IAP 225 and mounting brackets Product Code
  • 1.  IAP 225 and mounting brackets Product Code
    Posted Jul 25, 2018 11:23 AM
    Hi there,
    I am trying to order IAP225 and mounting bracket for ceiling tile rail. I will need to order some mounting brackets (some of the ones that cme with the AP for ceiling tile rail) as a site I am looking after has 3 IAPs above the ceiling and I want them installed below on the rail.
    Also, I am looking at the product codes and they only seem to be in;
    JW240A Aruba Instant IAP-225 (RW) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
    JW242A Aruba Instant IAP-225 (US) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
    JW239A Aruba Instant IAP-225 (JP) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
    JW238A Aruba Instant IAP-225 (IL) 802.11n/ac Dual 3x3:3 Radio Integrated Antenna AP
    I dont see the code for Ireland, can anyone help with above please it will be much appreciated.
    Kind Regards
  • 2.  RE: IAP 225 and mounting brackets Product Code
    Posted Jul 25, 2018 11:30 AM
    @prodigy wrote:
    Hi there,
    Kind Regards
    For Ireland, the rest-of-world product code is appropriate.
  • 3.  RE: IAP 225 and mounting brackets Product Code
    Posted Jul 25, 2018 11:40 AM
    Many thanks for your response that cleared that up. On that note; would you also know the code for License to have the 4 IAP225s on Aruba Central..? Also 3 year subscription Key.
    Kindest Regards and thanks again.
  • 4.  RE: IAP 225 and mounting brackets Product Code
    Posted Jul 25, 2018 11:44 AM
    Also, mounting bracket codes for ceiling tile rail..?
  • 5.  RE: IAP 225 and mounting brackets Product Code
    Posted Jul 25, 2018 11:48 AM
    I am so sorry I mean 5 year license
    Sorry about that.
    Looking forward to hearing from you
  • 6.  RE: IAP 225 and mounting brackets Product Code
    Posted Jul 25, 2018 12:20 PM
    Ceiling tile rails should be included with the AP.
    For Central pricing, I would contact a local HPE/Aruba partner in your area who has the correct product skus and pricing.
