IAP-205-US never join to the virtual controller.
  • 1.  IAP-205-US never join to the virtual controller.
    Posted May 19, 2016 05:58 PM
    I have a virtual controller whit 8 IAP-205-RW working correctly but recently we purchased three IAP-205-US and it never join to the virtual controller.
    Sorry for my English
    Regards
  • 2.  RE: IAP-205-US never join to the virtual controller.
    Posted May 19, 2016 06:59 PM
    As far as i know you can only get this working if you start with the US version as master and then add the RW version. It will then be limited to US region channels
  • 3.  RE: IAP-205-US never join to the virtual controller.
    Posted May 19, 2016 07:19 PM
    Regulatory domains must match in the same VC.
