IAP-175 external antenna configurations
  • 1.  IAP-175 external antenna configurations
    Posted Apr 18, 2014 06:14 AM
    The access point models with external antennal, for example IAP-104, we have to configure the ap's antennas 6 db for 2.4 gHz and 5 db for gHz. Do we need to do the same with IAP-175(in fact external antenna settings is independant from being Instant or Campus for the ap)? Are the gain values in dB are same with the 104 model?
  • 2.  RE: IAP-175 external antenna configurations
    Posted Apr 18, 2014 07:04 AM
    The gain values depends on the antennas i think. Not on the APs. So if you use the same antennas, you have to use the same gain values. But another one should confirm this.
    Greetings
  • 3.  RE: IAP-175 external antenna configurations
    Posted Apr 18, 2014 07:10 AM
    Hi Gordon,
    Thanks for your reply. The antennas are omni directional antennas. Antennas are 2005 for 2.4 gHz band and 5005 for 5 gHz band. If I'm not wrong the last digit at those numbers indicates the gain of antennas.
  • 4.  RE: IAP-175 external antenna configurations
    Posted Apr 18, 2014 07:18 AM
    Yes, I'm using the 2x2-D805 and the last digit indicates the gain value too. The datasheet of your antennas tell me that you have the same value (5005: 4.9–5.875GHz(5dBi), 2005: 2.4 – 2.5 GHz (5 dBi))
  • 5.  RE: IAP-175 external antenna configurations
    Posted Apr 18, 2014 07:24 AM
    Then I have to enter 5 dB for both type of antennas from the interface to configure the external antennas right?
  • 6.  RE: IAP-175 external antenna configurations
    Posted Apr 19, 2014 12:04 PM
    Yes, you're right!
