IAP 115 external radius server set up
  • 1.  IAP 115 external radius server set up
    Posted Jul 21, 2014 11:54 AM
    is there any documents on setting up a external radius server for the IAP 115?
  • 2.  RE: IAP 115 external radius server set up
    Posted Jul 21, 2014 11:58 AM
    What kind of RADIUS server?
  • 3.  RE: IAP 115 external radius server set up
    Posted Jul 21, 2014 11:59 AM
    it's a WIN 2008 server
  • 4.  RE: IAP 115 external radius server set up
    Posted Jul 21, 2014 12:02 PM
  • 5.  RE: IAP 115 external radius server set up
    Posted Jul 21, 2014 12:03 PM
    Also, do you have to use a certificate to set up radius to work with the IAP?  Its asking for the EAP type for the policy.
  • 6.  RE: IAP 115 external radius server set up
    Posted Jul 21, 2014 12:08 PM
    If you are using PEAP or TLS, you will need a server certificate on the NPS server to provide the server identity to the client.
  • 7.  RE: IAP 115 external radius server set up
    Posted Jul 21, 2014 12:12 PM
    Thanks for the link/tutorial, I'll go over this and test.
