IAP-224 wireless bridge support.
  • 1.  IAP-224 wireless bridge support.
    Posted May 27, 2014 05:20 PM
    About to install 2 x IAP-224 as a wirless bridge however in the recent firmware notes (6.3.1.4-4.0.05) states the following: IAP-22x does not support wireless mesh functionality. I am guesing that it is just refereing to the automatic mesh feature of previous IAP's, will this be supported at a latter date ? I allso read a tech note that stated the 27x series would not have this feature until 3rd quater of 2014 is this correct ? If so is this the same for the 22x series ?
    Cheers,
    Mark
  • 2.  RE: IAP-224 wireless bridge support.
    Posted May 27, 2014 07:45 PM
    What you read is correct.
  • 3.  RE: IAP-224 wireless bridge support.
    Posted May 27, 2014 08:10 PM
    Cheers Seth,
    So i am guessing you can't set up the IAP-224 as a wirless bridge manually ?
    Thanks for your time mate.
