IAP 205 won't add to Virtual Controller, radio lights remain yellow.
  • 1.  IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 06, 2017 12:03 PM
    I currently have a mixed Aruba network of IAP 105's and IAP 205's.  Firmware for both are 6.4.4.8-4.2.4.4_57496 (just recently updated.)  I just got in 3 new IAP 205's and all of them when plugged into POE boot up and come up with PWR - Green, ENET - Green Flashing, 5GHz - yellow, 2.4GHz - yellow.  They do get an IP address, when I go to the web console on their IP address, it forwards me to the virtual controller.  They do not show up on the virtual controller, and they appear to not get any information from the controller.
    Following is the putty output from boot up.
    APBoot 1.5.3.14 (build 45815)
    Built: 2014-09-05 at 11:23:04
    Model: AP-20x
    CPU: BCM53011/15, revision A0
    I2C: ready
    SKU: 2
    OTP: 0xeca01028
    Clock:
    CPU: 800 MHz
    DDR: 533 MHz
    AXI: 400 MHz
    APB: 200 MHz
    PER: 400 MHz
    DRAM: 128 MB
    POST1: memory passed
    SF: Detected MX25L25635E with page size 4 kB, total 32 MB
    Flash: 32 MB
    PCIe0: RC, link up
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 14e4 4360 00002 03 08000004 00000000 00000000 00000000
    PCIe1: RC, link up
    00 00 14e4 4360 00002 03 40000004 00000000 00000000 00000000
    Power: POE
    Net: eth0
    Radio: bcm43460#0, bcm43460#1
    **** Configuration Reset Requested by User ****
    Clearing state... Checking OS image and flags
    Image is signed; verifying checksum... passed
    Preserving image partition 0
    Erasing flash sector @ 0x1ff80000....done
    Erased 1 sectors
    Erasing flash sector @ 0x1ff90000....done
    Erased 1 sectors
    Erasing flash sector @ 0x1ffb0000....done
    Erased 1 sectors
    Erasing flash sector @ 0x1ffc0000....done
    Erased 1 sectors
    Erasing flash sector @ 0x1ffd0000....done
    Erased 1 sectors
    done
    Purging environment... Erasing flash...Writing to flash..................done
    done
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0x1e100000
    Copying image from 0x1e100000
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Uncompressing... done
    [ 0.000000]
    [ 0.000000] Aruba Networks
    [ 0.000000] ArubaOS Version 6.4.2.6-4.1.1.6 (build 50009 / label #50009)
    [ 0.000000] Built by p4build@tortuga on 2015-05-12 at 10:27:51 PDT (gcc version 4.7.2)
    [ 0.000000]
    [ 0.000000] Flash variant: variant0
    [ 0.000000] MPCORE found at 19020000, SCTLR 0x10c53c7f ACTLR 0x00000040 CPSR 0x600001d3 SPSR 0xc0000217 PRRR 0x000a81a8 NMRR 0x40e040e0
    [ 0.000000] Memory: 128MB = 128MB total
    [ 0.000000] Memory: 117688k/117688k available, 13384k reserved, 0K highmem
    [ 0.052000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    [ 5.336000] PMU: registered new PMU device of type 0
    [ 5.842000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
    [ 5.844000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
    [ 5.846000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
    [ 6.348000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
    [ 6.350000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
    [ 6.352000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
    [ 6.698000] i2c-springbank: using remapped base c8914060
    [ 6.702000] mpcore_wdt mpcore_wdt: enabling watchdog.
    [ 6.706000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
    [ 6.708000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
    [ 6.710000] Creating 1 MTD partitions on "spi1.0":
    [ 6.712000] 0x000000000000-0x000002000000 : "qspi"
    [ 6.716000]
    [ 6.716000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 6.720000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 6.734000] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 6.738000] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 6.740000]
    Domain Name: instant.arubanetworks.com
    No panic info available
    apfcutil: sector CACHE: Cache uninitialized
    apfcutil: sector RAP: Cache uninitialized
    apfcutil: sector FAT: Cache uninitialized
    apfcutil: sector SCRATCH: Cache uninitialized
    Check backup ENV.
    apfcutil: sector MESH Prov: Cache uninitialized
    Cfg len is 0
    Configuration file is empty, turning on default services...
    extended ssid activate due to no AP config ...
    [ 14.640000] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [ 16.644000] bond0: link up (1000FD)
    [ 16.648000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    Mesh is DISABLED on this device.
    Disabling wpa_supplicant for this paltform
    [ 17.714000] AP xml model 81, num_radios 2 (jiffies 8857)
    [ 17.716000] init_asap_mod: installation:0
    [ 17.718000] radio 0: band 1 ant 0 max_ssid 16
    [ 17.720000] radio 1: band 0 ant 0 max_ssid 16
    [ 17.722000] election init: rand=13 HZ=500
    [ 17.724000] IAP client match init
    notify asap_mod 3g no present...
    Starting watchdog process...
    Getting an IP address...
    Dec 31 16:00:19 udhcpc[1359]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:19 udhcpc[1359]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:19 udhcpc[1359]: Sending discover...
    Dec 31 16:00:19 udhcpc[1359]: send_selecting: pkt num 0, secs 0
    Dec 31 16:00:19 udhcpc[1359]: Sending select for 192.168.6.84...
    Dec 31 16:00:19 udhcpc[1359]: Lease of 192.168.6.84 obtained, lease time 259200
    Dec 31 16:00:19 udhcpc[1359]: DHCP OPT 43 deleted airwave config
    Dec 31 16:00:19 udhcpc[1359]: DHCP OPT 66/67: tftp 192.168.0.170 undionly.0
    bootstrap file download starting ...
    192.168.6.84 255.255.0.0 192.168.0.1
    Compressing all files in the /etc/httpd directory...
    [ 22.736000] ip_time_handler: Got ip and packets on bond0 Started master election 680-0, rand 17
    [ 23.128000] Adding bridge entry for magic vlan GW, ifindex 8450, d8:c7:c8:ca:fe:cb
    [ 23.130000] (00:00:25) !!! Init ---> Slave
    tftp: timeout
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    [ 24.842000] wifi0: AP type AP-205, radio 0, max_bssids 16
    [ 24.888000] wifi1: AP type AP-205, radio 1, max_bssids 16
    shutting down watchdog process (nanny will restart it)...
    Completed SW FIPS KAT test
    <<<<< Welcome to the Access Point >>>>>
    User: tftp: timeout
    tftp: timeout
    tftp: timeout
    tftp: timeout
    tftp: last timeout
    [ 44.626000] asap_send_elected_master: sent successfully
    [ 44.646000] process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
    [ 44.748000] wait for stm to initialize over
    [ 44.750000] asap_send_elected_master: sent successfully
    [ 49.714000] turn off mobility
    [ 50.586000] (16:23:26) !!! Init ---> Slave
  • 2.  RE: IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 06, 2017 12:17 PM
    Try upgrading a new 205 on a separate network to 6.4.4.8-4.2.4.4_57496 and then try to join the cluster.  I am not sure it will upgrade to the cloud if it is not GA code.
  • 3.  RE: IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 10, 2017 10:28 AM
    As suggested, Firmware updated to 6.4.4.8-4.2.4.4_57496, the exact same as my aruba networks virtual server claims to be.  Now I get green Pwr, Green Enet and no lights for either radio.  It connects to the network, it gets an IP, going to that IP redirects me to the Aruba Virtual Server.  But I get nothing from the AP.  I have 63 AP's on my Virtual server, far fewer than I have heard claims that can be handled.  Any more ideas?  BTW, thank you for your input.
    Model: AP-20x
    I2C: ready
    SKU: 2
    OTP: 0xeca01028
    Clock:
    CPU: 800 MHz
    DDR: 533 MHz
    AXI: 400 MHz
    APB: 200 MHz
    PER: 400 MHz
    DRAM: 128 MB
    Flash: 32 MB
    PCIe0: RC, link up
    PCIe1: RC, link up
    Power: POE
    Net: eth0
    Booting OS partition 0
    Signer Cert OK
    Policy Cert OK
    [ 0.000000]
    [ 0.000000] ArubaOS Version 6.4.4.8-4.2.4.4 (build 57496 / label #57496)
    [ 0.000000] Built by p4build@samos on 2016-11-28 at 01:31:47 PST (gcc version 4.7.2)
    [ 0.000000]
    [ 0.000000] MPCORE found at 19020000, SCTLR 0x10c53c7f ACTLR 0x00000040 CPSR 0x600001d3 SPSR 0x01038297 PRRR 0x000a81a8 NMRR 0x40e040e0
    [ 0.000000] Memory: 116764k/116764k available, 14308k reserved, 0K highmem
    [ 0.046000] khelper used greatest stack depth: 7032 bytes left
    [ 0.058000] khelper used greatest stack depth: 6704 bytes left
    [ 5.706000] PMU: registered new PMU device of type 0
    [ 6.214000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
    [ 6.216000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
    [ 6.218000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
    [ 6.722000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
    [ 6.724000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
    [ 6.726000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
    [ 7.030000] cryptomgr_test used greatest stack depth: 6560 bytes left
    [ 7.032000] cryptomgr_test used greatest stack depth: 6516 bytes left
    [ 7.034000] cryptomgr_test used greatest stack depth: 5776 bytes left
    [ 7.076000] i2c-springbank: using remapped base c8914060
    [ 7.080000] mpcore_wdt mpcore_wdt: enabling watchdog.
    [ 7.082000] ramzswap: num_devices not specified. Using default: 1
    [ 7.084000] ramzswap: Creating 1 devices ...
    [ 7.090000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
    [ 7.092000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
    [ 7.094000] Creating 1 MTD partitions on "spi1.0":
    [ 7.096000] 0x000000000000-0x000002000000 : "qspi"
    [ 7.108000]
    [ 7.108000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 7.112000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 7.126000] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 7.130000] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 7.132000]
    Thu Jan 1 00:00:00 PST 1970
    AP-type has_ble_support: .
    Backup ENV.
    [ 14.104000] busybox used greatest stack depth: 5500 bytes left
    Cfg len is 2516
    Loading configuration file of length 2516...
    wifi uplink not present...
    extended ssid config detected...
    Terminal access enabled...
    factory default SSID detected...
    extended ssid activate due to no valid ssid ...
    [ 18.380000] ADDRCONF(NETDEV_UP): bond0: link is not ready
    Ethernet uplink not active yet
    [ 20.384000] bond0: link up (1000FD)
    [ 20.386000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    copying bootuplog ...
    [ 20.792000] AP xml model 81, num_radios 2 (jiffies 10396)
    [ 20.794000] init_asap_mod: installation:0
    [ 20.796000] radio 0: band 1 ant 0 max_ssid 16
    [ 20.798000] radio 1: band 0 ant 0 max_ssid 16
    [ 20.800000] election init: rand=16 HZ=500
    [ 20.802000] IAP client match init
    allow PAPI
    apdot1x authentication is not enabled
    Jan 1 00:00:14 udhcpc[1648]: udhcpc (v0.9.9-pre) started
    Jan 1 00:00:14 udhcpc[1648]: send_discover: pkt num 0, secs 0
    Jan 1 00:00:14 udhcpc[1648]: Sending discover...
    Jan 1 00:00:14 udhcpc[1648]: send_selecting: pkt num 0, secs 0
    Jan 1 00:00:14 udhcpc[1648]: Sending select for 192.168.6.84...
    Jan 1 00:00:14 udhcpc[1648]: Lease of 192.168.6.84 obtained, lease time 259200
    Jan 1 00:00:14 udhcpc[1648]: DHCP OPT 43 deleted airwave config
    Jan 1 00:00:14 udhcpc[1648]: DHCP OPT 66/67: tftp 192.168.0.170 undionly.0
    [ 25.808000] ip_time_handler: Got ip and packets on bond0 Started master election 511-0, rand 21
    [ 26.010000] Adding bridge entry for magic vlan GW, ifindex 8450, 70:3a:0e:c4:f1:2c
    [ 26.012000] (08:00:19) !!! Init ---> Slave
    Done.
    Starting Webserver
    [ 28.872000] wifi0: AP type AP-205, radio 0, max_bssids 16
    [ 28.946000] wifi1: AP type AP-205, radio 1, max_bssids 16
    [ 29.012000] busybox used greatest stack depth: 5296 bytes left
    [ 29.318000] ramzswap: Disk size set to 63488 kB
    [ 29.320000] ramzswap: Device already initialized!
    [ 29.326000] Adding 63484k swap on /dev/ramzswap0. Priority:-1 extents:1 across:63484k SS
    cat: /proc/reboot_reason: No such file or directory
    User: [ 49.870000] asap_send_elected_master: sent successfully
    [ 50.418000] wait for stm to initialize over
    [ 50.420000] asap_send_elected_master: sent successfully
    [ 55.020000] turn off mobility
    [ 55.274000] (15:19:04) !!! Init ---> Slave
  • 4.  RE: IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 10, 2017 10:43 AM
    The 3 new AP-205s that you got, are they they "US", "Israel" or "Unrestricted" parts?
  • 5.  RE: IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 10, 2017 10:48 AM
    Well, I'm in the US, and they were ordered through a USA reseller??
    Model: APIN0205
    Tag claims it is an IAP-205-JP, made in china.
  • 6.  RE: IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 10, 2017 10:54 AM
    You have a JP or Japanese version, which will not connect to a cluster that is a US version.  You should ask the reseller to return the APs so that you can get an IAP-205-US or JW213A (HPE Part) as it is now known.  http://www.arubanetworks.com/assets/og/OG_AP-200Series.pdf
    The version is not related to where the part is manufacturered, but what countries it is approved for.  A cluster approved for a different country will not allow an AP model approved for a different country to attach.  The "turn of mobility" message in your log indicates a regulatory domain mismatch.
  • 7.  RE: IAP 205 won't add to Virtual Controller, radio lights remain yellow.
    Posted Jan 10, 2017 11:38 AM
    That was it, thank  you sir.  When I mentioned the -JP the sales rep knew what the issue was too.  I will remember to look for that from now on.
