IAP 205 Reboot information
  • 1.  IAP 205 Reboot information
    Posted Mar 12, 2018 04:00 PM
    We have a client with 13 IAP 205 FW: 6.5.2.0_59123.
    At varius days the system reboot without cause apparently. When go to CLI and show ap debug system-status we obtain this information about reboot:
    Reboot Information   (Master controller)
    AP rebooted Mon Mar 12 17:07:52 UTC 2018; UI cmd at uptime 6D 22H 44M 11S: reload all
    Reboot Information   (other IAP)
    AP rebooted Mon Mar 12 17:07:43 UTC 2018; VC cmd at uptime 32D 0H 22M 55S: UI cmd at uptime 6D 22H 44M 11S: reload all
    AP rebooted Mon Mar 12 17:07:45 UTC 2018; VC cmd at uptime 26D 0H 23M 40S: UI cmd at uptime 6D 22H 44M 11S: reload all
    How to interpret? What is the cause of reboot? Who initiated?
  • 2.  RE: IAP 205 Reboot information
    Posted Mar 12, 2018 04:25 PM
    Are you using Airwave to configure your instant cluster?
  • 3.  RE: IAP 205 Reboot information
    Posted Mar 13, 2018 07:51 AM
    No, I don't use Airwave.
    Iwant to interpret the information about "Reboot".
    It's a reboot from the IAP master and it's launched by an admin from UI?
  • 4.  RE: IAP 205 Reboot information
    Posted Mar 13, 2018 05:28 PM
    Reboot reason 'reload all' means that someone (or something) triggered a reboot by typing the command 'reload all'. Likely pressing the reboot button in the WebUI triggers this command in the background.
