IAP-225 and cisco 3560G port-channel issues
  • 1.  IAP-225 and cisco 3560G port-channel issues
    Posted Apr 17, 2015 02:36 PM
    I just got an Aruba IAP-225 (powered via an adapter) connected it to a Cisco 3560G switch via a 2 x 1Gb Port-channel configuration. On the Cisco side the LACP is set to active. On the AP side I see int Bond0 that is up/up and I'm able to connect via the wireless.
    Cisco Core Switch (IOS 15.02):
    Vlan2 - WLAN_MGNT 10.10.20.0/24
    DG:10.10.20.1
    Vlan10 - WLAN_MGNT 10.10.100.0/24
    DG:10.10.100.1
    Vlan20 - WLAN_MGNT 10.10.200.0/24
    DG:10.10.200.1
    Vlan25 - WLAN_MGNT 10.10.250.0/24
    DG:10.10.250.1
    Interface Po1
    switchport trunk encapsulation dot1q
    switchport mode trunk
    switchport trunk native vlan 2
    IAP225 (Aruba 6.3)
    native vlan 2 (changed int he configs)
    Bond0: 10.10.20.254
    Virtual:  10.10.20.100
    SSID
    Data - Vlan 10
    Voice - Vlan 20
    Guest - Vlan 25
    1. I started testing the failover feature and what I noticed is that when I disconnect eth0 port then the uplink to the switch goes down. If I unplug eth1 then the connection remains.
    (Is this a known behavior?)
    2. When the port-channel is up I see Mac address flaps on the switch.
    (What is the recommended load-balancing algorithm to use?)
    3. I'm able to ping the Virtual ip (10.10.20.100) address from the switch (10.10.20.1) but I cannot ping the physical ip (10.10.20.254) address of the AP. Is there something on the AP that I might have missed?
    I appreciate any input regarding this setup
    Andrei Patergin CCNP
    #AP225
  • 2.  RE: IAP-225 and cisco 3560G port-channel issues
    Posted Apr 17, 2015 06:29 PM
    Which link is providing power?
    Tim
  • 3.  RE: IAP-225 and cisco 3560G port-channel issues
    Posted Apr 17, 2015 07:41 PM
    I'm using the power supply (AC Adapter), no POE and no POE Injector.
    Andrei Patergin (CCNP)
