iap-205 does not give out ip's
  • 1.  iap-205 does not give out ip's
    Posted Apr 28, 2015 09:57 AM
    I am gettign into aruba now and have 11 iap-205's setup
    every once in a while I get calls about limited connectivity, adn when I look in the controller devices connected to an AP have a 169 ip whic means it did not get to the dhcp to get the address
    to fix this condition I simply reboot the ap and everything is good for a bit, this happens about once a week on about 2 of my 11 AP's that I currently have
  • 2.  RE: iap-205 does not give out ip's
    Posted Apr 28, 2015 10:00 AM
    What type of VLAN is it? Network assigned, Magic VLAN? Are you doing DHCP on the IAP or allowing a dedicated DHCP server to assign IPs? How many clients are connected to the network, and how large is the subnet they are assigned to?
    When clients have this issues, is it all clients ,or just a few in one area?
  • 3.  RE: iap-205 does not give out ip's
    Posted Apr 28, 2015 10:04 AM
    the vlan is network assigned and works 100% if I use a network cable and plug ito the same vlan and get the proper ip's
    I have a deditcated dhcp server for this vlan
    currently 32 people are connected to the aruba wifi network
    the subnet is a /24 and ip's are available
    this happens per ap, if I take an affected laptop down the hall it will connect to a different ap and get the proper ip and all is good
    thanx for the help
  • 4.  RE: iap-205 does not give out ip's
    Posted Apr 28, 2015 10:11 AM
    When it is happened you can try to enabled a pcap on the device and see whats going on:
    # debug pkt type dhcp
    # debug pkt dump
    This should dump all DHCP packets to the SSH session. if you want to capture all packets on the radio until the issue happens you can try a pcap to a machine running wireshark
    # pcap start 33:33:33:33:33:33 1.1.1.1 5555 0 5000
    Replace 33:33:33:33:33:33 with the MAC of the bss you want to capture. Run # show ap bss-table to find the MAC you want to capture. Replace 1.1.1.1 with the IP of the machine running wireshark.
    This might tell you if the packets are being sent into the network, or not even being received by the AP.
    Are you running a new version of code? might be worth upgrading/checking release notes for DHCP fixes if you are on an older code version.
  • 5.  RE: iap-205 does not give out ip's
    Posted Apr 28, 2015 10:23 AM
    I have an out put of the dhcp request and reply from a work dhcp request
    when it happens again I will do the same and compare and will update this ticket then
    thanx
  • 6.  RE: iap-205 does not give out ip's
    Posted Apr 29, 2015 12:02 PM
    so I ran those commands on an AP that this morning just stopped giving out ips
    this is the output when the ap is working properly
    dhcp: message-type: request
                 hardware type: 1, len: 6, hops: 0
                 txn id: 0x35f0168b, seconds elapsed: 0
                 client mac: 58:94:6b:f8:c6:d4
                 magic cookie: 0x63825363
          #dhcp-option: requested-ip: 172.29.102.78
          #dhcp-option: message-type: request
          #dhcp-option: dhcp-server: 172.29.100.101
    and here is the output when the AP isn't giving out addresses
    #dhcp: message-type: request
                 txn id: 0x4ce48aaa, seconds elapsed: 0
                 boot flags: 0x8000
                 client mac: 48:51:b7:23:1d:1a
          #dhcp-option: requested-ip: 172.29.102.148
    the only difference is that when the ap stops giving out ip's the DHCP request is missing this line  #dhcp-option: dhcp-server: 172.29.100.101 which is the ip of the dhcp server
    if I restart the ap that is having issues it will show a good dhcp request for a while but will eventually go back this state
    thanx
  • 7.  RE: iap-205 does not give out ip's
    Posted May 01, 2015 10:41 AM
    the ap had 3 people on it with valid ip's and a new pc was trying to get onto the same AP
    th enew pc was just getting an 169 address as it can't reach the dhcp server
    a restart of the ap and the device connects fine
    is there still no reason for this issue, seems to be happening to 1 or 2 out of 11 ap's
    are these just broken units, they all connect to the same switch and access the same dhcp server
  • 8.  RE: iap-205 does not give out ip's
    Posted May 08, 2015 07:10 AM
    What version of code are on your IAP-205s?
  • 9.  RE: iap-205 does not give out ip's
    Posted Aug 15, 2015 02:20 PM
    Hi - We have just implemented 12 iaps and this has happened 3 times now in 3 weeks, it's exactly the same issue as described above, is there a solution for this? A reboot of the affected iap restores connection but it's just not good enough for a brand new system.
  • 10.  RE: iap-205 does not give out ip's
    Posted Aug 15, 2015 02:22 PM
    What version of code is this?
  • 11.  RE: iap-205 does not give out ip's
    Posted Aug 17, 2015 03:04 AM
    Hi Colin,
    It's 6.4.2.0-4.1.1.0_46028.
  • 12.  RE: iap-205 does not give out ip's
    Posted Aug 17, 2015 06:52 AM
    iAP205,
    Please consider upgrading to 4.1.1.7 or 4.1.1.8.  There are alot of fixes that went in, that might solve your problem.
  • 13.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 01:04 PM
    I have the same issue, where do I find this firmware upgrade?
  • 14.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 01:07 PM
    http://support.arubanetworks.com/
    You need to have a support account, and then under Software you can find the Aruba Instant code.
  • 15.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 01:35 PM
    I guess I have to wait to register:
    Support Portal Error
    A critical error has occured in the system. While the IT is looking into it, Please close your browser and try logging after sometime.
  • 16.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 01:37 PM
    Try the link provided by cjoseph, it should allow you to download the firmware without having to login.
  • 17.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 04:02 PM
    I am currently running 6.4.2.3-4.1.1.3 on 15 APs. The one available on the link provided by Joseph is 6.4.2.6-4.1.1.13. To be sure, this is compatable with my IAP-205s?
  • 18.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 04:10 PM
    With thi IAP-205s - I use the Taurus???
  • 19.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 04:15 PM
    yes
  • 20.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 04:21 PM
    Thanks CJoseph, just to make sure. You said yes to both the compatablility, and that I use Taurus, correct?
    Thanks for your time.
  • 21.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 04:23 PM
    Yes and Yes.
  • 22.  RE: iap-205 does not give out ip's
    Posted Jan 12, 2017 11:34 AM
    I went through the procces of the upgrade and it was "Upgrading" for several hours. I left work and returned to find the original firmware still in place. Any advice?
  • 23.  RE: iap-205 does not give out ip's
    Posted Jan 12, 2017 11:45 AM
    What is the filename of the firmware?
    Did you use the GUI?
    Please try from a wired workstation, if you can...
  • 24.  RE: iap-205 does not give out ip's
    Posted Jan 12, 2017 12:05 PM
    I used Arubainstant_Taurus_6.4.2.6-4.1.1.13_54918 with the GUI from a a non-wired workstation. Will attempt again at 3pm from a wired workstation if you say this is the correct file. Have to wait until school is out, so there are no interuptions. Thanks.
  • 25.  RE: iap-205 does not give out ip's
    Posted Jan 12, 2017 12:19 PM
    If you can, please compute the Md5 sum to make sure you got the file and it is not corrupted.  Download the Aruba.sha256 file and open it in notepad.  Compare the md5sum for the device downloaded to the md5sum in the file by using an md5sum checker:
  • 26.  RE: iap-205 does not give out ip's
    Posted May 17, 2017 06:33 PM
    I am still having the same issue weekly with all 15 of my IAPs. I have been keeping track of firmware upgrades and installing them as they are available. Currenty running ArubaInstant_Taurus_6.5.2.0_59123... Any new advice?
  • 27.  RE: iap-205 does not give out ip's
    Posted May 17, 2017 07:01 PM
    Can you identify the ap and get the tech support from it?
  • 28.  RE: iap-205 does not give out ip's
    Posted May 17, 2017 07:40 PM
    It's all the APs..
  • 29.  RE: iap-205 does not give out ip's
    Posted May 17, 2017 07:44 PM
    None of the APs give out IP addresses at the same time? Are the VLANs virtual controller assigned or network assigned in those SSIDs?
  • 30.  RE: iap-205 does not give out ip's
    Posted May 18, 2017 02:08 PM
    Network assigned
  • 31.  RE: iap-205 does not give out ip's
    Posted Sep 07, 2017 12:07 PM
    Was this problem ever resolved?  I am having the same issue.  Need help!  I have both IAP 135 's and IAP 205's.  Current firmware shows:  64264116-5009.  I have learned this only occurs with Windows 7 workstations.  Unfortunately, both my labs are still Windows 7.
  • 32.  RE: iap-205 does not give out ip's
    Posted Sep 07, 2017 02:41 PM
    Yes, please upgrade to latest conservative release 4.2.4.8. or 6.5.3.2.
    Pash
  • 33.  RE: iap-205 does not give out ip's
    Posted Sep 07, 2017 02:43 PM
    Will that work for both the IAP 135 and the IAP 205?  I don't want to comepletely break my wireless network.
  • 34.  RE: iap-205 does not give out ip's
    Posted Sep 07, 2017 02:46 PM
    Looks like IAP-135 onl supports up to Instant code 4.2, so this wont work
    http://www.arubanetworks.com/support-services/end-of-life/
    _ELiasz
  • 35.  RE: iap-205 does not give out ip's
    Posted Sep 08, 2017 09:54 AM
    4.2.4.8 will work for both
  • 36.  RE: iap-205 does not give out ip's
  • 37.  RE: iap-205 does not give out ip's
    Posted Sep 11, 2017 04:35 PM
    Can you please send link to download that version please?
  • 38.  RE: iap-205 does not give out ip's
    Posted Jan 11, 2017 01:17 PM
    You can just choose the latest GA or EA code here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=21997
