IAP 205US and 303H Compatibility
  • 1.  IAP 205US and 303H Compatibility
    Posted Feb 07, 2018 11:17 AM
    Hi Guys,
    We have 4 IAP 205US instant access points. since they are at the end of the line now, we will have to just go with 303H's.  You're all a smart group of wireless users, I wanted to ask you if the two models can work together and be able to cluster without any issues?
  • 2.  RE: IAP 205US and 303H Compatibility
    Posted Feb 07, 2018 08:23 PM
    As long as they're all on 6.5.2 code or later, you should be fine.
  • 3.  RE: IAP 205US and 303H Compatibility
    Posted Feb 08, 2018 11:24 AM
    How do I check that? Is it what I attached in the attachement.
  • 4.  RE: IAP 205US and 303H Compatibility
    Posted Feb 08, 2018 02:47 PM
    Yup. Looks like you're going to have to upgrade your firmware version. 6.4.2.6-4.1.1.13 will not support 303H (need 6.5.2.0 or later), and all units in the cluster need to run the same version.
