IAP 205 using wifi uplink
  • 1.  IAP 205 using wifi uplink
    Posted Oct 08, 2015 01:18 PM
    Does anyone know how to enable it? - Im facing greate trouble with it.
    http://www.arubanetworks.com/techdocs/InstantHTML/Content/Chapter9%20Uplink%20Configuration/ConfigureWiFIUL.htm
     Followed this guide
    #AP205
  • 2.  RE: IAP 205 using wifi uplink
    Posted Oct 10, 2015 02:46 PM
    WiFi Uplink isn't supported on 11ac APs.
  • 3.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 09:27 AM
    So to extend the wireless signal, i need to purchase some new iaps?
    What i need is to extend the Wireless signal where i dont have access to a wired port - i have been looking in to mesh, but i dont think it will work like i want.
    /Nikolaj
  • 4.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 10:21 AM
    Yes. This is called wireless mesh.
    Tim
  • 5.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 10:41 AM
    I have tried to setup mesh on two IAP-205-RW, but cant get it working.
    Im also using af POE adapter to get it powered up, i dont know if that could be the cause why it isnt working.
    When setting up Mesh i followed the steps in the userguide: "Setting up Instant Mesh Network" - but when i come to the step where i should disconnect my AP, it isnt working - its just rebooting and the light is yellow in 2,4/5ghz - i was wondering if i need to use a power adapter insted of the POE-Adapter?
    It also says in the guide "Mesh is by default disabled" - how do i enable it?
    /Nikolaj
  • 6.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 11:01 AM
    Please see here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Configure-a-basic-Instant-mesh/ta-p/205027
    Go straight to the section "
    New Mesh Provisioning Procedure in 4.1
  • 7.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 11:07 AM
    So if im correct, mesh is NOT working on 11AC platforms?
    1. All 11AC platforms, e.g. IAP22x (Ardmore), IAP27x(k2);
  • 8.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 11:10 AM
    npabst,
    I apologize.  I should have looked at the model of your access point.  Mesh Does work in IAP 4.2.0.0 and above for 802.11ac access points.
  • 9.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 12:27 PM
    Its okay, but could i be a problem that im using a POE-adapter? Or should i use a normal power adapter, so I dont use the ethernet port.
    And how do I enable the MESH portal?
    World it work with only two Aps?
  • 10.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 01:03 PM
    You can either use a POE injector or power adapter
    For mesh, the same instructions in the article here apply (Instant 4.1 and above):  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Configure-a-basic-Instant-mesh/ta-p/205027
    It would work with only 2 APs, yes.
  • 11.  RE: IAP 205 using wifi uplink
  • 12.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 01:10 PM
    The guide is refering to 'mesh portal' is it just the portal the VC is creating? Its like the AP wont connect to My already created ssid. As far as i see i need to connect to accesspoints, create a ssid, take one of the accesspoints to another location, without connection to the network.
  • 13.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 01:20 PM
    Let me be clear:
    - Boot both access points up on the same layer 2 VLAN so you can see the second access points from the Virtual controller (first access point).  Both access points need to be on the same version of Instant code.  If you are running 802.11ac access points, you need to be running 4.2.0.0 or above to do mesh
    - Create an actual SSID so that the instant SSID disappears and your SSID is being broadcasted.
    - Disable Extended SSID
    - Move the second access point to where you only apply power and it should mesh when it boots up with the first access point.
  • 14.  RE: IAP 205 using wifi uplink
    Let me be clear:
  • 15.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 01:29 PM
    I have two 205-RW ap's - both Are upgraded to newest firm. And Are on the same vlan.
  • 16.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 02:38 PM
    I have now followed the "guide" you wrote, step by step.
    1. Factory Reset APs.
    2. I have a SO-HO switch for testing with POE, i plugged both AP's in.
    3. Booted both AP's.
    4. Connected to instant  SSID.
    5. Created a new SSID (GFG-Internal).
    6. Disabled Extended_SSID.
    7. Rebooted both APs.
    8. Plugged the 'Non-VC' to a POE adapter, without link to network.
    Still the same 2.4/5ghz light is orange - and it is not working - Reboot Loop is active :/
    This i really annoing, i have been working on this for hours now.
    CONFIGURATION:
    version 6.4.2.0-4.1.1
    virtual-controller-country DK
    virtual-controller-key 76748848010e9aab084ebf0f6be1002ea54575350c53131917
    name instant-CE:DC:90
    terminal-access
    clock timezone none 00 00
    rf-band 2.4
    allow-new-aps
    allowed-ap 94:b4:0f:ce:dc:90
    allowed-ap 94:b4:0f:ce:dc:bc
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin 81922d1dc0819bc6b41bbbbab0d5f290
    wlan access-rule default_wired_port_profile
    index 1
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 2
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule GFG-Internal
    index 3
    wlan ssid-profile GFG-Internal
    enable
    index 1
    type employee
    essid GFG-Internal
    wpa-passphrase b17a771040535fdf07a230b525a3e86e2c5ed56185fc680d
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan 1
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
  • 17.  RE: IAP 205 using wifi uplink
    Posted Oct 11, 2015 03:07 PM
    It looks like you are running 4.1.1.8.  Mesh on 802.11ac will only work on 4.2.0.0 and above.
    Please plug them both into the wired network and upgrade them....
  • 18.  RE: IAP 205 using wifi uplink
    Let me be clear:
