For proper MIMO performance, you want the antenna patterns of the three antennas to be similar and overlapping. Changing one of the three antennas to a higher-gain model will result in performance issues.
Aruba offers some 3x3 antennas with directionality and higher gain. I would suggest you explore that if your target coverage area is not omnidirectional.
