IAP-215 insufficient POE voltage
  • 1.  IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 04:03 PM
    I am trying to add a 3rd IAP-215 to my network, but the device is not able to be contacted via the GUI.   upon connecting to the unit via serial cable, i found it was continually rebooting after failing at ADP.   Further tinkering (and adding a local dns entry for aruba-master) allowed the device to boot, but then stated an "insuffcient POE voltage" error.   I am still unable to get the unit online, and cannot get to the GUI.
    Full boot output is below.   Any suggestions?
    APBoot 1.5.3.9 (build 43867)
    Built: 2014-05-21 at 19:31:10
    Model: AP-21x
    CPU:   P1010E, Version: 1.0, (0x80f90010)
    Core:  E500, Version: 5.1, (0x80212151)
    Clock:
           CPU0: 800 MHz
           CCB:  400 MHz
           DDR:  400  MHz (800 MT/s data rate) (Asynchronous)
           LBC:   unknown (LCRR[CLKDIV] = 0x00)
    L1:    D-cache 32KB enabled
           I-cache 32KB enabled
    I2C:   ready
    DRAM:  Configuring DDR for 800 MT/s data rate
    DDR:   256 MB (DDR3, 32-bit, CL=6, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2:    256 KB enabled
    Power: 802.3af POE
    PCIe1: RC, link up, x1
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  14e4  4360 00002   03 80000004 00000000 00000000 00000000
    PCIe2: RC, link up, x1
           00  00  14e4  4360 00002   03 a0000004 00000000 00000000 00000000
    Net:   eth0
    Radio: bcm43460#0, bcm43460#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xee000000
    Invalid image format version: 0xffffffff
    Checking image @ 0xeee00000
    Copying image from 0xeee00000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [    0.000000] Flash variant: variant0
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.4.1.0 (build 43882 / label #43882)
    [    0.000000] Built by p4build@cyprus on 2014-05-22 at 14:24:44 PDT (gcc version 4.5.1)
    [    0.000000]
    [    0.000000] P1010 RDB board from Freescale Semiconductor
    [    0.000000] Memory: 250004k/262144k available (8904k kernel code, 12140k reserved, 496k data, 358k bss, 5512k init)
    [    0.001488] Brought up 1 CPUs
    [    0.077622] PCI: Probing PCI hardware
    [    0.120670] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [    0.183575] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    [    0.245798] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [    0.320369] pci 0001:02:00.0: not setting up bridge for bus 0001:03
    [    4.190397] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    [    4.295220] Kprobe smoke test started
    [    4.345143] Kprobe smoke test passed successfully
    [    4.506044] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    [    4.581086] Amd/Fujitsu Extended Query Table at 0x0040
    [    4.642577] number of CFI chips: 1
    [    4.686978] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
    [    4.769341] gfar_probe: Renaming interface to bond0
    [    4.828105] /proc/gfar_bond0_stats created
    [    4.890185] Enabling watchdog on CPU 0
    [    4.938543] Disabled fips elf aesccm selftest
    [    4.990768]
    [    4.990772] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [    5.082512] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [    5.172186] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    5.244136] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    5.287930]
    [    5.333795] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
    [    5.429100] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
    [    5.532310] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
    [    5.636463] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
    [    5.740595] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
    [    5.837878] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
    Domain Name: arubanetworks.com
    No panic info available
    [    7.010219] AP xml model 84, num_radios 2 (jiffies 3332)
    [    7.073834] init_asap_mod: installation:0
    [    7.121775] radio 0: band 1 ant 0 max_ssid 16
    [    7.173879] radio 1: band 0 ant 0 max_ssid 16
    Starting watchdog process...
    Getting an IP address...
    [    9.477829] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [   40.521783] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
    [   40.595850] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    192.168.1.158 255.255.255.0 192.168.1.1
    Running ADP...Done. Master is 192.168.1.7
    [   96.485490] wifi0: AP type AP-215, radio 0, max_bssids 16
    [   96.581322] Shutting down 2 2.4G radio TX/RX chains due to insufficient POE voltage[power profile 2]
    [   96.702521] wifi1: AP type AP-215, radio 1, max_bssids 16
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
  • 2.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 04:05 PM
    What kind of switch are you using,?
  • 3.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 04:08 PM
    The switch is a Netgear GS724TP
  • 4.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 09:10 PM
    That switch only supports 802.3af.  Do you know how many other devices you are powering?
  • 5.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 09:14 PM
    The only other devices are (2) other iap 215 access points. I have also tried powering with a POE+ injector and got the Sam result.
  • 6.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 09:37 PM
    What make and model POE injector?
  • 7.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 10:05 PM
    I have two different injectors, each with the same result:
    TrendNET TPE 115GI
    And a
    ws‑gpoe‑6
    Michael De Cou
    Industry Standard Servers
    Hewlett Packard Enterprise
    (908) 963-6969
    michael.decou@hpe.com
  • 8.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 11:11 PM
    Don't connect the POE injector to a POE enabled switch port. Injectors are passive and will not 'take over' for the switch. So you can either connect the injector to a non-POE enabled port, or disable POE on that port.
    Second, check/replace/test other cables. The AP-215 doesn't require 802.3at, and should run on af power, but if the cable is leading to excessive voltage drop/loss, then it can report that on the 215.
    Finally if using the injectors on non-POE ports doesn't work, and multiple cables report the same issue, then you can open a TAC case to see about a replacement.
  • 9.  RE: IAP-215 insufficient POE voltage
    Posted Jan 21, 2017 10:08 PM
    TrendNET TPE 115GI
    And a
    ws‑gpoe‑6
