IAP-205 packet loss
  • 1.  IAP-205 packet loss
    Posted Jul 06, 2016 09:05 AM
    I bought an IAP-205 for our office and for WIFI (read: web browsing) access in general it works fine and the connection is stable. However, we have this gaming tradition on fridays where the office joins in for some fun. Since we got the IAP we've got quite big packet loss and the connection is quite unstable, unplayable at times. The issue is there when we do normal LAN gaming (not over the Internet) which leads me to believe it's something to do with the access point. It doesn't seem to matter if we're on 5 or 2.4 GHz, and connection protocol (n or ac) don't make a difference either. In the administration interface it says that all signals are strong and that there are no issues with the WIFI.
    How can i debug this? Is there any idea or pointer as to what might be wrong?
    Thanks a lot!
  • 2.  RE: IAP-205 packet loss
    Posted Jul 06, 2016 09:12 AM
    You have broadcast filter ARP enabled on your ssid?
  • 3.  RE: IAP-205 packet loss
    Posted Jul 06, 2016 09:14 AM
    I suppose so, "Broadcast filtering" is set to "ARP"
  • 4.  RE: IAP-205 packet loss
    Posted Jul 06, 2016 11:41 AM
    What version of Aruba Instant?
    How many clients on that access point?
  • 5.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 04:04 AM
    There are 5 clients right now. 2 of them are kind of active, but basically mail and browsing
    Version: 6.4.2.6-4.1.1.11_52666
  • 6.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 04:07 AM
    Can you do a constant ping to your default gateway?
    How many SSIDs are there?
  • 7.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 04:08 AM
    Do you mean SSIDs in general in the air where i am, or that the IAP has?
  • 8.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 04:26 AM
    My SSID is "MP", and it's the only one the IAP provides
    --- 192.168.0.1 ping statistics ---
    912 packets transmitted, 912 packets received, 0.0% packet loss
    round-trip min/avg/max/stddev = 1.246/4.174/361.904/16.395 ms
    $ /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport -s
    SSID BSSID RSSI CHANNEL HT CC SECURITY (auth/unicast/group)
    comhem_EAD3D4-5G dc:53:7c:e5:95:6b -68 100 Y DE WPA2(PSK/AES/AES)
    VaktNet e8:cc:18:60:d7:bd -69 11 Y -- WPA(PSK/TKIP,AES/TKIP) WPA2(PSK/TKIP,AES/TKIP)
    comhem_EAD3D4 dc:53:7c:e5:95:6a -64 11 Y -- WPA2(PSK/AES/AES)
    Buster 90:72:40:21:f3:d2 -63 6 Y SE WPA2(PSK/AES/AES)
    DIRECT-e0-HP M277 LaserJet 46:1c:a8:05:9e:e0 -67 6 Y -- WPA2(PSK/AES/AES)
    Siman, Simon's Guest Network 06:25:bc:88:bf:2d -74 1 Y SE WPA(PSK/TKIP/TKIP) WPA2(PSK/AES,TKIP/TKIP)
    LN Production 00:25:bc:88:bf:2d -73 1 Y SE WPA(PSK/TKIP/TKIP) WPA2(PSK/AES,TKIP/TKIP)
    comhem_A694F7 dc:53:7c:98:53:68 -85 1 Y -- WPA2(PSK/AES/AES)
    Siman, Simon's Guest Network 06:25:bc:88:bf:2e -76 44,+1 Y SE WPA(PSK/TKIP/TKIP) WPA2(PSK/AES,TKIP/TKIP)
    LN Production 00:25:bc:88:bf:2e -76 44,+1 Y SE WPA(PSK/TKIP/TKIP) WPA2(PSK/AES,TKIP/TKIP)
    Buster 90:72:40:21:f3:d3 -80 36 Y SE WPA2(PSK/AES/AES)
    MP f0:5c:19:01:72:70 -50 60,+1 Y SE WPA2(PSK/AES/AES)
  • 9.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 04:32 AM
    Are you having performance issues on that client right now?  Typically it is easy to show performance issues with dropped pings.
  • 10.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 11:03 AM
    I'm having performance issues right now, but i don't seem to get dropped pings
  • 11.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 11:07 AM
    Performance with what application?
  • 12.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 11:09 AM
    I'm just CLI pinging my ISP gateway and one of these gaming servers we connect to. I get stable ping and no dropped packets, BUT, if i connect to the server it's unstable hell more or less
    Gateway:
    289 packets transmitted, 289 packets received, 0.0% packet loss
    round-trip min/avg/max/stddev = 3.431/10.838/399.446/23.050 ms
    Gaming server:
    288 packets transmitted, 288 packets received, 0.0% packet loss
    round-trip min/avg/max/stddev = 17.158/22.514/30.322/2.239 ms
  • 13.  RE: IAP-205 packet loss
    Posted Jul 07, 2016 11:17 AM
    Have you tried to do anything else like surf the internet or a speed test?  Try other applications...  Typically if the client can reach the default gateway and ping that, it verifies the quality of the wireless network.  Do you have any bandwidth throttling configured on that user on the IAP?
  • 14.  RE: IAP-205 packet loss
    Posted Sep 02, 2016 08:54 AM
    The problem has persisted just that i haven't prioritized it. I tried another access point now to the same network so one client was on the IAP and the other on another one. The IAP client had the same type of issues as previously described, but the other one had no issues. When the other client also was on the IAP, it had the same issues.
    I can't find a lot of information about this but it would be really nice if somebody could shed some light on what could be wrong. It's like waves of packet loss and high ping that appears about every second minute, so it's not a steady packet loss.
  • 15.  RE: IAP-205 packet loss
    Posted Sep 02, 2016 09:15 AM
    There are quite a few reasons why this could be happening.  Someone like like should look over your tech support and your network diagram and narrow it down.  It would be too hard to guess with the limited information provided on the forum.
