IAP 205, wildcard certificate for replace securelogin.arubanetworks.com
This thread has been viewed 48 times
  • 1.  IAP 205, wildcard certificate for replace securelogin.arubanetworks.com
    Posted Oct 24, 2016 11:41 AM
    Can I use wildcard certificate for replace default certificate for captive portal (securelogin.arubanetworks.com) on IAP running relase 6.5.0.0-4.3.0.0?
    And if it is possible, what is the procedure?
    EF
  • 2.  RE: IAP 205, wildcard certificate for replace securelogin.arubanetworks.com
  • 3.  RE: IAP 205, wildcard certificate for replace securelogin.arubanetworks.com
    Posted Oct 28, 2016 06:22 AM
    -resolved-
  • 4.  RE: IAP 205, wildcard certificate for replace securelogin.arubanetworks.com
    Posted Oct 28, 2016 07:10 AM
    I followed these steps and works for me.
    Previous you need:
    • Wildcard certificate. Ex.: cert.crt
    • Private key of wildcard certificate. Ex.: certkey.key
    • Bundle certificate with root and intermediate certificates of CA. Ex.: bundle.crt
    • Openssl
    1.- Make copy of wildcard (you will need)
    Ex.: cert-copy.crt
    2.- Make bundle with wildcard and bundle.
    cat bundle.crt >> cert.crt
    3.- Make a pkcs12 certificate
    openssl pkcs12 –export –out certpkcs12.pfx –inkey certkey.key –in cert.crt –certfile cert-copy.crt
    YOU WILL BE ASKED TO SET A PASSWORD, DON´T FORGET IT
    4.- convert to pem format
    Openssl pkcs12 –in certpkcs12.pfx –out certpem.pem –nodes
    YOU WILL BE ASKED TO ENTER THE PASSWORD
    5.- Load certificate in the virtual controller
    6.- Reload virtual controller.
    7.- Try to login and you will see that the name of the portal is “captiveportal-login.mycompany.com”
    IF YOU ARE USING CLEARPASS WEB LOGIN PORTAL, YOU MUST CHANGE THIS PARAMETER INSIDE YOUR LOGIN PAGE
