iap 225 and iap 303
  • 1.  iap 225 and iap 303
    Posted Feb 20, 2019 04:47 AM
    These access points can they work together?. I mean can they share the same network?
  • 2.  RE: iap 225 and iap 303
    MVP EXPERT
    Posted Feb 20, 2019 05:33 AM
    As long all IAPs are running Aruba InstantOS 8.3.0.0 or Aruba InstantOS 8.4.0.0 for the 303P. They will form a cluster if in the same L2 broadcast domain. If they are L3 separate they will be in separate clusters.
