IAP-205 , IAP-305 Firmware check error
  • 1.  IAP-205 , IAP-305 Firmware check error
    Posted Jun 04, 2019 09:19 AM
    I usually check for firmware update once a week. This week I am no longer able to check for firmware updates.
    Error message:
    image_check_internal error 001 code 002
    Generic searches, aruba and airheads searches not coming back with much on the error codes . Current firmware level 6.5.4.12_68901
  • 2.  RE: IAP-205 , IAP-305 Firmware check error
    Posted Jun 08, 2019 06:37 AM
    I have the same problem on iap-315 running airos 8.3.0.6
  • 3.  RE: IAP-205 , IAP-305 Firmware check error
    Posted Jun 18, 2019 10:47 AM
    found this from cjoseph on another thread (https://community.arubanetworks.com/t5/Wireless-Access/Aruba-305-check-for-new-version-error-Image-check-internal-error/td-p/539912):
    "This is a backend error.  It means that there is no firmware upgrade available and it is not handled correctly by the access point.  For now assume it means there is no firmware upgrade.
    I will re-post when it is fixed."
