IAP-205 vs IAP-205H
  • 1.  IAP-205 vs IAP-205H
    Posted Nov 07, 2017 07:16 AM
    We use lots of the IAP-205RW's but for my next project I don't want to ceiling mount the access points. I've seen desk mounts for the IAP-205H. How does this hospitatlity access point compare again the IAP-205 in terms of signal, coverage etc. Are they omni/directional? They look smaller so I'm concerend they won't provide as good coverage.
    Tom
  • 2.  RE: IAP-205 vs IAP-205H
    Posted Nov 07, 2017 07:44 AM
    Hi!
    They are a bit smaller yes. Don´t know about coverage area compared to the regular 205. But I suspect they are quite similar.
    The antenna seams to be quite directional looking at the graphs:
    http://www.arubanetworks.com/assets/ds/DS_AP205H.pdf
    So not omni.
  • 3.  RE: IAP-205 vs IAP-205H
    Posted Nov 07, 2017 10:34 AM
    they would have slightly lower signal coverage, we are assuming due to lower specs, we did a comparison with 303h and 305 some time back, signal propagation difference about 5-10%
  • 4.  RE: IAP-205 vs IAP-205H
  • 5.  RE: IAP-205 vs IAP-205H
    Posted Nov 07, 2017 10:35 AM
    and yes they are omnidirectional
  • 6.  RE: IAP-205 vs IAP-205H
  • 7.  RE: IAP-205 vs IAP-205H
    Posted Nov 07, 2017 03:01 PM
    Coverage of a desk mounted 205H should not be significantly different from a ceiling mounted 205, but it may depend on the environment in which the AP is placed (objects may cause more RF attenuation, etc.). The 205H (and 303H) have "slightly directional" antenna patterns, but I doubt that it will have a noticeable impact. RF performance numbers (transmit power, receiver sensitivity) are very similar.
    Note that you may want to consider the 303H instead of the 205H. The 205H has been announced to go end of sale (by 5/1/2018), and the 303H is a lower cost and more capable replacement.
    Also, if you're sure to use it in a desk mount scenario, we have the AP-303HR bundles, where the 303H comes with a pre-assembled and attached desk stand, a power adapter and AC cord.
    There are two versions of this bundle. AP-303HR-US comes with the AP-303H-US and a North-American cord, while AP-303HR-EU contains the AP-303H-RW and a european power cord.
  • 8.  RE: IAP-205 vs IAP-205H
    Posted Nov 07, 2017 05:08 PM
    Thank you everyone for the feedback. I've accepted this as the answer as it goes further and recommends the newer model.
  • 9.  RE: IAP-205 vs IAP-205H
    Posted May 23, 2018 04:33 PM
    Will the 303H work with the 205H in an instant cluster?
  • 10.  RE: IAP-205 vs IAP-205H
    Posted May 24, 2018 02:19 PM
    Sure. As long as you're using a software version that supports both (6.5.2.0 or later I guess)
