IAP-205 wireless interface restarts (wlc_reset)
  • 1.  IAP-205 wireless interface restarts (wlc_reset)
    Posted May 08, 2016 03:16 PM
    I am running 12 units IAP-205 with software 6.4.2.6-4.1.1.11.
    In random period of time, some groups of users connected to one AP suffer from packet loss.
    From syslogs I see that every day radios (5Ghz or 2.4Ghz) on different APs rebooting with some error.
    All APs not overloaded and in the moment of failure can have 2 clients.
    This is typical message I catch from AP after problem:
    show log driver
    [8151765.330000] failed to get phy_rxiqest
    [8151876.506000] stats > 100: ccastats_us: 74016, acc->statss_ms: 74
    [8152001.944000] stats > 100: ccastats_us: 74268, acc->statss_ms: 74
    [8152064.714000] stats > 100: ccastats_us: 74187, acc->statss_ms: 74
    [8152142.786000] wl0 wlc_dotxstatus: consumes 0 frames!
    [8152142.786000] wl0 raw txstatus 0063 3A09 | 077A 0000 | 00000000 00000000 || 00007195 00000000 | 00000000
    [8152142.786000] pktpend: 0 1 0 0 0 ap: 1
    [8152142.786000] frameid 0x3a09 queue 1
    [8152142.786000] wl0: wlc_bmac_txstatus:: bad txstatus 3A090063 2000077A 00000000 00000000 || 00007195 00000000 00000000 C7B080C8
    [8152142.786000] error 1 caught in wlc_bmac_txstatus
    [8152142.786000] wl0: wlc_dpc: txstatus fatal error
    [8152142.786000] wl0: wlc_reset: !!!BIG-hammer!!!
    [8152142.786000] wl0: 1 tx fifo 1 underflows!
    [8152142.806000] wl0: wlc_txbf_init_sta: scb aleady has user index 0
    [8152147.590000] wl0: ampdu_resp_timeout: cleaning up resp tid 0 waiting for seq 0x6fb for 200 ms
    [8152356.796000] wl0: ampdu_resp_timeout: cleaning up resp tid 0 waiting for seq 0x9a for 200 ms
    show log kernel
    54616.806000] wl0: PHYTX error
    [8154616.806000] wl0: PHYTX error
    [8154616.856000] wl0: PSM microcode watchdog fired at 8138192 (seconds). Resetting.
    [8154616.856000] ucode revision 876.1
    [8154616.856000] wl0: psmdebug 0x00ff861c, phydebug 0x00000048, psm_brc 0x00b0 psm_brc_1 0x00a2
    [8154616.856000] wepctl 0x0015 wepstat 0x0003 wep_hdrloc 0x0026 wep_psdulen 1454
    [8154616.856000] RXE_RXCNT: 0x0014 DAGG: ctl: 0x0000, bleft: 0x095f
    [8154616.856000] offs: 0x0034, stat: 0x13db, len: 0x0000
    [8154616.856000] phydebug
    [8154616.856000] 0x0048
    [8154616.858000] PC :
    [8154616.858000] 0xff861c
    [8154616.858000] wlc_dump_aggfifo:
    [8154616.858000] framerdy 0x2 bmccmd 1 framecnt 0x2
    [8154616.858000] AQM agg params 0xfff maxlen hi/lo 0x4 0x2040 minlen 0xc8 adjlen 0x8
    [8154616.858000] AQM agg results 0x8001 len hi/lo: 0x0 0x5b2 BAbitmap(0-3) 0 0 0 0
    [8154616.858000] wlc_dpc:605 wl0 ASSERT 'PSM Watchdog' macintstatus:0x2800
    [8154616.858000] wl0: wlc_dpc: macintstatus & MI_GP0 non-zero, HAMMERING
    [8154616.858000] wl0: wlc_reset: !!!BIG-hammer!!!
    [8154616.878000] wl0: wlc_txbf_init_sta: scb aleady has user index 0
    [8154773.658000] wl0: ampdu_resp_timeout: cleaning up resp tid 1 waiting for seq 0x65c for 200 ms
    [8154996.036000] stats > 100: ccastats_us: 74133, acc->statss_ms: 74
    [8155028.930000] wl0: ampdu_resp_timeout: cleaning up resp tid 0 waiting for seq 0xd8a for 200 ms
    Peak CPU Util in the last one hour
    Timestamp CPU Util(%) Memory Util(%)
    2016-05-08 14:36:21 37 67
    I guess it is some driver problem but I`m not sure. If you have some thoughts, please share.
  • 2.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted May 09, 2016 06:42 PM
    open a tac case, it has already been reported and under investigation.
  • 3.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 12:02 PM
    Is this a known issue? Please provide additional information such as bug IDs or existing case numbers for this issue.
  • 4.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 12:19 PM
    It is already resolved issue. Try latest stable firmware
  • 5.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 12:44 PM
    Thanks for the suggestion, but we are running 6.5.0.3, which I believe is the latest firmware.
    We see this interface reset error on ~70 of our AP-225 units around campus (out of ~1,700).
    The "wl1: fatal error, reinitializing > wl1: wlc_reset: !!!BIG-hammer!!! " error is generated by these APs every 2 seconds. It only affects the 2.4Ghz radio and prevents any clients from associating to that radio. The 5Ghz radio continues to work fine and serve clients. Rebooting the AP eliminates the issue and the 2.4Ghz radio begins serving clients agian.
  • 6.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 12:45 PM
    My Co-worker created a detailed post about this particular issue we are having:
    https://community.arubanetworks.com/t5/Wireless-Access/Problem-with-radio-resets-quot-BIG-Hammer-quot/m-p/285430#M66902
  • 7.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 03:19 PM
    Radio resets typically are due to errors due to interference. What is the arm min and max transmit power for your WLAN?
  • 8.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 03:39 PM
    Our 2.4Ghz ARM profile is set to range from 15 to 9.
    Our 5Ghz ARM profile is set to range from 18 to 12.
    We see this issue only on our 2.4Ghz radios. The radio resets every 2 seconds, preventing any client associations. This behavior continues throughout the night when I'd imagine the RF environment should be less noisy.
    Daytime noise floor is typically in the mid to upper -90 range for the APs experiencing this issue.
    If we reboot the AP, the problem goes away for at least a few days, but may show up on other APs in the building.
    Thanks for your thoughts, we also have an open case with TAC. They claim to have seen this before and development wants to collect some log data from us.
  • 9.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 03:53 PM
    I would stick with TAC on this one. You are pulling together threads that may or may not be relevant to your situation, and that might delay relief.
    Noise is mainly an indicator for non-wifi interference. High utilization can be caused by wifi, non wifi interference or a combination. That could cause radio resets. If you have a dense deployment, I would lower the max TX for 2.4ghz to 12 and see if it continues. Since TX power is logarithmic, every 3 that you decrement is an effective halving of transmit power which can make a great difference.
    If you type "show ap arm state ap-name <name of AP> how many APs can you see on the 2.4ghz band?
  • 10.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 05:10 PM
    Thanks, we may try moving the 2.4Ghz max down to 12 and see if that changes the frequency of this problem.
    Trying your suggested command, some of the APs return no output besides the date. and time.
    For the APs that do return ARM state info, the number of valid neighbors ranges from 10-20 with relevant neighbors in the 2-10 range.
  • 11.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 20, 2017 06:24 PM
    Try the max at 12.
  • 12.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 21, 2017 05:42 AM
    I am talking about General Availability firmware.
    I use 6.4.4.8-4.2.4.4_57496.
  • 13.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 27, 2017 02:22 PM
    I have this on our APs. I did a debug:
    "show ap tech-support ap-name AP225-G-frecuency-Issues Archivo-TechSupp-AP225-G-frecuency-Issues.txt"
    and in the file i found this (very cutted lines for short):
    Toooooo many resets on radio 1:
    show ap debug radio-stats ap-name "APAC-225-Issues.Level-3.Building-9F.HMO" radio 1 advanced
    RADIO Stats
    Parameter Value
    ------------------- General
    Total Radio Resets 246575
    Resets Beacon Fail 0
    BB Check Positives 0
    Resets BeacQ Stuck 0
    Resets Fatal Intr 0
    Resets RX Overrun 0
    Resets RF Gain 0
    Resets MTU Change 0
    Resets TX Timeouts 0
    Resets RX Timeouts 0
    POE-Related Resets 0
    External Reset 0
    PCI Fatal Intr Reset 0
    Chainmask Reset 0
    TX stat Reset 0
    TX Power Changes 5
    Channel Changes 2
    Failed Channel Changes 0
    Radio Band Changes 0
    ======================= Radio 0 seems like no problem (resetes: 8 vs 246,575) ====
    show ap debug radio-stats ap-name "APAC-225-Issues.Level-3.Building-9F.HMO" radio 0 advanced
    RADIO Stats
    Parameter Value
    Total Radio Resets 8
    Resets Fatal Intr 0
    Resets RX Overrun 0
    Resets RF Gain 0
    Resets MTU Change 0
    External Reset 0
    Chainmask Reset 0
    TX stat Reset 0
    TX Power Changes 3
    Channel Changes 2
    ======================  BIG HAMMER fatal error =====
    show ap debug driver-log ap-name "APAC-225-Issues.Level-3.Building-9F.HMO"
    [564399.224855] wl1 bmac set short slot 1, wl status 1
    [564399.225533] wl1 bmac set short slot 1, wl status 1
    [564399.256318] wl1: ap watchdog handler error
    [564401.170057] wl1: bcn inactivity detected HAMMERING
    [564401.170069] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564401.170081]
    [564401.170083] chan dur ibss obss interf time
    [564401.170093] wl1: fatal error, reinitializing
    [564401.170104] wl1: wlc_reset: !!!BIG-hammer!!!
    [564401.225479] wl1 bmac set short slot 1, wl status 1
    [564401.226100] wl1 bmac set short slot 1, wl status 1
    [564401.256888] wl1: ap watchdog handler error
    [564403.168993] wl1: bcn inactivity detected HAMMERING
    [564403.169005] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564403.169017]
    [564403.169020] chan dur ibss obss interf time
    [564403.169030] wl1: fatal error, reinitializing
    [564403.169040] wl1: wlc_reset: !!!BIG-hammer!!!
    [564403.224947] wl1 bmac set short slot 1, wl status 1
    [564403.225628] wl1 bmac set short slot 1, wl status 1
    [564403.256532] wl1: ap watchdog handler error
    [564405.169501] wl1: bcn inactivity detected HAMMERING
    [564405.169513] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564405.169525]
    [564405.169527] chan dur ibss obss interf time
    [564405.169537] wl1: fatal error, reinitializing
    [564405.169548] wl1: wlc_reset: !!!BIG-hammer!!!
    [564405.225434] wl1 bmac set short slot 1, wl status 1
    [564405.226090] wl1 bmac set short slot 1, wl status 1
    [564405.256978] wl1: ap watchdog handler error
    [564406.223241] wl0: wlc_ampdu_tx_send_delba: tid 0 initiator 1 reason 39 dest 64:9a:be:38:33:62
    [564407.171197] wl1: bcn inactivity detected HAMMERING
    [564407.171208] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564407.171228]
    [564407.171230] chan dur ibss obss interf time
    [564407.171241] wl1: fatal error, reinitializing
    [564407.171252] wl1: wlc_reset: !!!BIG-hammer!!!
    [564407.225774] wl0: wlc_ampdu_tx_send_delba: tid 6 initiator 1 reason 39 dest 24:f0:94:41:d6:d4
    [564407.226696] wl1 bmac set short slot 1, wl status 1
    [564407.227360] wl1 bmac set short slot 1, wl status 1
    [564407.258005] wl1: ap watchdog handler error
    [564409.169508] wl1: bcn inactivity detected HAMMERING
    [564409.169519] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564409.169531]
    [564409.169533] chan dur ibss obss interf time
    [564409.169543] wl1: fatal error, reinitializing
    [564409.169554] wl1: wlc_reset: !!!BIG-hammer!!!
    [564409.224961] wl1 bmac set short slot 1, wl status 1
    [564409.225616] wl1 bmac set short slot 1, wl status 1
    [564409.256352] wl1: ap watchdog handler error
    [564410.223220] wl0: wlc_ampdu_tx_send_delba: tid 6 initiator 1 reason 39 dest 68:ae:20:0c:c2:6a
    [564411.168992] wl1: bcn inactivity detected HAMMERING
    [564411.169003] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564411.169015]
    [564411.169018] chan dur ibss obss interf time
    [564411.169028] wl1: fatal error, reinitializing
    [564411.169038] wl1: wlc_reset: !!!BIG-hammer!!!
    [564411.224346] wl1 bmac set short slot 1, wl status 1
    [564411.224949] wl1 bmac set short slot 1, wl status 1
    [564411.255709] wl1: ap watchdog handler error
    [564413.169486] wl1: bcn inactivity detected HAMMERING
    [564413.169497] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564413.169509]
    [564413.169511] chan dur ibss obss interf time
    [564413.169522] wl1: fatal error, reinitializing
    [564413.169532] wl1: wlc_reset: !!!BIG-hammer!!!
    [564413.224835] wl1 bmac set short slot 1, wl status 1
    [564413.225468] wl1 bmac set short slot 1, wl status 1
    [564413.256213] wl1: ap watchdog handler error
    [564415.169489] wl1: bcn inactivity detected HAMMERING
    [564415.169501] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564415.169513]
    [564415.169515] chan dur ibss obss interf time
    [564415.169525] wl1: fatal error, reinitializing
    [564415.169536] wl1: wlc_reset: !!!BIG-hammer!!!
    [564415.224832] wl1 bmac set short slot 1, wl status 1
    [564415.225492] wl1 bmac set short slot 1, wl status 1
    [564415.256246] wl1: ap watchdog handler error
    [564417.169498] wl1: bcn inactivity detected HAMMERING
    [564417.169509] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564417.169521]
    [564417.169523] chan dur ibss obss interf time
    [564417.169534] wl1: fatal error, reinitializing
    [564417.169544] wl1: wlc_reset: !!!BIG-hammer!!!
    [564417.224883] wl1 bmac set short slot 1, wl status 1
    [564417.225536] wl1 bmac set short slot 1, wl status 1
    [564417.256245] wl1: ap watchdog handler error
    [564419.169505] wl1: bcn inactivity detected HAMMERING
    [564419.169516] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564419.169528]
    [564419.169531] chan dur ibss obss interf time
    [564419.169541] wl1: fatal error, reinitializing
    [564419.169552] wl1: wlc_reset: !!!BIG-hammer!!!
    [564419.225107] wl1 bmac set short slot 1, wl status 1
    [564419.225717] wl1 bmac set short slot 1, wl status 1
    [564419.229858] wl0: wlc_ampdu_tx_send_delba: tid 6 initiator 1 reason 39 dest 64:9a:be:38:33:62
    [564419.256455] wl1: ap watchdog handler error
    [564421.169551] wl1: bcn inactivity detected HAMMERING
    [564421.169562] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564421.169574]
    [564421.169576] chan dur ibss obss interf time
    [564421.169587] wl1: fatal error, reinitializing
    [564421.169597] wl1: wlc_reset: !!!BIG-hammer!!!
    [564421.225005] wl1 bmac set short slot 1, wl status 1
    [564421.225646] wl1 bmac set short slot 1, wl status 1
    [564421.256364] wl1: ap watchdog handler error
    Any idea?
  • 14.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 27, 2017 02:38 PM
     Same pattern here... i did a debug and seems like something in the driver:
    “show ap tech-support ap-name AP225-G-frecuency-Issues Archivo-TechSupp-AP225-G-frecuency-Issues.txt
    I extract few lines:
    show ap debug datapath ap-name "AP225-G-frecuency-Issues "
    Datapath Parameters Table
    essid     encr-alg        client-vlan-id  tunnel-id  gre-type  deny-bcast  num-clients
    Uni    WPA2 8021X AES  1128            0x10951    0x8210    disable     6
    Mae  WPA2 8021X AES  1128            0x10608    0x8200    disable     1
    Uni    WPA2 8021X AES  1128            0x105b1    0x8310    disable     0
    Mae  WPA2 8021X AES  1128            0x10952    0x8300    disable     0
    show ap debug client-table ap-name "AP225-G-frecuency-Issues "
    Client Table
    MAC                ESSID     BSSID              Assoc_State    HT_State  AID  PS_State    UAPSD            Tx_Pkts  Rx_Pkts  PS_Qlen  Tx_Retries  Tx_Rate  Rx_Rate  Last_ACK_SNR  Last_Rx_SNR  TX_Chains  Tx_Timestamp              Rx_Timestamp              MFP Status (C,R)  Idle time  Client health (C/R)
    68:c4:4d:4c:43:cb  Mae  18:64:72:14:85:30  Associated     WSsb      0x2  Awake       (0,0,0,0,N/A,0)  222      69       0        154         45       19       11            9            3[0x7]     Thu Jan 26 12:05:34 2017  Thu Jan 26 12:05:34 2017  (0,0)             0          100/65
    f4:09:d8:4f:6d:7b  Mae  18:64:72:14:85:30  Authenticated  AWvSsEe        Awake       (0,0,0,0,N/A,0)  289      45       0        9           866      780      50            48           3[0x7]     Thu Jan 26 12:05:28 2017  Thu Jan 26 12:05:28 2017  (0,0)             5          100/65
    f4:09:d8:4f:6d:7b  Uni    18:64:72:14:85:31  Associated     AWvSsEe   0x6  Awake       (0,0,0,0,N/A,0)  59       20       0        21          866      780      44            47           3[0x7]     Thu Jan 26 12:05:34 2017  Thu Jan 26 12:05:34 2017  (0,0)             0          100/65
    c0:bd:d1:f6:01:c6  Uni    18:64:72:14:85:31  Associated     AWvSsEe   0x4  Awake       (0,0,0,0,N/A,0)  1270     1003     0        124         195      87       10            15           3[0x7]     Thu Jan 26 12:05:34 2017  Thu Jan 26 12:05:34 2017  (0,0)             0          81/65
    24:f0:94:41:d6:d4  Uni    18:64:72:14:85:31  Associated     AWvSsEe   0x5  Power-save  (0,0,0,0,N/A,0)  11       10       3        15          433      6        7             7            3[0x7]     Thu Jan 26 12:01:18 2017  Thu Jan 26 12:01:21 2017  (0,0)             253        100/65
    68:ae:20:0c:c2:6a  Uni    18:64:72:14:85:31  Associated     WQSs      0x3  Awake       (0,0,0,0,N/A,0)  16627    15087    0        2981        14       13       9             7            3[0x7]     Thu Jan 26 12:05:31 2017  Thu Jan 26 12:04:44 2017  (0,0)             50         33/65
    64:9a:be:38:33:62  Uni    18:64:72:14:85:31  Associated     AWvSsEQ   0x1  Awake       (0,0,0,0,N/A,0)  11362    10741    0        1388        7        6        11            6            3[0x7]     Thu Jan 26 12:05:30 2017  Thu Jan 26 12:02:09 2017  (0,0)             204        28/65
    34:e6:ad:34:e0:18  Uni    18:64:72:14:85:31  Associated     WvSsEbQM  0x2  Awake       (0,0,0,0,N/A,0)  145521   96292    0        11670       433      351      34            27           3[0x7]     Thu Jan 26 12:05:34 2017  Thu Jan 26 12:05:34 2017  (0,0)             0          90/65
    1c:7b:21:b4:71:3f  Mae  18:64:72:14:85:20  Authenticated  sb             Awake       (0,0,0,0,N/A,0)  33       43       0        35          11       19       34            31           1[0x1]     Fri Jan 20 19:05:55 2017  Thu Jan 26 10:58:56 2017  (0,0)             3999       90/65
    9c:20:7b:0d:86:6a  Mae  18:64:72:14:85:20  Authenticated  Qb             Awake       (0,0,0,0,N/A,0)  98       234      0        50          39       26       17            25           1[0x1]     Fri Jan 20 19:04:18 2017  Thu Jan 26 12:05:00 2017  (0,0)             34         90/65
    Num of associated clients: 7
    UAPSD:(VO,VI,BK,BE,Max SP,Q Len)
    HT  Flags: A - LDPC Coding; W - 40MHz; S - Short GI 40; s - Short GI 20
              D - Delayed BA; G - Greenfield; R - Dynamic SM PS
              Q - Static SM PS; N - A-MPDU disabled; B - TX STBC
              b - RX STBC; M - Max A-MSDU; I - HT40 Intolerant; t turbo-rates (256-QAM)
    VHT Flags: C - 160MHz/80+80MHz; c - 80MHz;  V - Short GI 160; v - Short GI 80
                        E - Beamformee; e - Beamformer
    HT_State shows client's original capabilities (not operational capabilities)
    show ap debug driver-log ap-name "AP225-G-frecuency-Issues "
    [564401.170081]
    [564403.169017]
    [564455.169713] chan dur      ibss           obss           interf       time
    [564455.169723] wl1: fatal error, reinitializing
    [564455.169733] wl1: wlc_reset: !!!BIG-hammer!!!
    [564455.224983] wl1 bmac set short slot 1, wl status 1
    [564455.225644] wl1 bmac set short slot 1, wl status 1
    [564455.256365] wl1: ap watchdog handler error
    [564457.169511] wl1: bcn inactivity detected HAMMERING
    [564457.169522] wl1: txbcnfrm 0 prev txbcnfrm 0 txbcn inactivity 2 timeout 2
    [564457.169535]
    [564457.169537] chan dur      ibss           obss           interf       time
    [564457.169547] wl1: fatal error, reinitializing
    [564457.169558] wl1: wlc_reset: !!!BIG-hammer!!!
    [564457.194509] stats > 100: ccastats_us: 4077, acc->statss_ms: 2
    [564457.225173] wl1 bmac set short slot 1, wl status 1
    [564457.225792] wl1 bmac set short slot 1, wl status 1
    [564457.229810] wl0: wlc_ampdu_tx_send_delba: tid 6 initiator 1 reason 39 dest 24:f0:94:41:d6:d4
    [564457.256587] wl1: ap watchdog handler error
    Driver Log
    show ap debug radio-stats ap-name "AP225-G-frecuency-Issues" radio 0 advanced
    RADIO Stats
    Parameter                           Value
    Resets Fatal Intr                   0
    Resets RX Overrun                   0
    Resets RF Gain                      0
    Resets MTU Change                   0
    External Reset                      0
    Chainmask Reset                     0
    TX stat Reset                       0
    TX Power Changes                    3
    Channel Changes                     2
    Current Noise Floor                 92
    Dummy NF pkts on home channel       0
    Dummy NF pkts on scan channel       0
    Avail TX Buffers                    2048
    11g Protection                      0
    Last TX Antenna                     0
    Last RX Antenna                     0
    Scan Requests                       54759
    Scan Rejects                        15427
    Load aware Scan Rejects             60
    PS aware Scan Rejects               0
    EAP Scan Rejects                    778
    Voice aware Scan Rejects            14325
    Video aware Scan Rejects            264
    UAPSD Scan Rejects                  0
    Post radar related scan Rejects     0
    CABQ traffic Scan Rejects           0
    Radio Reset Scan Rejects            0
    Queue Drain Scan Rejects            0
    Scan Success                        39198
    EIRP                                18
    MAX EIRP                            22
    Dummy002                            19
    Dummy007                            8
    Dummy010                            1136
    Dummy011                            82710
    Dummy012                            0
    Dummy013                            0
    Dummy014                            0
    Dummy015                            0
    Dummy016                            0
    Dummy017                            19
    Dummy018                            0
    Dummy019                            0
    Dummy020                            0
    Dummy021                            0
    Dummy022                            22223
    -------------------                 Transmit
    Tx Time perct @ beacon intvl        1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Tx Frames Rcvd                      7124217
    Tx Bcast Frames Rcvd                0
    Tx Frames Dropped                   723350
    Tx Bcast Frames Dropped             0
    Tx Frames Transmitted               39305108
    Tx Bytes Rcvd                       4123176852
    Tx Bytes Transmitted                4200678483
    Tx Time Frames Rcvd                 1107283613
    Tx Time Frames Dropped              59540255
    Tx Time Frames Transmitted          1107283613
    Tx PS Unicast                       0
    Tx DTIM Broadcast                   0
    Tx Success With Retry               580417
    Tx Multiple Retries                 48169
    Tx Mgmt Frames                      1163162
    Tx Mgmt Frames(PPS)                 0
    Tx Beacons Transmitted              10998699
    Tx Beacons Transmitted(PPS)         0
    Tx Probe Responses                  64115
    Tx Probe Responses(PPS)             0
    Tx Data Transmitted Retried         5403232
    Tx Data Transmitted                 6279400
    Tx Data Frames                      7120523
    Tx Broadcast Data Frames In         0
    Tx Data Bytes Transmitted           4134319704
    Tx Data Bytes                       4208380682
    Tx Time Data Transmitted            661177657
    Tx Time BC/MC Data                  6184
    Tx Time Data dropped                59540255
    Tx Time Data                        661177657
    Tx Time Data (Ideal)                284675246
    Client Health Samples               3944211
    Tx Broadcast Data Frames Sent       0
    Tx Broadcast Data Frames Sent(PPS)  0
    Tx Multicast Data Frames            27651
    Tx Multicast Data Frames(PPS)       0
    Tx Workqueue Frames                 0
    Tx Bypass Frames                    0
    Tx DMO Multicast                    0
    Tx DMO Invalid                      0
    Tx DMO Converted                    0
    Tx DMO Replicated                   0
    Tx DMO Dropped                      0
    Tx DMO No Client                    0
    Tx DMO No BSSID                     0
    Tx Unicast Data Frames              6294682
    Tx RTS Frames                       9543605
    Tx RTS Frames(PPS)                  0
    Tx RTS Success                      3917024
    Tx RTS Failed                       5626581
    Tx CTS Frames                       1743003
    Tx CTS Frames(PPS)                  0
    Tx Powersave Queue Timeouts         0
    Tx Dropped After Retry              0
    Tx Dropped No Buffer                0
    Tx Missed ACKs                      683721
    Tx Failed Beacons                   22169
    Tx Multi-Beacon Fail                0
    Tx Long Preamble                    740603
    Tx Short Preamble                   0
    Tx Beacon Interrupts                11020870
    Tx Interrupts                       0
    Tx FIFO Underrun                    0
    Tx Allocated Desc                   7124217
    Tx Freed Desc                       0
    Tx EAPOL Frames                     30465
    TX STBC Frames                      844933
    TX LDPC Frames                      2498708
    Tx AGGR Good                        3820303
    Tx AGGR Unaggr                      113946
    Tx AGGR Retry                       485857
    Tx WMM DATA [BK]                    367578
    Tx Data Priority [BE]               2941642
    Tx Data Priority [VI]               22
    Tx Data Priority [VO]               2985521
    Tx Data Frames  12 Mbps  (Mon)      161620
    Tx Data Frames  54 Mbps  (Mon)      1432623
    Tx Data Frames 108 Mbps  (Mon)      1516130
    Tx Data Frames 300 Mbps  (Mon)      1540460
    Tx Data Frames 450 Mbps  (Mon)      1573733
    Tx Data Frames 1300 Mbps  (Mon)     70197
    Tx Data Frames 1300 Mbps+ (Mon)     0
    Tx Data Bytes   12 Mbps  (Mon)      77740156
    Tx Data Bytes   54 Mbps  (Mon)      779547490
    Tx Data Bytes  108 Mbps  (Mon)      1355673583
    Tx Data Bytes  300 Mbps  (Mon)      1089933044
    Tx Data Bytes  450 Mbps  (Mon)      798904944
    Tx Data Bytes  1300 Mbps  (Mon)     32520487
    Tx Data Bytes  1300 Mbps+ (Mon)     0
    Tx 9 Mbps                           739976
    Tx 12 Mbps                          8
    Tx 24 Mbps                          63
    Tx HT 7.2 Mbps                      131137
    Tx HT 14.4 Mbps                     303377
    Tx HT 21.7 Mbps                     2776
    Tx HT 27 Mbps                       67
    Tx HT 28.9 Mbps                     2738
    Tx HT 30 Mbps                       586502
    Tx HT 40.5 Mbps                     66
    Tx HT 43.3 Mbps                     1676
    Tx HT 45 Mbps                       535358
    Tx HT 57.8 Mbps                     524
    Tx HT 58.5 Mbps                     31
    Tx HT 60 Mbps                       751752
    Tx HT 65 Mbps                       181679
    Tx HT 72.2 Mbps                     265
    Tx HT 90 Mbps                       417256
    Tx HT 97.5 Mbps                     164623
    Tx HT 117 Mbps                      169
    Tx HT 120 Mbps                      209081
    Tx HT 130 Mbps                      500842
    Tx HT 135 Mbps                      40911
    Tx HT 150 Mbps                      46531
    Tx HT 175.5 Mbps                    73
    Tx HT 180 Mbps                      10952
    Tx HT 195 Mbps                      380022
    Tx HT 234 Mbps                      101
    Tx HT 240 Mbps                      3198
    Tx HT 260 Mbps                      230135
    Tx HT 270 Mbps                      606
    Tx HT 300 Mbps                      147
    Tx VHT 292.5 Mbps                   117692
    Tx VHT 325 Mbps                     171368
    Tx VHT 351 Mbps                     26
    Tx VHT 390 Mbps                     363961
    Tx VHT 433.3 Mbps                   1038378
    Tx VHT 468 Mbps                     12
    Tx VHT 520 Mbps                     19140
    Tx VHT 526.5 Mbps                   15
    Tx VHT 585 Mbps                     10979
    Tx VHT 650 Mbps                     6325
    Tx VHT 702 Mbps                     16
    Tx VHT 780 Mbps                     5243
    Tx VHT 866.7 Mbps                   28399
    Tx VHT 975 Mbps                     38
    Tx VHT 1170 Mbps                    20
    Tx VHT 1300 Mbps                    10
    Tx WMM [BK]                         363008
    Tx WMM [BE]                         2936847
    Tx WMM [VI]                         22
    Tx WMM [VO]                         2979523
    Tx WMM [BK] Dropped                 878
    Tx WMM [BE] Dropped                 31435
    Tx WMM [VI] Dropped                 1
    Tx WMM [VO] Dropped                 112849
    Tx UAPSD OverflowDrop               0
    TX Timeouts                         0
    Lost Carrier Events                 0
    Tx HT40 Hang Detected               0
    Tx HT40 Hang Stuck                  0
    Tx HT40 Hang Possible               0
    Tx HT40 Dfs IMM WAR                 0
    Tx HT40 Dfs HT20 WAR                0
    Tx MAC/BB Hang Stuck                0
    Tx Mgmt Bytes                       54925101
    Tx Beacons Bytes                    0
    Tx Managment Frames Dropped         571830
    Tx Data Frames Dropped              151520
    Tx AMSDU pkt count                  0
    Tx EAPOL Frames Rcvd                30467
    Tx EAPOL Frames Dropped             0
    -------------------                 Receive
    Rx Last SNR                         43
    Rx Last SNR CTL0                    43
    Rx Last SNR CTL1                    42
    Rx Last SNR CTL2                    40
    Rx Last SNR EXT0                    43
    Rx Last SNR EXT1                    42
    Rx Last SNR EXT2                    40
    Rx Last ACK SNR                     43
    Rx Frames Received                  17349116
    Rx Good Frames                      16268094
    Rx Bad Frames                       1081022
    Rx Total Data Frames Recvd          4181985
    Rx Total Mgmt Frames Recvd          1459967
    Rx Total Control Frames Recvd       10626142
    Rx Total Bytes Recvd                3408545096
    Rx Total Data Bytes Recvd           2208072561
    Rx Total RTS Frames Recvd           1772842
    Rx Total CTS Frames Recvd           4358109
    Rx Total ACK Frames                 376714
    Rx Total Beacons Received           34204
    Rx Total Probe Requests             266435
    Rx Total Probe Responses            338
    Rx Retry Frames                     813299
    Channel Busy 1s                     2
    Channel Busy 4s                     1
    Channel Busy 64s                    3
    Ch Busy perct @ beacon intvl        1 2 2 2 2 2 2 2 2 2 2 1 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2 2 2
    Rx Time perct @ beacon intvl        0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    Rx Discarded Events                 0
    Rx ARM Scan Frames                  0
    Rx Data Frames Retried              483511
    Rx Data Frames                      5294491
    Rx Data Frames(PPS)                 0
    Rx Data Bytes                       2208072561
    Rx Time Data                        542106938
    Rx Duplicate Frames                 11724
    Rx Broadcast Data Frames            71
    Rx Multicast Data Frames            161
    Rx Unicast Data Frames              4928038
    Rx Null Data Frames                 1083011
    Rx Mgmt Frames                      5048931
    Rx Mgmt Frames(PPS)                 0
    Rx Control Frames                   10626142
    Rx Control Frames(PPS)              0
    Rx Frames To Me                     15722659
    Rx Bytes To Me                      3408545096
    Rx Time To Me                       1489550426
    Rx Broadcast Frames                 514942
    Rx Probe Requests                   90593
    Rx Probe Requests(PPS)              0
    Rx RTS Frames                       1725089
    Rx RTS Frames(PPS)                  0
    Rx CTS Frames                       3917024
    Rx CTS Frames(PPS)                  0
    Rx PS Poll Frames                   28050
    Rx CRC Errors                       1081017
    Rx PLCP Errors                      57674
    Rx Frames Dropped                   11438326
    Rx PHY Events                       25048240
    Rx RADAR Events                     0
    RX Interrupts                       0
    RX Overrun                          0
    Rx Undecryptable                    0
    Rx EAPOL Frames                     23599
    Rx STBC Frames                      716111
    Rx LDPC Frames                      1185771
    Rx Data Priority [BK]               105965
    Rx Data Priority [BE]               3770267
    Rx Data Priority [VI]               202854
    Rx Data Priority [VO]               102899
    Rx Data Frames  12 Mbps  (Mon)      361350
    Rx Data Frames  54 Mbps  (Mon)      1791647
    Rx Data Frames 108 Mbps  (Mon)      955561
    Rx Data Frames 300 Mbps  (Mon)      629169
    Rx Data Frames 450 Mbps  (Mon)      431982
    Rx Data Frames 1300 Mbps  (Mon)     12276
    Rx Data Frames 1300 Mbps+ (Mon)     0
    Rx Data Bytes   12 Mbps  (Mon)      51363930
    Rx Data Bytes   54 Mbps  (Mon)      1575479703
    Rx Data Bytes  108 Mbps  (Mon)      229712449
    Rx Data Bytes  300 Mbps  (Mon)      264415827
    Rx Data Bytes  450 Mbps  (Mon)      84631837
    Rx Data Bytes  1300 Mbps  (Mon)     2468815
    Rx Data Bytes  1300 Mbps+ (Mon)     0
    Rx 6 Mbps                           128571
    Rx 9 Mbps                           365491
    Rx 12 Mbps                          188913
    Rx 18 Mbps                          149337
    Rx 24 Mbps                          100124
    Rx 36 Mbps                          60159
    Rx 48 Mbps                          207692
    Rx HT 6.5 Mbps                      163653
    Rx HT 7.2 Mbps                      4232
    Rx HT 13 Mbps                       110149
    Rx HT 13.5 Mbps                     78278
    Rx HT 14.4 Mbps                     10721
    Rx HT 19.5 Mbps                     39290
    Rx HT 21.7 Mbps                     281
    Rx HT 26 Mbps                       6307
    Rx HT 27 Mbps                       352387
    Rx HT 28.9 Mbps                     5571
    Rx HT 30 Mbps                       13157
    Rx HT 39 Mbps                       3847
    Rx HT 40.5 Mbps                     850381
    Rx HT 43.3 Mbps                     836
    Rx HT 45 Mbps                       9346
    Rx HT 52 Mbps                       1220
    Rx HT 54 Mbps                       308260
    Rx HT 57.8 Mbps                     4
    Rx HT 58.5 Mbps                     171721
    Rx HT 60 Mbps                       100193
    Rx HT 65 Mbps                       35648
    Rx HT 72.2 Mbps                     88
    Rx HT 78 Mbps                       411
    Rx HT 81 Mbps                       223908
    Rx HT 86.7 Mbps                     115
    Rx HT 90 Mbps                       48165
    Rx HT 97.5 Mbps                     11496
    Rx HT 104 Mbps                      1
    Rx HT 108 Mbps                      250390
    Rx HT 117 Mbps                      172322
    Rx HT 120 Mbps                      4006
    Rx HT 121.5 Mbps                    9786
    Rx HT 130 Mbps                      4553
    Rx HT 135 Mbps                      8933
    Rx HT 150 Mbps                      48972
    Rx HT 162 Mbps                      40249
    Rx HT 175.5 Mbps                    125030
    Rx HT 195 Mbps                      9913
    Rx HT 216 Mbps                      22627
    Rx HT 234 Mbps                      58665
    Rx HT 243 Mbps                      691
    Rx HT 260 Mbps                      5475
    Rx HT 270 Mbps                      2
    Rx VHT 29.3 Mbps                    12660
    Rx VHT 32.5 Mbps                    3385
    Rx VHT 87.8 Mbps                    136235
    Rx VHT 263.3 Mbps                   58142
    Rx VHT 292.5 Mbps                   68777
    Rx VHT 325 Mbps                     25548
    Rx VHT 351 Mbps                     84439
    Rx VHT 390 Mbps                     213838
    Rx VHT 433.3 Mbps                   108157
    Rx VHT 468 Mbps                     3813
    Rx VHT 526.5 Mbps                   704
    Rx VHT 585 Mbps                     327
    Rx VHT 702 Mbps                     39
    Rx VHT 780 Mbps                     155
    Rx VHT 866.7 Mbps                   7238
    Rx WMM [BK]                         72538
    Rx WMM [BE]                         3377971
    Rx WMM [VI]                         201742
    Rx WMM [VO]                         90953
    RX bad length                       0
    Rx Null Src MAC                     28539
    -------------------                 SLB
    SLB: Total Clients Found            0
    SLB: Assoc Requests Refused         0
    Rx Data Frames TxBF                 106
    Throttle drops                      0
    Stop all but Mgmt                   0
    CCA percentage of our bss           1
    CCA percentage of other bss         0
    CCA percentage of interference      0
    MU-NDPA frames Tx failed            0
    MU-NDP frames Tx failed             0
    MU Sequences posted                 0
    Client swap with pkt drop           0
    Client swap pkt drop frames         0
    ANUL RADIO Stats
    Parameter                   Value
    ANUL Assoc Rejects          0
    ANUL Auth Rejects           0
    ANUL Dos STA Rejects        0
    ANUL Auth Throttle Rejects  0
    ANUL Max STA Rejects        0
    show ap debug radio-stats ap-name "AP225-G-frecuency-Issues" radio 1 advanced
    RADIO Stats
    Parameter                           Value
    External Reset                      0
    Chainmask Reset                     0
    TX stat Reset                       0
    TX Power Changes                    5
    Channel Changes                     2
    Current Noise Floor                 96
    11g Protection                      1
    Last TX Antenna                     0
    Last RX Antenna                     0
    Scan Requests                       318059
    Scan Rejects                        5200
    Load aware Scan Rejects             0
    Any help is welcome.
  • 15.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 27, 2017 03:16 PM
    Help for what?
    Radio resets occur when there is severe interference, which happens every now and then.  If you think you have an issue, please open a case with TAC who will gather information and determine the best course of action.
  • 16.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 27, 2017 03:36 PM
    A few resets from time to time can be caused by interference. The issue we are seeing results in 1 reset every 2 seconds. It happens only on the 2.4Ghz radio.
    Aside from verification through the logs, you can visit the AP location, switch off your 5Ghz client radio, and verify that there is no way to associate with the AP before the 2.4Ghz radio resets again. If you have something like splunk, you can find APs that generate thousands of radio resets every hour.
    The 2.4Ghz radio on the AP will be unusable until you perform a full reboot. After that point, it will work fine for days or weeks into the future (we haven't determined how long it is before or even if this problem will return or if it happens randomoly to APs). Aruba tech support is aware of this issue in certain trains of code and we are sending log information to assist the development team in diagnosing the problem.
    Again though, if you see less than 1,000 resets per hour, you do not have this problem. This issue will generate well over 1,000 radio resets, per AP, per hour.
    Finally, the 5Ghz radio continues to work. As such, we have only a few examples of this actually affecting clients. Most use the 5Ghz radio or roam to another 2.4 nearby.
  • 17.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 27, 2017 03:51 PM
    Yes... same pattern... as i wrote (BTW: I have the same version: 6.5.0.3 and 80% are AP-225 model).
    I just try to explain my analisys over the "sh ap tech-support ap-name APwiththisissue" output were I got 246,575 22.4GHz radio resets!!
    and saw it directly (no splunk) the key lines:
    #reset: !!!BIG-hammer!!!
    #wl1: fatal error, reinitializing
    #wl1: ap watchdog handler error
    Best regards.
  • 18.  RE: IAP-205 wireless interface restarts (wlc_reset)
    Posted Jan 27, 2017 05:09 PM
    Best regards.
    Please open a tac case.  You could have a different issue than the person who opened this thread.
