iap 207 unable to authenticate after configuration
  • 1.  iap 207 unable to authenticate after configuration
    Posted Nov 30, 2017 09:52 AM
    hello,
    i have an issue that i don t understand
    i've 6 iap 207
    1 Switch
    4 wired poe and 2 for mesh
    firmware used are 6.5.4.3
    I ve created one ssid. i haven't change the admin's password for the moment.
    all is ok but when i'm cut  off 1 or 2 access points, others access points lose radio signal ( led is off ). when i want to connect to the powerred access points with ip adress, web interface is ok but i'm unable to enter to the configuration. ( username and password incorrect )
    have you an idea ?
    i've this issue with extended ssid on or off ...
    thank you
  • 2.  RE: iap 207 unable to authenticate after configuration
    Posted Dec 04, 2017 03:46 AM
    hello
    have you an idea ?
