IAP-205 802.1x login issues, getting message about securelogin.arubanetworks.com
  • 1.  IAP-205 802.1x login issues, getting message about securelogin.arubanetworks.com
    Posted Jan 14, 2015 10:08 AM
    Customer has a network of IAP-205s with 802.1x radius auth setup on a server 2003 domain controller. initially this was setup, tested and domain machines/users could connect fine. Recently when the customer started to connect new users he is getting a popup (see attachment) and unable to successfully authenticate. There is a certificate installed on the Radius server per its setup. As far as settings on the ssid, it is network assigned for IP addresses, wpa2-enterprise with Termination enabled. Thoughts on why this would occur?
    Attachment(s)
    docx
    8021xpopup.docx   51 KB 1 version
  • 2.  RE: IAP-205 802.1x login issues, getting message about securelogin.arubanetworks.com
    Posted Jan 14, 2015 10:11 AM
    The popup is a normal part of the EAP process.The only way to elminate this is to manually configure the device or use a configuration utility like QuickConnect or GPO.
  • 3.  RE: IAP-205 802.1x login issues, getting message about securelogin.arubanetworks.com
    Posted Jan 14, 2015 10:13 AM
    Weird, i tried to recreate pretty much the same scenario in my lab using an IAP 135 but do not get this popup.
  • 4.  RE: IAP-205 802.1x login issues, getting message about securelogin.arubanetworks.com
    If there is a certificate on the radius server, termination should be disabled...
