IAP-215 doesn't send Instant SSID even after reset button.
  • 1.  IAP-215 doesn't send Instant SSID even after reset button.
    Posted Mar 30, 2017 04:07 AM
    Hi
    Even after I reset button to initialize IAP-215, I can never see "Instant" SSID.
    Is there any configuration not be deleted by even a reset button?
    The LED after boot up with reset button is shown below.
    https://www.fastpic.jp/viewer.php?file=1955610713.jpg
    Without seeing an Instant SSID, I can't configure this IAP.
    What else can I configure?
    Four IAP-215 is same symptom, so it is not a hardwere failure.
    Regards
    Simon
  • 2.  RE: IAP-215 doesn't send Instant SSID even after reset button.
    MVP EXPERT
    Posted Mar 30, 2017 04:10 AM
    Hey, can you confirm the IAP is obtaining an IP address? Set up a DHCP server and plug in a console cable to confirm an IP address is being assigned.
  • 3.  RE: IAP-215 doesn't send Instant SSID even after reset button.
    Posted Apr 12, 2017 04:23 AM
    I should have connected to DHCP server.. Thanks.
  • 4.  RE: IAP-215 doesn't send Instant SSID even after reset button.
    Posted Mar 30, 2017 12:16 PM
    Hi Simon,
    If you know the IP address assigned to this IAP, you can access the WebUi of this IAP from a wired machine by typing the IP address in the web browser.
