IAP 205 and IAP 204 in one cluster
  • 1.  IAP 205 and IAP 204 in one cluster
    Posted Feb 17, 2016 07:47 AM
    Hello everybody
    Is it possible to have two different models of IAP in the same cluster of IAP's?
    For example if I want to configure some IAP 205 and some IAP 204 in the same cluster, will I get problems if I do this?
    Thanks for your help
  • 2.  RE: IAP 205 and IAP 204 in one cluster
    Posted Feb 17, 2016 07:52 AM
    No problems.  You should be fine.  They even use the same version of code.  You would have to configure the antenna gain for the IAP-204s  (external antenna model) manually before they put out any RF, however....
  • 3.  RE: IAP 205 and IAP 204 in one cluster
    Posted Feb 17, 2016 08:27 AM
    Thank you very much! This helps me alot.
  • 4.  RE: IAP 205 and IAP 204 in one cluster
    Posted Feb 17, 2016 08:45 AM
    Would a IAP 270 also be compatible with the IAP 205 and 204 in one cluster?
  • 5.  RE: IAP 205 and IAP 204 in one cluster
    Posted Feb 17, 2016 09:05 AM
    Yes.
  • 6.  RE: IAP 205 and IAP 204 in one cluster
    Posted Feb 17, 2016 09:44 AM
    One of our customers used four different types of IAP in a single cluster (IAP-10x, IAP-13x, IAP-20x and IAP-2[2;7]0).
    Just be careful with the upgrades because the process is far from being dummy proof.
