IAP-175 5Gig radio is not coming up
  • 1.  IAP-175 5Gig radio is not coming up
    Posted Oct 14, 2015 12:46 AM
    Dear Concern,
                           I have IAP 175.I have mounted both antena types R0 and R1 correctly on IAP 175.But R0(5Gig)  is not coming up.(Its red light no blue blinking).Is there any thing i need to do in IAP configuration to enable 5Gig antennas.
  • 2.  RE: IAP-175 5Gig radio is not coming up
    Posted Oct 14, 2015 12:56 AM
    Is this a wired IAP?
    What version of software?
    Is a dual-band SSID configured?
    Does the AP have 802.3at power supplied?
  • 3.  RE: IAP-175 5Gig radio is not coming up
    Posted Oct 14, 2015 01:19 AM
    yes
    ArubaOS Version 6.2.1.0-3.4.0.6
    I didn't see this option while configuring IAP SSID.(Let me check this again).
    yes
  • 4.  RE: IAP-175 5Gig radio is not coming up
    Posted Oct 14, 2015 08:32 AM
    Is it part of an existing VC/IAP Cluster?
    Just make sure the SSID configured is for both bands. Also, what country is this for?
  • 5.  RE: IAP-175 5Gig radio is not coming up
    Posted Oct 15, 2015 12:22 AM
     Its standalone IAP.No cluster.I am setting it up single IAP.
    SSID configured with band option ALL selected(dual band SSID).
    Regulatory domain is GB.
  • 6.  RE: IAP-175 5Gig radio is not coming up
    Posted Oct 15, 2015 09:21 AM
    I would hit up TAC and let them look at it then, there's no reason the 5GHz radio on a wired IAP wouldn't come up unless there are other facotrs at work, config or some other reason that just isn't jumping out.
