iap-205 arubacentral activation
  • 1.  iap-205 arubacentral activation
    Posted Sep 02, 2015 06:44 PM
    Have an IAP-205, which connects to the public internet.
    I can also log in to ArubaCentral, no problem. However when I go to add a device, I enter the Cloud Activation key and the MAC address of my AP. It says device activation successful but nothing happens after that.
    I can navigate to Wireless Config --> Access Points, but see no APs there.
    Advice appreciated, thanks!
  • 2.  RE: iap-205 arubacentral activation
    Posted Sep 03, 2015 11:44 AM
    Do you have a license installed on Central?
  • 3.  RE: iap-205 arubacentral activation
    Posted Sep 03, 2015 12:30 PM
    I found the section for adding a subscription key.
    It's been added, so we'll see if that works (Central now shows device sync is pending, so I need to wait up to 24 hours) :-/
  • 4.  RE: iap-205 arubacentral activation
    Posted Sep 03, 2015 01:13 PM
    Seems like some issue happening in backend system. Can you please open a case with our Tech Support team?
    Even if you have EVAL account, they should be able to help you.
    -Alap
