IAP-215 kind of died, can't convert to CAP.
  • 1.  IAP-215 kind of died, can't convert to CAP.
    Posted Feb 12, 2018 08:57 AM
    Mobility Controller 7205. Some 30 IAP-215 in CAP-mode. 6.5.4.2 software.
    I got reports that wifi-connectivity was down in one room, and I remembered that the AP had frozen a while back. This time it responded to ping, but was otherwise unusable and radio was down. I pulled the power, and after that it kept rebooting i a cycle of a few minutes.
    I replaced the AP, and tried resetting it. The AP is an IAP-model, so I could get into it again. After some fiddling about I realized that I was unable to convert it back to a CAP again as long as it has the same ip-address as before. Even when I deleted (cleared) the AP from the list in the controller.
    After configuring another IP-address for the AP I managed to get the AP to download a CAP-image from the controller, but now it has been sitting there with a blinking green power and booting for almost 20 minutes. It never shows up in the provisioning-list.
    Could there be something wrong with the AP, as in hardware-wise? I have converted a lot of AP's back and forth but this one seems strange and unwilling to perform.
    I got tired of waiting for it to boot, and pulled the plug. Now I'm back in the mode where I started. That is, it responds to a few (six) ping packets and the spontaniously reboots.
  • 2.  RE: IAP-215 kind of died, can't convert to CAP.
    MVP EXPERT
    Posted Feb 12, 2018 09:05 AM
    It could be a possible hardware fault, have you been able to attach a console cable a record the output? If so could you post it here?
  • 3.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 12, 2018 09:15 AM
    I'll have to do that.
  • 4.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 12, 2018 09:48 AM
    Ip address conflict?  Check to see if you can still ping that ip address when the AP is down...
  • 5.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 13, 2018 02:43 AM
    Looks to me there's a crash
    [ 50.919068] wifi0: AP type AP-215, radio 0, max_bssids 16
    [ 51.136303] aruba_usb_power_control:1136 en:1 status:0
    [ 51.197903] aruba_enable_usb_block:556 Enabled USB
    [ 51.255235] aruba_usb_power_control:1141 Enable USB power control for 214/215
    [ 51.340713] tomatin_usb_power_control:975 enable the USB
    [ 51.701067] wifi1: AP type AP-215, radio 1, max_bssids 16
    [ 51.979995] irq 18: nobody cared (try booting with the "irqpoll" option)
    [ 52.060217] Call Trace:
    [ 52.089410] [cfff1f40] [c000853c] show_stack+0x44/0x154 (unreliable)
    [ 52.165477] [cfff1f80] [c0084aac] __report_bad_irq+0x34/0xbc
    [ 52.233204] [cfff1fa0] [c0084d08] note_interrupt+0x1d4/0x230
    [ 52.300929] [cfff1fd0] [c0085aac] handle_fasteoi_irq+0xf4/0x13c
    [ 52.371787] [cfff1ff0] [c0010654] call_handle_irq+0x18/0x28
    [ 52.438472] [cc6798c0] [c0004684] do_IRQ+0xcc/0x18c
    [ 52.496823] [cc6798f0] [c0011320] ret_from_except+0x0/0x18
    [ 52.562868] --- Exception: 501 at read_radio_reg+0x104/0x1f8 [wl]
    [ 52.562871] LR = wlc_phy_switch_radio_acphy+0x112c/0x2748 [wl]
    [ 52.709884] [cc6799b0] [c90944c8] mod_radio_reg+0x24/0x50 [wl] (unreliable)
    [ 52.793361] [cc6799d0] [c905025c] wlc_phy_switch_radio_acphy+0x112c/0x2748 [wl]
    [ 52.881000] [cc679a50] [c90999f0] wlc_phy_switch_radio+0x2b0/0x3f8 [wl]
    [ 52.960304] [cc679a80] [c9097084] wlc_phy_init+0x168/0x588 [wl]
    [ 53.031285] [cc679ac0] [c919f8e4] wlc_bmac_set_extlna_pwrsave_shmem+0x28c/0xeb4 [wl]
    [ 53.124144] [cc679af0] [c919bf7c] wlc_bmac_init+0xdd4/0x20e8 [wl]
    [ 53.197215] [cc679b80] [c91bf088] wlc_init+0x130/0xfb8 [wl]
    [ 53.264032] [cc679c00] [c91b9330] wl_init+0x34/0x60 [wl]
    [ 53.327728] [cc679c10] [c91cc314] wlc_up+0x1d0/0x694 [wl]
    [ 53.392462] [cc679c40] [c91b948c] wl_up+0x58/0xbc [wl]
    [ 53.454082] [cc679c60] [c92a1f9c] aruba_wl_init_up+0x28/0x1f8 [wl]
    [ 53.528197] [cc679c80] [c92a2390] aruba_wl_init+0x224/0x714 [wl]
    [ 53.600223] [cc679ce0] [c91bcc20] wl_ams_forward_capture+0xc64/0x197c [wl]
    [ 53.682673] [cc679dc0] [c92f4b44] wl_pci_probe+0x134/0x27c [wl]
    [ 53.753530] [cc679dd0] [c0166f98] pci_device_probe+0x80/0xa4
    [ 53.821259] [cc679df0] [c018ce54] driver_probe_device+0xa4/0x1d4
    [ 53.893151] [cc679e10] [c018d040] __driver_attach+0xbc/0xc0
    [ 53.959839] [cc679e30] [c018bd58] bus_for_each_dev+0x60/0x9c
    [ 54.027569] [cc679e60] [c018cac0] driver_attach+0x24/0x34
    [ 54.092168] [cc679e70] [c018c620] bus_add_driver+0xb0/0x268
    [ 54.158857] [cc679ea0] [c018d2f4] driver_register+0x88/0x154
    [ 54.226588] [cc679ec0] [c0167258] __pci_register_driver+0x54/0xe4
    [ 54.299650] [cc679ee0] [c96402b4] init_module+0x2b4/0x318 [wl]
    [ 54.369462] [cc679ef0] [c0001ec4] do_one_initcall+0x3c/0x1d0
    [ 54.437197] [cc679f20] [c007fabc] sys_init_module+0xdc/0x1e0
    [ 54.504922] [cc679f40] [c0010cc8] ret_from_syscall+0x0/0x3c
    [ 54.571609] --- Exception: c01 at 0x4831cb90
    [ 54.571613] LR = 0x10027830
    [ 54.660168] handlers:
    [ 54.687262] [<c001ed38>] (fsl_ifc_ctrl_irq+0x0/0x1e4)
    [ 54.747714] Disabling IRQ #18
    [ 88.046858] BUG: soft lockup - CPU#0 stuck for 31s! [busybox:2122]
    [ 88.120826] Modules linked in: wl(+) asap_mod drvlog_mod(P)
    [ 88.187529] **bleep**: c9094cf0 LR: c9054d20 CTR: c9054cb4
    [ 88.246915] REGS: cc679980 TRAP: 0901 Tainted: P (2.6.35)
    [ 88.326092] MSR: 00029000 <EE,ME,CE> CR: 22004044 XER: 20000000
    [ 88.399058] TASK = ce0a1300[2122] 'busybox' THREAD: cc678000 CPU: 0 STACK FREE: 5088
    [ 88.489721] GPR00: 0000001f cc679a30 ce0a1300 c97c8000 000001b0 00008000 00008000 00000001
    [ 88.589786] GPR08: 00001c70 0000002a 00000000 d10303fe 28004042
    [ 88.664063] **bleep** [c9094cf0] phy_reg_mod+0xac/0x16c [wl]
    [ 88.725656] LR [c9054d20] wlc_phy_resetcca_acphy+0x288/0x600 [wl]
    [ 88.798581] Call Trace:
    [ 88.827762] [cc679a30] [caea0000] 0xcaea0000 (unreliable)
    [ 88.892489] [cc679a60] [c9054d20] wlc_phy_resetcca_acphy+0x288/0x600 [wl]
    [ 88.973879] [cc679a80] [c9097090] wlc_phy_init+0x174/0x588 [wl]
    [ 89.044860] [cc679ac0] [c919f8e4] wlc_bmac_set_extlna_pwrsave_shmem+0x28c/0xeb4 [wl]
    [ 89.137717] [cc679af0] [c919bf7c] wlc_bmac_init+0xdd4/0x20e8 [wl]
    [ 89.210782] [cc679b80] [c91bf088] wlc_init+0x130/0xfb8 [wl]
    [ 89.277600] [cc679c00] [c91b9330] wl_init+0x34/0x60 [wl]
    [ 89.341295] [cc679c10] [c91cc314] wlc_up+0x1d0/0x694 [wl]
    [ 89.406030] [cc679c40] [c91b948c] wl_up+0x58/0xbc [wl]
    [ 89.467649] [cc679c60] [c92a1f9c] aruba_wl_init_up+0x28/0x1f8 [wl]
    [ 89.541764] [cc679c80] [c92a2390] aruba_wl_init+0x224/0x714 [wl]
    [ 89.613790] [cc679ce0] [c91bcc20] wl_ams_forward_capture+0xc64/0x197c [wl]
    [ 89.696241] [cc679dc0] [c92f4b44] wl_pci_probe+0x134/0x27c [wl]
    [ 89.767099] [cc679dd0] [c0166f98] pci_device_probe+0x80/0xa4
    [ 89.834833] [cc679df0] [c018ce54] driver_probe_device+0xa4/0x1d4
    [ 89.906724] [cc679e10] [c018d040] __driver_attach+0xbc/0xc0
    [ 89.973414] [cc679e30] [c018bd58] bus_for_each_dev+0x60/0x9c
    [ 90.041144] [cc679e60] [c018cac0] driver_attach+0x24/0x34
    [ 90.105748] [cc679e70] [c018c620] bus_add_driver+0xb0/0x268
    [ 90.172431] [cc679ea0] [c018d2f4] driver_register+0x88/0x154
    [ 90.240161] [cc679ec0] [c0167258] __pci_register_driver+0x54/0xe4
    [ 90.313224] [cc679ee0] [c96402b4] init_module+0x2b4/0x318 [wl]
    [ 90.383037] [cc679ef0] [c0001ec4] do_one_initcall+0x3c/0x1d0
    [ 90.450771] [cc679f20] [c007fabc] sys_init_module+0xdc/0x1e0
    [ 90.518499] [cc679f40] [c0010cc8] ret_from_syscall+0x0/0x3c
    [ 90.585183] --- Exception: c01 at 0x4831cb90
    [ 90.585186] LR = 0x10027830
    [ 90.673742] Instruction dump:
    [ 90.709176] 7c0803a6 4e800020 393d03fc 7c0004ac 7fc04f2c 813f001c 81290014 3809fff5
    [ 90.801943] 2b800001 409d0050 397d03fe 7c0004ac <7c005e2c> 0c000000 4c00012c b0010008
  • 6.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 13, 2018 02:47 AM
    Hit <Enter> to stop autoboot: 0
    Booting OS partition 0
    Checking image @ 0xee000000
    Copying image from 0xee000000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [ 0.000000] Flash variant: variant0
    [ 0.000000]
    [ 0.000000] Aruba Networks
    [ 0.000000] ArubaOS Version 6.5.4.2 (build 61807 / label #61807)
    [ 0.000000] Built by p4build@lesbos on 2017-10-07 at 00:39:00 PDT (gcc version 4.5.1)
    [ 0.000000]
    [ 0.000000] P1010 RDB board from Freescale Semiconductor
    [ 0.000000] Memory: 248712k/262144k available (10060k kernel code, 13432k reserved, 612k data, 376k bss, 6520k init)
    [ 0.001500] Brought up 1 CPUs
    [ 0.078100] PCI: Probing PCI hardware
    [ 0.121203] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [ 0.184002] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    [ 0.246161] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [ 0.320848] pci 0001:02:00.0: not setting up bridge for bus 0001:03
    [ 4.923309] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    [ 5.143789] irq 17: nobody cared (try booting with the "irqpoll" option)
    [ 5.222960] Call Trace:
    [ 5.252138] [cfff1f40] [c000853c] show_stack+0x44/0x154 (unreliable)
    [ 5.328168] [cfff1f80] [c0084aac] __report_bad_irq+0x34/0xbc
    [ 5.395869] [cfff1fa0] [c0084d08] note_interrupt+0x1d4/0x230
    [ 5.463574] [cfff1fd0] [c0085aac] handle_fasteoi_irq+0xf4/0x13c
    [ 5.534406] [cfff1ff0] [c0010654] call_handle_irq+0x18/0x28
    [ 5.601064] [ce033d00] [c0004684] do_IRQ+0xcc/0x18c
    [ 5.659396] [ce033d30] [c0011320] ret_from_except+0x0/0x18
    [ 5.725025] --- Exception: 501 at _raw_spin_unlock_irqrestore+0x10/0x14
    [ 5.725029] LR = __setup_irq+0x168/0x368
    [ 5.855214] [ce033df0] [c0084488] __setup_irq+0x2c0/0x368 (unreliable)
    [ 5.933334] [ce033e10] [c0084630] request_threaded_irq+0x100/0x15c
    [ 6.007292] [ce033e40] [c02cc34c] fsl_ifc_ctrl_probe+0x1f4/0x2b4
    [ 6.079160] [ce033e60] [c01fcc20] of_platform_device_probe+0x50/0x90
    [ 6.155201] [ce033e80] [c018ce54] driver_probe_device+0xa4/0x1d4
    [ 6.227066] [ce033ea0] [c018b9d0] bus_for_each_drv+0x6c/0xa8
    [ 6.294770] [ce033ed0] [c018ccd8] device_attach+0xa4/0xc8
    [ 6.359349] [ce033ef0] [c018c468] bus_probe_device+0x2c/0x44
    [ 6.427053] [ce033f00] [c0189e0c] device_add+0x48c/0x5ec
    [ 6.490599] [ce033f50] [c01fc5e8] of_device_register+0x30/0x44
    [ 6.560380] [ce033f60] [c000a468] of_platform_device_create+0x44/0x74
    [ 6.637457] [ce033f70] [c000a690] of_platform_bus_probe+0x12c/0x154
    [ 6.712458] [ce033f90] [c037daf8] __machine_initcall_p1010_rdb_p1010rdb_publish_devices+0x38/0x48
    [ 6.818695] [ce033fa0] [c0001ec4] do_one_initcall+0x3c/0x1d0
    [ 6.886404] [ce033fd0] [c03759f0] kernel_init+0x1a4/0x268
    [ 6.950979] [ce033ff0] [c0010a38] kernel_thread+0x4c/0x68
    [ 7.015553] handlers:
    [ 7.042635] [<c001ed38>] (fsl_ifc_ctrl_irq+0x0/0x1e4)
    [ 7.103048] Disabling IRQ #17
    [ 7.284822] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    [ 7.359965] Amd/Fujitsu Extended Query Table at 0x0040
    [ 7.421456] number of CFI chips: 1
    [ 7.475882] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
    [ 7.558285] gfar_probe: Renaming interface to bond0
    [ 7.617149] /proc/gfar_bond0_stats created
    [ 7.717034] Enabling watchdog on CPU 0
    [ 7.763815] caam ffe30000.crypto: device ID = 0x0a14010000000000
    [ 7.835808] caam ffe30000.crypto: job queues = 4
    [ 7.891148] caam ffe30000.crypto: authenc-hmac-sha1-cbc-aes-caam
    [ 7.963173] caam ffe30000.crypto: authenc-hmac-sha256-cbc-aes-caam
    [ 8.037240] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des3_ede-caam
    [ 8.114462] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des3_ede-caam
    [ 8.193738] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des-caam
    [ 8.265742] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des-caam
    [ 8.344701] caam ffe30000.crypto: ccm-aes-caam
    [ 8.442882]
    [ 8.442887] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 8.534691] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 8.653631] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 8.725636] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 8.769433]
    [ 8.815302] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
    [ 8.910616] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
    [ 9.032543] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
    [ 9.155487] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
    [ 9.278450] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
    [ 9.413283] Starting Kernel AES-CCM FIPS KAT ...Completed Kernel AES-CCM FIPS KAT
    [ 9.513708] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
    AP-type has_ble_support: USB.
    Domain Name: arubanetworks.com
    No panic info available
    ardmore: Start hotplug
    Enabling ble_daemon via nanny
    [ 18.246837] AP xml model 84, num_radios 2 (jiffies 8951)
    [ 18.310483] apType 84 hw_opmode 0
    [ 18.350093] radio 0: band 1 ant 0 max_ssid 16
    [ 18.402204] radio 1: band 0 ant 0 max_ssid 16
    [ 18.513242] init_asap_mod: installation:0
    [ 18.887224] firewall cpu: core-0
    ardmore: Copying BT modules to /tmp
    Starting watchdog process...
    Getting an IP address...
    [ 23.139301] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [ 29.143467] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
    [ 29.248718] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.0.36.91 255.255.255.0 10.0.36.254
    Running ADP...Done. Master is 10.0.36.253
    [ 53.065065] wifi0: AP type AP-215, radio 0, max_bssids 16
    [ 53.282459] aruba_usb_power_control:1136 en:1 status:0
    [ 53.344043] aruba_enable_usb_block:556 Enabled USB
    [ 53.401405] aruba_usb_power_control:1141 Enable USB power control for 214/215
    [ 53.486877] tomatin_usb_power_control:975 enable the USB
    ardmore: Insmod BT modules
    [ 54.181033] usbcore: registered new interface driver usbfs
    [ 54.426931] usbcore: registered new interface driver hub
    [ 54.548450] usbcore: registered new device driver usb
    [ 54.707025] usbcore: registered new interface driver usbserial
    [ 55.001595] USB Serial support registered for generic
    [ 55.062364] usbcore: registered new interface driver usbserial_generic
    [ 55.140637] usbserial: USB Serial Driver core
    [ 55.286816] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 55.365109] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [ 55.444377] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [ 55.587211] fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000
    [ 55.660863] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [ 55.727659] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 55.808992] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 55.895492] usb usb1: Product: Freescale On-Chip EHCI Host Controller
    [ 55.972642] usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
    [ 56.037290] usb usb1: SerialNumber: fsl-ehci.0
    [ 56.149006] hub 1-0:1.0: USB hub found
    [ 56.193956] hub 1-0:1.0: 1 port detected
    [ 56.535018] usbcore: registered new interface driver cdc_acm
    [ 56.602888] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
    shutting down watchdog process (nanny will restart it)...
    <<<<< Welcome to the Access Point >>>>>
    So it eventually ended up in a prompt. Power led blinking green, enet blinking green faster. Amber 5GHz.
  • 7.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 13, 2018 03:05 AM
    Signer Cert OK
    Policy Cert OK
    [ 0.000000]
    [ 0.000000]
    [ 8.442882]
    [ 8.769433]
    So it eventually ended up in a prompt. Power blinking green, enet blinking faster green, 5GHz amber.
  • 8.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 13, 2018 05:52 AM
    Please contact TAC for what you should do next:
    http://www.arubanetworks.com/support-services/contact-support/
  • 9.  RE: IAP-215 kind of died, can't convert to CAP.
    Posted Feb 16, 2018 04:42 AM
    Thanks. I will get a replacement.
