IAP-205H
  • 1.  IAP-205H
    Posted Nov 22, 2016 09:33 AM
    We have recently purchased several Aruba IAP-205H models for use in our remote sites. At some of the sites we need to connect the IAP-205H to the campus site via 4G USB modem. In our older RAP-155 models we used to set the 4G USB settings with the following CLI command on the controller:
    conf t
    provision-ap
    read-bootinfo ap-name "RAP-155Name"
    usb-type huawei-cdc
    usb-dev 0x12d11506
    cellular_nw_preference auto
    link-priority-cellular 8
    link-priority-ethernet 1
    reprovision ap-name "RAP-155Name"
    My question therefore is what would I use for the usb-dev code in the case of the IAP-205H ?
    Many thanks in advance.
    Regards Peter
  • 2.  RE: IAP-205H
    Posted Nov 22, 2016 09:37 AM
    Are you using them as IAPs or RAPs?
  • 3.  RE: IAP-205H
    Posted Nov 22, 2016 09:51 AM
    Hi Tim,
    We will be using them as RAPS, to coonnect up to the central Campus Controller.
    Regards Peter
  • 4.  RE: IAP-205H
    Posted Nov 22, 2016 09:53 AM
    Is your controller on 6.5? This new version allows for autoconfiguration of
    most LTE modems.
  • 5.  RE: IAP-205H
    Posted Nov 22, 2016 09:59 AM
    Hi Tim,
    Our controller runs on version 6.4X, but would be able to upgrade to 6.5 during the next service window.
    Regards Peter
