  • 1.  IAP-214-RW
    Posted Sep 19, 2016 09:48 AM
    Could someone confirm whether a customer needs to use all 3 antenna connectors on this AP or can they just use 2?
    Jamie.
  • 2.  RE: IAP-214-RW
    Posted Sep 19, 2016 10:05 AM
    I assume 3 antenna's would give it the 3 spatial streams it is designed for, so if they just installed 2 antennas that would give them 2 spatial streams, is that the right assumption?
  • 3.  RE: IAP-214-RW
    Posted Sep 20, 2016 05:24 AM
    Yes, you will need to connect all three connectors, as leaving them open will damage the radio's.
    IF you just want to connect two antenna elements, you should have a so-called terminator (example: http://www.digikey.com/catalog/en/partgroup/rp-sma/23723) to prevent the radio from being damaged.
    And then, yes, with just two antenna elements that RF performance will be reduced to a maximum of 2 spatial streams.
    Also make sure that the antennas you install are part of the same antenna system; so you can't install two separate antenna's and point them to different directions as it will result in very strange behavior. The three antenna connection are on the same radio (different radio chains though).
    Please contact your partner or local Aruba SE if you seek advice.
