IAP 135 Not working. Power LED solid RED continously !!!!
  • 1.  IAP 135 Not working. Power LED solid RED continously !!!!
    Posted May 30, 2014 01:00 AM
    I have a IAP 135 connected with controller 620. IAP is using POE on controller port 0. Console session of IAP it didnt show not even a single line.
    As the IAP gets power thorugh POE, power led get solid red and enet0 led is solid orange. This state does not change to someother state. I wait for almost half hour but couldnt get any response from the IAP.
    #AP135
  • 2.  RE: IAP 135 Not working. Power LED solid RED continously !!!!
    Posted May 30, 2014 02:23 AM
    You should raise a case with support, it sounds like an RMA.  Have you tried to put the ap in a different port?
