IAP-205-RW vs IAP-205-US
  • 1.  IAP-205-RW vs IAP-205-US
    Posted Jan 26, 2016 12:56 PM
    Hi All,
    I've got 2x IAP-205-RW installed aboard a ship.
    We are doing cruises in both US and Europe.
    Want to buy and install more IAPs.
    In US IAP-205-US (restricted) is cheaper than RW version.
    I found that on US ones ch. 13,14 will be missing.
    What other differencies between them?
    Can I use US version with RW within the same network or not?
  • 2.  RE: IAP-205-RW vs IAP-205-US
    Posted Jan 26, 2016 12:58 PM
    I don't believe so, no, you should stick with ROW APs if your vessel is mostly either in international waters or outside of the US.
  • 3.  RE: IAP-205-RW vs IAP-205-US
    They are tied to unique regulatory requirements.
    US can only be used in the US and can not be a part of a cluster with RW IAPs.
  • 4.  RE: IAP-205-RW vs IAP-205-US
    Posted Jan 26, 2016 01:22 PM
    Thanks for quick answers!
