IAP 215 - received no response from server
  • 1.  IAP 215 - received no response from server
    Posted Oct 17, 2017 02:33 PM
    I have IAP 215's setup with a Virtual Controller that I am trying to upgrade.
    When I try to check for new firmware version I get the message "received no response from server".  When I SSH into the controller and try to ping google.com I get unknown host, and I can ping 8.8.8.8.
    I manually upgraded the AP's to 6.5.2.0 and still have the same issue after the upgrade is complete.
    Also, I have another set of AP's, similar configuration and same version, I was able to do the check for new firmware and upgrade the AP's.
    Figured out my issue -- Removed and Re-added the DNS settings to the AP
  • 2.  RE: IAP 215 - received no response from server
    Posted Oct 17, 2017 10:30 PM
    Why wouldn't you just get DNS from dhcp?
