IAP-205 not upgrading firmware
This thread has been viewed 16 times
  • 1.  IAP-205 not upgrading firmware
    Posted Mar 23, 2020 07:53 AM
    Hi all,
    In order to integrate a new 305 IAP in my IAP cluster I wanted to upgrade the existing IAP103 and 205 to the 6.5.4.3 release.
    First i entered the paths to the file in the web frontend and tried to upgrade - worked fine for the AP-103 but not for the 205. The 305 was added successfully but the 205 wont show up anymore.
    I sshd into the ap and tried to upgrade via cli
    "upgrade-image ftp://ip_of_my_ftp/ArubaInstant_Taurus_6.5.4.3_61959"
    which is commented with "uprading swarm image - Will automatically reboot when done"
    After that message nothing is happening anymore. I tried a debug-download and everything is fine - i see also the anonymous access on my ftp log when doing that debug command.
    checking my ftp logs when i do the upgrade-image command shows no ftp access to my server.
    can i copy the image file to the ap manually anyhow? do you have any other suggestions?
    Your help would really be appreciated!
    Peter
  • 2.  RE: IAP-205 not upgrading firmware
    MVP EXPERT
    Posted Mar 23, 2020 08:34 AM
    What do you see in the IAP upgrade logs?
    show log upgrade
    Are you using the firmware version specific to the IAP-205? As you can see from the below the firmware image used by the 205 is different from a 305 and also the 103.
    AP Class
    AP models
    Aries
    RAP-155 and RAP-155P
    Centaurus
    IAP-224, IAP-225, IAP-214/215, IAP-274, IAP-275 and IAP-277
    Draco
    AP-344/345 and AP-514/515
    Gemini
    AP-504/505
    Hercules
    IAP-314/315, IAP-324/325, AP-318 and AP-374/375/377/387
    Lupus
    IAP-334/335
    Scorpio
    IAP-555, IAP-535/534
    Ursa
    AP-303/303P/303H, IAP-304/305 and AP-365/367
    Vela
    AP-203H, AP-203R, IAP-203RP and IAP-207
    Pegasus
    RAP-108, RAP-109, IAP-114, IAP-115 and IAP-103
    Taurus
    IAP-204/205, IAP-205H
    Cassiopeia
    IAP-134 and IAP-135
    Orion
    IAP-104, IAP-105, IAP-175, RAP-3WN and RAP-3WNP
    You can always isolate the IAP-205 its own VLAN, upgrade then re-introduce in to the cluster which is already running the firmware you require.
  • 3.  RE: IAP-205 not upgrading firmware
    Posted Mar 23, 2020 08:43 AM
    thanks for your prompt response - i attached the output of the show log upgrade command.
    I use the Taurus image - should be fine afaik
    Separating in an own vlan would be my last choice cause that would mean lots of work as the network is my homenetwork and is flat
    Peter
  • 4.  RE: IAP-205 not upgrading firmware
    Posted Mar 23, 2020 10:08 AM
    Did manage to get things in order - had to disconnect all APs despite the 205, resetted to factory defaults, then managed to upgrade to latest firmware.
    After that took the 205 offline and the other aps online again at last the 205 and surprise there it was
    thx for help anyway!
    br
    Peter
