IAP 215 Firmware has Taurus instead of Centaurus
  • 1.  IAP 215 Firmware has Taurus instead of Centaurus
    Posted Jun 06, 2023 02:24 PM
    Good Afternoon Folks,
    I've been using IAP215s for my two offices for some time now. They've always wanted a Centaurus firmware. I just bought 4 more of them and 3 of them came with Centaurus while the 4th came with Taurus 6.5.4.9_67129 on it. When I try to feed it the Centaurus update, expectedly, it rejects it. My older 205 APs had Taurus on them.
    Is there a way to force the upgrade?
    I've already tried:
    IAP web UI Firmware upgrade
    copy files via tftp, however the command seems broken, I can copy them to flash but not to one of the system partitions, the partition flag just doesn't exist.
    factory reset by interrupting the boot process and issuing factory-reset and then reset.
  • 2.  RE: IAP 215 Firmware has Taurus instead of Centaurus
    Posted Jun 06, 2023 07:01 PM
    this is wierd. perhaps you can interrupt the boot process and then upgrade it from there. Have you tried that?
  • 3.  RE: IAP 215 Firmware has Taurus instead of Centaurus
    Posted Jun 07, 2023 08:30 AM
    It gets even wierder. I left it up overnight and when I came it it was running the version of centaurus I was trying to upgrade it to. I'm literally a one man shop and it didn't have internet access. I guess one of the update methods I tried actually did work even though it said it didn't?
