IAP-205 boot in old firmware after upgrade
  • 1.  IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 07:21 AM
    i'm try to upgrade one of iap-205-rw but after reboot iap boot in to old firmware.
    sh ver
    ArubaOS (MODEL: 205), Version 6.4.2.6-4.1.1.6
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-05-12 at 10:27:51 PDT (build 50009) by p4build
    sh image
    Primary Partition Build Time :2015-05-12 10:27:51 PDT
    Primary Partition Build Version :6.4.2.6-4.1.1.6_50009
    Backup Partition Build Time :2017-03-2 04:25:52 PST
    Backup Partition Build Version :6.5.1.0-4.3.1.2_58595
    Try to switch-partition-reboot:
    Reboot Time and Cause: AP rebooted Thu May 4 11:06:33 UTC 2017; CLI cmd at uptime 0D 0H 6M 40S: switch-partition-reboot
    But iap still load 6.4.2.6. I'm try 6.4.4.8, 6.5.1.0.
    Iap allso don't convert into standalone ap.
  • 2.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 07:59 AM
    Did you try any other version of Instant for the upgrade?
  • 3.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 09:03 AM
    We try:
    ArubaInstant_Taurus_6.5.1.0-4.3.1.2_58595
    6.4.4.8-4.2.4.6_58505 (manual and auto upgrade from web interface)
    ArubaInstant_Taurus_6.4.2.6-4.1.3
  • 4.  RE: IAP-205 boot in old firmware after upgrade
    MVP EXPERT
    Posted May 04, 2017 09:08 AM
    Are you trying  to upgrade a single IAP in a cluster or is this a single IAP which is not in a cluster?
  • 5.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 09:26 AM
    We have 4 new point.
    First ap was upgrade on new firmware and configured, then we add points to cluster. For the first time this AP was added to cluster, but then she down from claster. I think cuz fail firmware upgrade.
    If she boot first, other point's can't join claster.
    Then we try to upgrade this ap without cluster.
    AP was cleared to default settings, write erase all and from web interface.
    Ap don't  convert to standalone ap.
  • 6.  RE: IAP-205 boot in old firmware after upgrade
    MVP EXPERT
    Posted May 04, 2017 09:59 AM
    Are all of the IAP's the 205 model? It sounds like the cluster is split between old and new firmware. Do you see anything in the logs when the upgrade fails or when it fails to reboot as a standlone AP?
  • 7.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 10:06 AM
    All ap was same model and firmware. 3 ap work in cluster propertly.
    We don see anything in logs. AP upload firmware successfully go to reboot and boot with old firmware. Now all operation was with single ap.
  • 8.  RE: IAP-205 boot in old firmware after upgrade
    MVP EXPERT
    Posted May 04, 2017 10:11 AM
    If you can, could you post the tech-support? (Remove any private info if needed :) )
  • 9.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 10:18 AM
    In attachment.
    Attachment(s)
    txt
    aruba-support.txt   238 KB 1 version
  • 10.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 10:51 AM
    Is it possible to take console access to this IAP & run the following command from apboot
    apboot> factory_reset
    apboot>save
    apboot> boot
    If possible , put this IAP in a different vlan at time of testing & then try the upgrade process.
  • 11.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 11:05 AM
    We try to find console cable.
    The AP single in broadcast domain for most time that we try to fix it.
  • 12.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 11, 2017 06:50 AM
    With console cable AP say crc error on main partition image.
    Send AP back to reseller.
  • 13.  RE: IAP-205 boot in old firmware after upgrade
    Posted May 04, 2017 09:16 AM
    Reboot Time and Cause: AP rebooted Thu May 4 13:08:25 UTC 2017; Image Upgrade Successful
    34:fc:b9:c0:b8:82# sh image
    Backup Partition Build Time :2016-12-7 02:12:08 PST
    Backup Partition Build Version :6.4.2.6-4.1.3.4_57646
    sh version
    AP uptime is 1 minute 25 seconds
    Reboot Time and Cause: AP rebooted Thu May 4 13:11:52 UTC 2017; CLI cmd at uptime 0D 0H 1M 24S: switch-partition-reboot
    Same result(
