IAP 115 Wireless G client not able to connect
  • 1.  IAP 115 Wireless G client not able to connect
    Posted Mar 23, 2016 10:11 PM
    I have IAP115 with the firmware version 6.4.2.6-4.1.1.8_50989, all wireless G mobile client not able connect to this AP. It was all perfect before I do firmware upgrade. The SSID is with WPA Personal Security. I have also tested with wireless without security, the mobile client also not able to connect.
    Please advise what should I do. Below is the screenshot to show wireless G client not able to connect.
  • 2.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 02:12 AM
    What VLAN are you trying to put the device on?  Is that VLAN trunked to the AP?
  • 3.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 02:40 AM
    I have already trunked VLAN100 to the IAP115. Anything else should I take note?
  • 4.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 04:45 AM
    Is there a DHCP server on VLAN 100?  Is VLAN 100 defined in your SSID configuration?
  • 5.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 04:55 AM
    Yes, there is DHCP server on VLAN100. Those wireless client with the latest AC or AN, can connect with DHCP obtained without any problem. Only those wireless G client not able to connect.
  • 6.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 04:56 AM
    What does your SSID configuration look like?
    Did you configure anything under advanced or change anything from the defaults?
  • 7.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 05:15 AM
    Below is the configuration for the AP:
    version 6.3.1.0-4.0.0
    virtual-controller-country MY
    virtual-controller-key 8d94deab01d50fbdc429ad81667b485f7e1e7f7862d1f9017a
    name Instant-C3:B4:C0
    terminal-access
    ntp-server time.windows.com
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 18:64:72:c3:b4:c0
    allowed-ap 18:64:72:c3:b3:80
    allowed-ap 18:64:72:c3:b2:62
    arm
    wide-bands 5ghz
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin 12eef01369b39023b93ec21a7c225f411787138e35431e3f
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 1
    rule 10.10.1.215 255.255.255.255 match tcp 80 80 permit
    rule 10.10.1.215 255.255.255.255 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule "The Pines - Guest"
    index 2
    rule 192.168.10.254 255.255.255.255 invert icmp any any deny
    wlan access-rule "The Pines - Management"
    index 3
    wlan ssid-profile "The Pines - Guest"
    enable
    index 0
    type employee
    essid "The Pines - Guest"
    wpa-passphrase 57938b1efe50a445d7b5a72d9e258bbed7eb457a4d3a13b1
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan 100
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile "The Pines - Management"
    enable
    index 1
    type employee
    essid "The Pines - Management"
    wpa-passphrase 5f2673cb8bb6510edc2c07d8f58a513c9557bdab32266b3d
    opmode wpa2-psk-aes
    vlan 100
    rf-band all
    dtim-period 1
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    client-detection-level medium
    client-protection-level custom
    protect-valid-sta
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
    attack
    drop-bad-arp-enable
    poison-check-enable
  • 8.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 24, 2016 10:23 PM
    Maybe you should upgrade to the latest GA version?
    The client has a low signal strength
  • 9.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 27, 2016 10:14 PM
    Actually I have tried to upgrade the IAP 115 to the latest version GA, it is because I have upgraded the AP, only it has this issue. I tried to downgrade the IAP 115 again is to try if the issue still the same. In the end, it still the same. In further, I have found out that the latest GA version 2.4GHz frequency is not as strong as the previous firmware. Please advise.
  • 10.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 27, 2016 10:16 PM
    What are you using to measure "frequency"?
  • 11.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 04:07 AM
    I'm using mobile device to detect the 2.4GHz wireless frequency.
  • 12.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 04:24 AM
    Let's go back to the beginning:
    You said "I have IAP115 with the firmware version 6.4.2.6-4.1.1.8_50989, all wireless G mobile client not able connect to this AP. It was all perfect before I do firmware upgrade."
    To be clear, are you saying that NO wireless clients can connect since the upgrade, or just a specific wireless client?
  • 13.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 04:46 AM
    To be clear is only Wireless G client not able to connect, all those wireless AN or AC clients has no issue on connecting the AP. Wireless G client can connect to the IAP 115 before the firmware upgrade to the latest GA version.
  • 14.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 04:52 AM
    Only a single wireless G client or ALL wireless G clients?
  • 15.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 04:53 AM
    All Wireless G clients.
  • 16.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 05:09 AM
    Okay.  PM me your email address and I will send you the latest firmware we have.  AP-115s are approved for Malaysia country code, for what I can see.
  • 17.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 05:11 AM
  • 18.  RE: IAP 115 Wireless G client not able to connect
    Posted Mar 28, 2016 05:51 AM
    I have tried the latest code you provided, it works well. Thanks!
