IAP 205 with Hotspot manager and vouchers for guest access
  • 1.  IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 07:26 AM
    Hi
    I would like to have a wireless solution for the company using IAP205 with controller or controllerless. I need to have a prefessional hotspot manager (vouchers for guest access) as well.
    I had used IAP105 but they dont have this feature. I appreciate any helpful direction to achieve the goal.
    Thanks for your support.
  • 2.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 07:38 AM
    ClearPass is what you're looking for. You can accomplish this with controller or controllerless.
  • 3.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 07:41 AM
    Thanks for the quick reply.
    Clearpass is an addon or separate product? How it integrates with Aruba? I appreciate the details. Thanks again.
  • 4.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 08:42 AM
    ClearPass in An Authentication server (Phisic or Virtual) , it contain a module Called ClearPass Guest , that permit the generation guest vocher without the need of the controleur .
  • 5.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 09:54 AM
    Thank you for the details.
    So, i will redirect the guest control to the clearpass from the Aruba consol? Is there any solution from Aruba itself to handle this?
  • 6.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 10:15 AM
    For Aruba AP with controller yes, you can use the build in Captive Portal and you can generate temporary user in the local data base
    But for the IAP you can create Guest account manually, and of course you have to delete them manually too.
    So honestly if you have many guest, you have to buy a Guest management Solution, but if you have you haven’t you can use the Instant AP built In captive portal.
  • 7.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 10:20 AM
    ClearPass is a policy engine. Please work with your Aruba partner to design a solution.
  • 8.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 10:29 AM
    you can also lease a cloud services
  • 9.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 11:33 AM
    I would like to have an on-premise solution. clearpass has this?
  • 10.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 11:38 AM
    yes ClearPass is an On Promise Policy Engine Appliance.
  • 11.  RE: IAP 205 with Hotspot manager and vouchers for guest access
    Posted Jun 12, 2016 11:39 AM
    Yes. Please work with your Aruba partner.
