I could use some input for the following scenario:
IAP-135, open network, no external splash page server etc.
Is there a way to redirect wifi clients to a web page once connected?
Thanks in advance for any advice.
You could use the built in captive portal with an acknowledge page. You have to use some type of captive portal to inject a redirect after connection.
Thanks for your reply. I saw this. I can upload a small logo but other than modifying the text, is there a way to customize the generic looking text boxes that display before the redirect? It appears that this can be done when using a controller but I haven't seen documentation on changing this on an IAP.
Thank you.
cls
that is because it is not possible on an IAP, it is one of the limitations.
