In a company I am using 03 IAP 207 RW (firmware 8.3.0.10) managed with the virtual controller and everything works well. Can I add an IAP-303 RW to the virtual controller? I did a test but in the VC the access poit 303 is seen with the red mac address.
thanks
Cristiano
It looks like Cluster should be upgraded. Did you check any error in the dashboard.
I'm doing the configuration remotely and certainly the AP-303 has a more recent firmware version of the 207 ...I have a warning and an error of which I attach image.Thank you
All APs in a cluster need to be running the same firmware version.
I could not determine the version running from the attached screenshots. What version is the existing IAP-207 cluster running, and what version is the IAP-303 trying to run?
https://www.arubanetworks.com/assets/ds/DS_AP303Series.pdf
