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  CLI to PAPI port 8504 communication code 1
    Nov 23 15:09:32  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  Swarm State Change from Found to Image_ok
    Nov 23 15:09:33  nanny[2297]: <303073> <ERRS> |AP Junior_Art@10.10.85.54 nanny|  Process /aruba/bin/ntpclient [pid 11489] died: got signal SIGTERM
    Nov 23 15:09:33  nanny[2297]: <303079> <ERRS> |AP Junior_Art@10.10.85.54 nanny|  Restarted process /aruba/bin/ntpclient, new pid 14976
    Nov 23 15:09:50  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  restart dhcp helper and dnsmasq!!!
    Nov 23 15:09:50  cli[2355]: <341004> <WARN> |AP Junior_Art@10.10.85.54 cli|  recv_config_init: config isn't changed; skip config and change to sync complete
    Nov 23 15:10:27  cli[2355]: <341005> <ERRS> |AP Junior_Art@10.10.85.54 cli|  telnetd is missing, restarting
    Nov 23 15:25:14  KERNEL(Junior_Art@10.10.85.54): (15:25:14) !!! Slave ---> Pot-Master
    Nov 23 15:25:15  KERNEL(Junior_Art@10.10.85.54): (15:25:15) I am POT_MASTER.recv-ed a master normal-beacon.
    Nov 23 15:25:15  KERNEL(Junior_Art@10.10.85.54): (15:25:15) !!! Pot-Master ---> Slave
    Nov 23 15:28:23  KERNEL(Junior_Art@10.10.85.54): (15:28:23) !!! Slave ---> Pot-Master
    Nov 23 15:28:24  KERNEL(Junior_Art@10.10.85.54): (15:28:24) I am POT_MASTER.recv-ed a master normal-beacon.
    Nov 23 15:28:24  KERNEL(Junior_Art@10.10.85.54): (15:28:24) !!! Pot-Master ---> Slave
    VC is beconing as expected ALL the time. Switches are UPS supported.
    Any ideas?
  • 2.  RE: IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Nov 23, 2018 10:57 AM
    You should make the 315 the preferred master:
    Look for "Manual Provisioning of Master Instant AP" here:  https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Web_Help_Index.htm#Instant_UG/CustomizeIAPParams/Master_Election_Protocol.htm
    The 215 and 315 have more capacity to be the master than the iap-115 does.
  • 3.  RE: IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Nov 23, 2018 11:20 AM
    The master is an IAP-315.
  • 4.  RE: IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Nov 23, 2018 11:24 AM
    Do you have any other devices on the management VLAN besides the Instant APS?  You would only want the instant APs on the same management VLAN at this cluster size.  The instant APS rely on broadcasts to communicate with each other...adding more broadcasts could create more broadcast traffic and disrupt communications.
  • 5.  RE: IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Nov 23, 2018 11:29 AM
    Only the APs are on the management VLAN. I packet sniffed on a mirrored port to a faulting AP, On the management VLAN only AP traffic and broadcasts is showing up. Have 115s ever had any issues with noise? This is a newly extended building with many eco frendly gizmos like LED lighting and Solar panels.
  • 6.  RE: IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Nov 23, 2018 11:31 AM
    It would open a TAC case to pursue it further, or others can chime in. I am not aware of any specific issues.
  • 7.  RE: IAP-115 Drop Ethernet Connection for a few seconds.
    Posted Jun 20, 2020 03:48 PM
    were u able to solve this issue?
