IAP-207 admin access after vlan setup
  • 1.  IAP-207 admin access after vlan setup
    Posted Jan 04, 2020 02:06 PM
    Hello guys,
    we are using IAP-207 devices for our WiFi network, latest 6.5.4 firmware.
    I have misconfigured something in probably the System tab on the GUI, where there was something about default VLAN for management and set the VLAN where the IAPs have their management IP. Previous to that the field was empty. Now I am not able to access the admin GUI anymore, neither SSH but the clients can connect to the WiFi networks and use them both (having different VLANs) for internet.
    Can you please guide me how to restore connectivity to the IAPs?
  • 2.  RE: IAP-207 admin access after vlan setup
    Posted Jan 06, 2020 04:30 AM
    You probably could from your switches add the management VLAN as a tagged VLAN to all of your APs to restore remote management, or use a serial console cable to connect to the CLI and remove the management VLAN configuration (you might need to do that on each of your APs as the configuration may not sync if the APs can't communicate over the management VLAN).
