last person joined: 9 hours ago
IAP 205 SSID on VLAN and the DHCP is being handed out by local server
  • 1.  IAP 205 SSID on VLAN and the DHCP is being handed out by local server
    Posted Jun 29, 2016 01:13 AM
    Hi
    I am running a IAP 205. Where the SSID is setup to be on the default network that has a DHCP server. A client connects and they dont get a IP from the DHCP server. I upgraded to the latest 6.4.2.6-4.1.3.0_54915 (dell IAP).
    I had the same issue at another site where i had to reconfigure the SSID again and then it started working. Is there anything i can check to why clients dont pickup an IP?
    Of course clients wired are working fine
    thanks
  • 2.  RE: IAP 205 SSID on VLAN and the DHCP is being handed out by local server
    Posted Jun 29, 2016 01:22 AM
    You can run debug in IAP and check what is happening.
    #debug pkt match mac.
    #debug pkt mac <mac-id>
    #debug pkt type dhcp
    #debug pkt dump
  • 3.  RE: IAP 205 SSID on VLAN and the DHCP is being handed out by local server
    Posted Jul 04, 2016 12:14 AM
    Thanks, i will run this next time. Strange, adding back the SSID from scratch fixed the issue
    David
