IAP 205 issue
  • 1.  IAP 205 issue
    Posted Nov 02, 2015 07:25 AM
    Hi All,
    I am having strange issue with IAP 205H. Someone please give me some defintive answer.
    Previously i configured 205H with a DHCP server, i was able to access the instant webpage and configured a new SSID Employee (for testing purpose). I turned it off
    Today i turned it on
    1. i dont see any SSID Employee or Instant
    2. The led status is Amber
    3. After sometime (usually 10 minutes or so), the status changes to blinking green (restarting ??) and then to Amber and cycle continues
    Is there a problem with 205H in general ? is there a bug ?
    After i configure the new SSID, and restart it, will it not retain the configuration ?
  • 2.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:32 AM
    Did you re-IP the IAP as well?
  • 3.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:34 AM
    No, i didnt gave the IP manually, is that the cause the configuration was not saved ?
  • 4.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:37 AM
    I think you will need to set the virtual controller address first.
  • 5.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:38 AM
    But why its restarting again n again ?
  • 6.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:39 AM
    is it a bug or just how IAP works ?
  • 7.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:41 AM
    Have you had a chance to console into the IAP to see what exactly is going on?
  • 8.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:52 AM
    Nope, dont have the console cable :(
    The console cable is quite different :(
  • 9.  RE: IAP 205 issue
    Posted Nov 02, 2015 07:53 AM
    But still i am not getting answer to whether this is a required behaviour from 205H ? seems faulty and buggy to me !!
  • 10.  RE: IAP 205 issue
    Posted Nov 02, 2015 08:09 AM
    Hi all,
    I tried factory resetting it, this is what i did
    1. turned off the AP
    2. press the reset button
    3. turned on the AP
    4. it started flashing,
    5. released the reset button
    6. same process as previous, i dont see any instant SSID !!!!
    What is the problem ???
  • 11.  RE: IAP 205 issue
    Posted Nov 02, 2015 08:24 AM
    Can someone please guide me how to open tac case ?
  • 12.  RE: IAP 205 issue
    Posted Nov 02, 2015 09:19 AM
    Ovais,
    Are you supplying DHCP to that instant AP?
  • 13.  RE: IAP 205 issue
    Posted Nov 02, 2015 09:21 AM
    i tried doing that as well but no use :(
    Strange thing is, its not broadcasting the instant ID even i factory reset it,
    can someone please help me understand why its not broadcasting the instant SSID ?
  • 14.  RE: IAP 205 issue
    Posted Nov 02, 2015 09:24 AM
    Are you sure it is getting a DHCP ip address?  What is supplying DHCP? Did you wait 6 minutes?  What is the color of the lights?
  • 15.  RE: IAP 205 issue
    Posted Nov 02, 2015 09:26 AM
    Its not getting the IP.
    The light remains Amber :-( and then restarts like i said
  • 16.  RE: IAP 205 issue
    Posted Nov 02, 2015 09:29 AM
  • 17.  RE: IAP 205 issue
    Posted Nov 02, 2015 09:36 AM
    Send an email to support@arubanetworks.com
