IAP 225 1Password Sync issue
  • 1.  IAP 225 1Password Sync issue
    Posted Jul 03, 2020 01:22 PM
    Recently moved wifi over to a Aruba IAP 225 running 8.6.0.5. After the move I had a complaint come up that a users 1password app stopped syncing over wifi.
    Enabled everything I could think related based on any documentation I could find but still not able to see each other across the wifi. Switching back to an ASUS router that was in place before allows the two devices (mac book & iPhone) to see each other and sync.
    I can see both clients connected to the IAP in the webGUI but can not figure out what might be blocking the sync. Bonjour & DLNA are both enabled, All airgroup options are enabled (not sure if needed) Broadcast filtering is set to off.
    Any thoughts?
