IAP-205, Windows 7, NPS and EAP.
  • 1.  IAP-205, Windows 7, NPS and EAP.
    Posted Aug 11, 2015 01:37 PM
    All,
    We're trying to setup several IAP-205's to work with an NPS server to automatically authenticate active-directory users. We've set everything up according to some articles that we found linked from here and everything is working fine on Windows 8 systems, but on our Windows 7 systems we can't get them to connect. We are prompted for credentials on these machines, but it doesn't accept them and eventually times out. We've tried this on a range of Windows 7 laptops and we get the same results, but again, on Windows 8 systems it works fine. Has anyone had any issues like this and if so, any solutions?
  • 2.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 11, 2015 01:40 PM
    Are you using a publicly or privately signed RADIUS server certificate?
    If private, is the root CA or self-signed certificate installed on each
    client?
    Are you using Group Policy to configure the clients?
  • 3.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 11, 2015 01:44 PM
    Thanks for the reply,
    We're using a self-signed cert
    The root/cert is distributed to all the clients via CMS, we've confirmed via certs snap-in.
    We are not currently pushing authentication through group policy as we wanted to test/tinker before pushing the policy out.
  • 4.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 11, 2015 01:55 PM
    Please enable user-debug for one of the problem clients, attempt an
    authentication and then post the output of "show auth-tracebuf mac
    macaddress".
  • 5.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 11, 2015 02:22 PM
    When I try to enable user-debug loggin with config t logging level debugging user I get a failure on the logging command.
    ac:a3:1e:c5:a0:86# config t logging level debugging user
    Any suggestions?
  • 6.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 12, 2015 03:15 AM
    Have you separated the "conf t" and "logging level debugging user" into two separate commands - it looks like you are entering them on the same line.
  • 7.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 12, 2015 11:16 AM
    have tried seperating the commands and running them on the same line, same result
  • 8.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 08:39 AM
    any other suggestions?
  • 9.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 08:40 AM
  • 10.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 10:44 AM
    I pasted the results of the command in the link in the follow up post. THanks !
  • 11.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 08:41 AM
    What do the logs on the NPS side say?
  • 12.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 10:39 AM
    Authentication attempts seem to be reaching it and I believe authentication is successful?
    "DC1","IAS",08/14/2015,10:29:27,1,"DOMAIN\testaccount","DOMAIN\testaccount","aca31ec5a10e","70188b08204b",,,"192.168.253.242","192.168.253.249",0,0,"192.168.253.1","Kraft WLAN Auth",,,19,,,1,5,"Secure Wireless Connections",0,"311 1 192.168.254.209 08/05/2015 11:00:29 158",,,,"",,,,,,,,,,,,,,,,,,,,,,,,,,,,,,"Secure Wireless Connections",1,,,,
    "DC1","IAS",08/14/2015,10:29:27,3,,"DOMAIN\testaccount",,,,,,,,0,"192.168.253.1","Kraft WLAN Auth",,,,,,,5,"Secure Wireless Connections",22,"311 1 192.168.254.209 08/05/2015 11:00:29 158",,,,"",,,,,,,,,,,,,,,,,,,,,,,,,,,,,,"Secure Wireless Connections",1,,,,
    The account referenced can auth from Windows 8 systems, so we know it's good there.
    For reference:
    192.168.253.242 = IAP
    192.168.254.209 = DC/NPS
    192.168.253.1 = gateway
    The below is the result of the Show AP Debut Auth-Trace-Buf command that matches up with what I pasted above:
    Aug 14 10:29:20  station-up             *  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      -   -     wpa2 aes
    Aug 14 10:29:20  eap-id-req            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5
    Aug 14 10:29:21  station-up             *  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      -   -     wpa2 aes
    Aug 14 10:29:21  eap-id-req            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5
    Aug 14 10:29:26  eap-start             ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      -   -
    Aug 14 10:29:26  eap-id-req            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5
    Aug 14 10:29:26  eap-id-resp           ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   33    domain\testaccount
    Aug 14 10:29:26  rad-req               ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      85  230
    Aug 14 10:29:26  rad-resp              <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1/DC1  85  90
    Aug 14 10:29:26  eap-req               <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      2   6
    Aug 14 10:29:26  eap-nak               ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      2   6
    Aug 14 10:29:26  rad-req               ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1/DC1  86  241
    Aug 14 10:29:26  rad-reject            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1/DC1  86  44
    Aug 14 10:29:26  eap-failure           <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      2   4     server rejected
    Aug 14 10:29:27  station-up             *  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      -   -     wpa2 aes
    Aug 14 10:29:27  eap-id-req            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5
    Aug 14 10:29:27  eap-start             ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      -   -
    Aug 14 10:29:28  station-up             *  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      -   -     wpa2 aes
    Aug 14 10:29:28  eap-id-req            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5
    Aug 14 10:29:59  eap-id-req            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5
    Aug 14 10:29:59  eap-id-resp           ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   5     70188B08204B
    Aug 14 10:29:59  rad-req               ->  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      87  186
    Aug 14 10:29:59  rad-reject            <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1/DC1  87  44
    Aug 14 10:29:59  eap-failure           <-  70:18:8b:08:20:4b  ac:a3:1e:da:10:e1      1   4     server rejected
  • 13.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 10:46 AM
    oops, dupe post, sorry.
  • 14.  RE: IAP-205, Windows 7, NPS and EAP.
    Posted Aug 14, 2015 10:50 AM
    You should double-check the trust settings (serial numbers on your CA certs) on your Windows 8 devices:
    What method do you use to push the trusted certs to the Windows 8 machine?
