IAP 205 Time Range not working
  • 1.  IAP 205 Time Range not working
    Posted May 02, 2017 02:24 PM
    I have IAP 205s version 6.4.4.8-4.2.4.6_58505
    I am trying to set up an SSID for use only on this Friday from 4p-11p.  I thought I set it up correctly, but when I test it and try to connect to it, it allows me to connect when it shouldn't.  I was hoping it would only let me connect during the time I specified?
    In the UI I went to System>Advanced Options>Time Based Services.  I created an Absolute profile for 5/5/17 16:00 to 23:00.  I then went to edit the SSID>Show Advanced options>Edit Time Range Profiles> Enable the profile I created earlier.
    Am I missing a step?
  • 2.  RE: IAP 205 Time Range not working
  • 3.  RE: IAP 205 Time Range not working
    Posted May 03, 2017 08:27 AM
    Hi Colin,
    Yes, I used that article to set up the time range.  when I do a show time range in the CLI I see this:
    # show time-range
    Current Time     :2017-05-03 07:25:33
    Time Range Summary
    Profile Name     Type      Start Day   Start Time  End Day     End Time  Valid
    Specific Friday  Absolute  05/05/2017  16:00       05/06/2017  23:59     No
    Do you see something I am missing?
  • 4.  RE: IAP 205 Time Range not working
    Posted May 03, 2017 11:45 AM
    You need to disable the SSID.  The SSID then will only be enabled during the time range:
  • 5.  RE: IAP 205 Time Range not working
    Posted May 03, 2017 12:13 PM
    Ahhh...so in the edit SSID >Show Advanced Options check the SSID: disable box (next to the hide box)?
    Then the time range setting will over-ride the disabled setting?
  • 6.  RE: IAP 205 Time Range not working
    Posted May 03, 2017 01:03 PM
    Yes.  Not very clear.
  • 7.  RE: IAP 205 Time Range not working
    Posted May 03, 2017 01:09 PM
    Thank you, Colin, once again you earned your Guru title!! :o)
  • 8.  RE: IAP 205 Time Range not working
    Posted Oct 06, 2017 10:16 AM
    Thank you!
