We use IAP-207 within our product. Usually we have about 20-30 clients.
These clients are IOT devices exactly ESP8266.
Each client produces small amount of traffic about 1-2Kb per second.
Everything worked fine so far.
Recently we equipped new object having 59 clients. The object is the square room with
aprox 20x10 meter sides. We installed AP under the ceil horizontally.
We encountered a weiried issue. Few times a day the network stucks, connection between clients and AP
drops for about 10-60 seconds. After that comes period within few hours when connection is stable.
Then the issue repeats. I tried to reduce transmit power min/max = 6/9db.
I investiaged aruba configuration and the default settings seems look good.
We decided to buy IAP-315 with spectrum analysis feature
to exclude the external non-wifi RF sources.
So, could you please suggest an idea or something to resolve the issue?
Thanx in advance.
