iap 205 getting error limited connectivity
  • 1.  iap 205 getting error limited connectivity
    Posted Oct 07, 2017 12:38 PM
    hi
    i have 3 205 iap which connected together we have 5 hp switch single network no vlan am getting error limited connectivity also all lan user getting Aruba ssid name on lan connection what will be the problem we are using sonic wall firewall for dhcp
  • 2.  RE: iap 205 getting error limited connectivity
    Posted Oct 07, 2017 03:13 PM
    Is the VLAN under your SSID "virtual controller assigned" or "network assigned"?
  • 3.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 03:01 AM
    network assigned  ip address assgin by sonicwall dhcp
  • 4.  RE: iap 205 getting error limited connectivity
    MVP EXPERT
    Posted Oct 08, 2017 03:49 AM
    Is your Sonic Wall configured with the VLAN's for the SSID? What happens if you plug a wired client into a switch port on the same VLAN, do they obtain an IP address? Is the default gateway for the clients not the Sonic Wall, in that case do you need an ip-helper?
  • 5.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 04:20 AM
    it is single vlan lan and wan
    yes
    sonicwall we set default gateway
  • 6.  RE: iap 205 getting error limited connectivity
    MVP EXPERT
    Posted Oct 08, 2017 04:32 AM
    I expect the issue is with your VLAN tagging. Are all the same VLAN's being used for IAP, Sonic Wall and the SSID in question? The IAP traffic will be untagged and the client traffic will be tagged.
    Try setting your Client IP Assignment to Virtual Controller Managed as a test.
  • 7.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 06:39 AM
    yes we are using same vlan for wifi and lan
    if assign virtually control managed ip that will create different range ip that will think that will cause problem for active directory sync
  • 8.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 07:58 AM
    Do you have the VLAN set to 1?
  • 9.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 09:24 AM
    Client ip assigned  network assigned
    Client vlan assignment  default  i think  it should be vlan 1
    it showing like  this   vlan  --    ?
    am not sure it is vlan 1
  • 10.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 09:32 AM
    Do you have clients assigned to a role that is firewalling traffic?  You need to allow dhcp if that is the case, or remove all restrictions on client traffic.
  • 11.  RE: iap 205 getting error limited connectivity
    Posted Oct 08, 2017 09:44 AM
    Access rolls unrestricted
