last person joined: 3 hours ago
IAP-215's wont join existing VC
  • 1.  IAP-215's wont join existing VC
    Posted Jun 16, 2015 07:54 PM
    I have an existing VC with 17 IAP-135's on it.  It's been working fine for a year or more.  I upgraded it to 6.4.2.6-4.1.1.7_50209 to ensure it would support the new IAP-215's I was going to add.
    Unfortunately, none of the 215's will join the controller.  The best I can tell, the problem is some sort of image mismatch.  I have completed this exact process at another site and all the 215's came online to the VC without issue.  Running same version and everyhing.  Below is the log.
    Thanks for your help.
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.06.16 19:03:03 =~=~=~=~=~=~=~=~=~=~=~=
    LCHS-NTN-25# sh log system
    Jun 16 17:50:51 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.101, using url 0, auto save disable 0.
    Jun 16 17:50:51 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.114, using url 0, auto save disable 0.
    Jun 16 17:50:52 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.102, using url 0, auto save disable 0.
    Jun 16 17:50:52 nanny[2753]: <303073> <ERRS> |AP LCHS-NTN-25@10.9.2.120 nanny| Process /aruba/bin/radiusd-term [pid 5222] died: got signal SIGTERM
    Jun 16 17:50:52 nanny[2753]: <303079> <ERRS> |AP LCHS-NTN-25@10.9.2.120 nanny| Restarted process /aruba/bin/radiusd-term, new pid 5420
    Jun 16 17:50:57 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Isc_send_request
    Jun 16 17:50:57 cli[2829]: <341005> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| APAS provision failed, code: connection-failed
    Jun 16 17:51:40 cli[2829]: <341108> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| sess_validate_sid: 179 invalid session client-10.201.1.18 sid-AstftA9MrlmOklTyjSaq.
    Jun 16 17:52:01 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-ac:a3:1e:c6:f8:b8, version-6.4.2.0-4.1.1.0_46028, ccode_idx-0.
    Jun 16 17:52:01 cli[2829]: <341165> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send image match to 10.9.2.88.
    Jun 16 17:52:06 cli[2829]: <341199> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_config_init: send config to slave 10.9.2.88, using url 0, auto save disable 0.
    Jun 16 17:52:57 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Isc_send_request
    Jun 16 17:52:57 cli[2829]: <341005> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| APAS provision failed, code: connection-failed
    Jun 16 17:54:58 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c3:bb:94, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:54:58 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:54:58 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:54:58 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.222
    Jun 16 17:56:15 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6f:04, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:15 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:15 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:15 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.239
    Jun 16 17:56:15 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:c4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:15 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.204
    Jun 16 17:56:16 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:24, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:16 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.238
    Jun 16 17:56:16 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6e:f4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.243
    Jun 16 17:56:16 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:f4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:16 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.180
    Jun 16 17:56:17 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:f0, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:17 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.172
    Jun 16 17:56:17 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6d:b4, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.245
    Jun 16 17:56:17 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6b:10, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:17 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.174
    Jun 16 17:56:18 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:a8, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:18 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:18 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:18 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.242
    Jun 16 17:56:19 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6a:4a, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:19 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:19 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:19 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.240
    Jun 16 17:56:20 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6f:38, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:20 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    .120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.195
    Jun 16 17:56:20 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6b:46, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:20 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:20 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.244
    Jun 16 17:56:20 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c5:6f:26, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:20 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.241
    Jun 16 17:56:21 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-6c:f3:7f:c3:60:e2, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:21 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:21 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:21 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.150
    Jun 16 17:56:23 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-6c:f3:7f:c3:64:06, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:23 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:23 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:23 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.225
    Jun 16 17:56:50 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-6c:f3:7f:c3:61:08, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 17:56:50 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 17:56:50 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 17:56:50 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.250
    Jun 16 17:56:58 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Isc_send_request
    Jun 16 17:56:58 cli[2829]: <341005> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| APAS provision failed, code: connection-failed
    Jun 16 18:01:55 cli[2829]: <341097> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check: mac-9c:1c:12:c3:bb:94, version-6.4.2.6-4.1.1.7_50209, ccode_idx-0.
    Jun 16 18:01:55 cli[2829]: <341052> <ERRS> |AP LCHS-NTN-25@10.9.2.120 cli| recv_image_check, 1637: AP class not match, Master-25, Slave-15.
    Jun 16 18:01:55 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| Image_sync_via_isc
    Jun 16 18:01:55 cli[2829]: <341004> <WARN> |AP LCHS-NTN-25@10.9.2.120 cli| send_image_mismatch url (ap classCentaurus) to 10.9.1.222
    LCHS-NTN-25#
  • 2.  RE: IAP-215's wont join existing VC
    Posted Jun 16, 2015 08:20 PM
    I sent you the 4.1.1.7 image for the AP215.  Try upgrading it individually, first and then try to join it to the cluster.
  • 3.  RE: IAP-215's wont join existing VC
    Posted Jun 25, 2015 12:45 PM
    Thanks Chris.
    Here is the new problem.  I SSH to one of the 215's and immediately get the following message:
    Warning: CLI module is running in a degraded state. Configuration, write memory, and support command are disabled; please debug with caution.
    So I try the upgrade-image tftp://X.X.X.X/imagename you sent me
    I get the following message but it never does anything. I monitor the TFTP server and you can see that the AP never even requests a file or connects to it.
    Upgrading swarm image. Will automatically reboot when done.
    Any ideas?
    Not sure if this helps, but I can actually shut down all the existing 135's and the new 215's will form their own VC that I can manage.  Of course the 135's wont connect to it when I boot them back up. But I do have the ability to get the 215's working in their own VC or the 135's working in their own VC.  Just not both.
    Thanks.
  • 4.  RE: IAP-215's wont join existing VC
    Posted Jun 25, 2015 06:52 PM
    Did you try to upgrade using the GUI with the file I sent?
  • 5.  RE: IAP-215's wont join existing VC
    Posted Jun 28, 2015 12:19 PM
    I guess I overlooked the obvious.
    That worked. Thanks for your help.
  • 6.  RE: IAP-215's wont join existing VC
    Posted Sep 01, 2015 04:15 PM
    I recently had a similar issue with a single 215 not joining the VC after all 215 APs were upgraded to 6.4.2.6-4.1.1.8_50989.  I also had the message, "CLI module is running in a degraded state."  So, I couldn't upgrade the firmware from the CLI.  Also, I couldn't access the GUI so I couldn't upgrade the firmware that way either.
    The CLI would allow me to revert to the previous version on the other partition, so I used the following command to switch boot partitions and reboot:
    switch-partition-reboot
    While the AP was rebooting, I changed the switchport to an isolated VLAN.  While in isolation, I could access the GUI and successfully upgrade to 6.4.2.6-4.1.1.8_50989.  After the reboot, I cleared the config and moved it back to the original VLAN.  It then successfully joined the virtual controller.
  • 7.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 02:56 PM
    Hi Joseph,
    I'm new to Aruba, do you mind if you could send me the link steps/howto upgrade the AP (e.g. IAP-105) individually? As I was having the same problem that IAP device was NOT joining or NOT showing in existing VC (though for the past months with the same model IAP-105, it was successfully joined without issue except for this time).
    I was guessing that it might the software version as the existing were running ArubaOS (MODEL: 105), Version 6.4.2.6-4.1.3.0 and this new IAP is version-6.3.1.4-4.0.0.6_44126. Below is some log output taken via show log system, as shown below:
    Aug 19 09:19:02 cli[1722]: <341097> <WARN> |AP ARUBA-004@10.?.?.11 cli| recv_image_check_v1_1: mac-9c:1c:12:c9:12:96, version-6.3.1.4-4.0.0.6_44126, ccode_idx-0.
    Aug 19 09:19:02 cli[1722]: <341052> <ERRS> |AP ARUBA-004@10.?.?.11 cli| recv_image_check_v1_1, 1565: AP class not match, Master-26, Slave-10.
    Aug 19 09:19:02 cli[1722]: <341004> <WARN> |AP ARUBA-004@10.?.?.11 cli| Image_sync_via_isc
    Aug 19 09:19:07 cli[1722]: <341097> <WARN> |AP ARUBA-004@10.?.?.11 cli| recv_image_check_v1_1: mac-9c:1c:12:c9:12:96, version-6.3.1.4-4.0.0.6_44126, ccode_idx-0.
    Aug 19 09:19:07 cli[1722]: <341052> <ERRS> |AP ARUBA-004@10.?.?.11 cli| recv_image_check_v1_1, 1565: AP class not match, Master-26, Slave-10.
    Aug 19 09:19:07 cli[1722]: <341004> <WARN> |AP ARUBA-004@10.?.?.11 cli| Image_sync_via_isc
    Aug 19 09:19:12 cli[1722]: <341097> <WARN> |AP ARUBA-004@10.?.?.11 cli| recv_image_check_v1_1: mac-9c:1c:12:c9:12:96, version-6.3.1.4-4.0.0.6_44126, ccode_idx-0.
    Aug 19 09:19:12 cli[1722]: <341052> <ERRS> |AP ARUBA-004@10.?.?.11 cli| recv_image_check_v1_1, 1565: AP class not match, Master-26, Slave-10.
    Your help is very much appreciated.
    Kind regards,
    Jun
  • 8.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 03:03 PM
    What is the output of "show upgrade info" on the Virtual Controller?
  • 9.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 03:25 PM
    Hi Joseph,
    Thanks for a quick reply. Below is the output from show upgrade with mix APs (e.g. 114 and 105). The AP with MAC address 24:de:c6:ce:35:??  was the one that I deployed past months that has no issue with the same model that I have now that has a problem NOT showing in existing VC.
    ARUBA-004# show upgrade info
    Image Upgrade Progress
    Mac IP Address AP Class Status Image Info Error Detail
    18:64:72:c2:b0:?? 10.?.?.21 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.22 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.23 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.24 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.25 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.26 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.27 Pegasus image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.28 Pegasus image-ok image file none
    18:64:72:c2:af:?? 10.?.?.29 Pegasus image-ok image file none
    24:de:c6:ce:35:?? 10.?.?.30 Orion image-ok image file none
    18:64:72:c2:b0:?? 10.?.?.31 Pegasus image-ok image file none
    Auto reboot :enable
    Use external URL :disable
    Thanks and regards,
    Jun
  • 10.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 03:30 PM
    You can disable auto-join on the cluster and
    (1) Individually Upgrade or downgrade the newest AP to the image of the cluster or
    (2) Individually Upgrade or downgrade the cluster to the version of the newest AP
    then
    Turn off autojoin and try to add that AP to the cluster.  This could be an issue with older firmware.
  • 11.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 03:54 PM
    Hi Joseph,
    I prefer to do the Option-1 to upgrade the new AP to the image of the cluster. But please bear with me as I'm new to this, do you mind if you could send me detailed steps/procedure to do this that I will be able to successfully safely complete this task? I've already downloaded below software (as per of your reply on this post - https://community.arubanetworks.com/t5/Controllerless-Networks/IAP-Firmware/m-p/286188)  BUT not sure if this would work with the current version 6.4.2.6-4.1.3.0_54915 of the cluster.
    ArubaInstant_Orion_6.4.2.6-4.1.3.1_55246
    Please advise.
    Kind regards,
    Jun
  • 12.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 04:01 PM
    To upgrade/downgrade the image, you need to go to maintenence> Firmware and upload the file.
    The images must match for the AP to join the cluster successfully, so the one I pointed to will not work.  Let me PM you some information.
  • 13.  RE: IAP-215's wont join existing VC
    Posted Aug 21, 2019 04:02 PM
    I mean PM me your email address and I will send you some information.
  • 14.  RE: IAP-215's wont join existing VC
    Posted Aug 22, 2019 01:23 PM
    Followed all the instruction from cjoseph
  • 15.  RE: IAP-215's wont join existing VC
    Posted Jun 17, 2015 08:29 AM
    Hi Friend,
    It is expected issue because, both IAP 135 and IAP 215 are of two different hardware, IAP 135 is a Cassiopeia and IAP 215 is a Centaurus hence they can not join the cluster due to Image mismatch. there are two ways to get it done,
    1. Configure Airwave to push the image so that the IAP 215 will download the required Image and join the cluster
    2. Upgrade the IAP 215 with the same Image as IAP 135 and join the cluster.
    Please feel free for any further help on this.
